Question about Frigidaire Affinity ATF7000E Front Load Washer
Wont drain has cade e20 flashing - Frigidaire Affinity ATF7000E Front Load Washer
    Genius:
  • 1,417 Answers
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
INSTRUCTION BELOW
  • A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
  • 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  • 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
  • 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  • 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall
  • thanks and thanks for using fixya.
    Posted on Oct 03, 2010
    Another AEG e20 Plea, tried everything please help!
    E20 on your machine means some sort of drain problem. If it actually goes through the spin cycle fine; some water will still not drain out at the time of the tumble dry. Check the wall drain to make sure it isn't clogged..
    Check the drain of your wall, not the washer, this shd be cleaned out thoroughly; and the exit pipe of your washer should not fit too tight into it, there shd be some space for air.
    This is a further tip, if helped click helped.
    Apr 10, 2013 | Washing Machines
    E20 code flashing Crosley washing machine
    E20 is a draining issue. You probably have objects obstructing the drain line.
    May 06, 2012 | Crosley CW5000 Front Load Washer
    My Zanussi Jetsystem Timeline washer/dryer starts its wash cycle, but when it comes to draining, it wont drain and flashes E20.
    Have you taken the filter out at the front of the washer and cleaned it. Mine wouldn't drain but once I did that it worked ok.
    Mar 04, 2011 | Zanussi ZWD1680W Front Load Washer / Dryer
    E20 message want spin
    E20 is not an exact error code. It's indicating a possible pump out problem. Here is a few possible causes of an E20 error code:
    1. Restriction in the drain pump
    2. Failed pump
    3. Water not pumping out fast enough (crimped drain hose)
    4. Too many suds ( too much detergent or wrong kind)
    5. Pressure switch (not communicating with control board)
    6. Loose wire at pressure switch
    7. Loose wire at pump or control board
    8. Failed control board
    Apr 29, 2010 | Frigidaire ATF6000ES Front Load Washer
    My kenmore he washer will not drain all the water also have code E20 flashing
    2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
    3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Feb 16, 2010 | Kenmore HE2 Plus Front Load Washer
    The machine wont spin when in spin cycle and
    try cleaning out the coin trap/drain hose that is underneath the machine
    this is also the error code E20 which sometimes the machine will start flashing
    Jan 15, 2010 | Frigidaire Affinity ATF7000E Front Load...
    E10 & E20 problem
    e10 problems refer to water supply..so check the tap is on, the inlet hose is not kinkrd, and the filter in the inlet hose is not blocked.  e20 refers towater drainage,  so check the drain hose isn't kinked and the drain pump isn't clogged
    Aug 09, 2009 | Electrolux EW1000i Front Load Washer
    E20 code. Not draining
    E20 is a general error code to get to the real problem try this..
    Reading Error Codes 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an “E” followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. let me know what code come up... hope it helps
    Jun 06, 2009 | Zanussi ZWD1470W Front Load Washer / Dryer
    Zwf 1631 w
    Have you took the front cover off and looked for the strainer which is located before the water pump. I have seen many of them plugged tightly, causing the water not to drain. Look inside the owners manual that came with the machine. It also should give you some things to check that would cause the code E20 to keep flashing. Hope this helps.
    May 09, 2008 | Zanussi ZWF1430W Front Load Washer
    Frigidaire Affinity ATF7000E Front Load Washer Logo
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
