Question about Kenmore 24 in. 15079 Built-in Dishwasher
Food residue is building up on my dishes. i have put CLR through it to clean it out. is there something else i need to do
  • 5,081 Answers
There are many probable causes of failure .
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishwashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher
Posted on Oct 03, 2010
  • INDIRA KUMAR
    INDIRA KUMAR Oct 03, 2010
    A helpful rating and a testimonial would be greatly appreciated if you are satisfied with my solution...
Our maytag is about ten years old. No big problems that a little vinegar wouldn't solve once in awhile. Lately, we ran out of water softener salt and a white film was on dishes and not getting clean. I...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 28, 2011 | Maytag 24 in. MDB4100 Built-in Dishwasher
Dishwasher is about 8 years old an dishes are just not as clean. Looks like they have a bit of residue on the dishes. Dishes clean in terms of food, but just not squeaky clean look anymore. Way to clean...
heatman101
Aug 21, 2010 | Asko D1876 Dishwasher
Brand new bosch dishwater does not get dishes clean - food residu
Try the cascade new soap they have been changing the ingredents due to state requirments for the water treatment. also make sure spray arms and jet are free from food particles,also clean soap dispencer,If you want run CLR through dish washer no dishes to clean machine.Thanks
Jul 26, 2010 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Whte residue left on glassware and dishes
use a dishwashing cleaning agent in the machine. or some thing the has a grease cutting agent.run this on an empty cycle.
there are times residue grease and oils can accumulate down in the sump area where the water sits and can cause film on the dishes.
this could also be some lime or scale build up for that you can use some C.L.R or any kind of lime and scale remover to clean your machine.
make sure tht that this is done on an empty dishwasher
May 19, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
I have maytag dishwasher leaves food residue
there is a filter on the inside bottom of the dishwasher check and clean it
May 16, 2010 | Maytag 24 in. MDBH970AWS Built-in...
Dishwasher just started leaving food residue on dishes after washing. We usually don't rinse beforehand but even when we do this it's still happening. Can I run something thru a cycle to give the washer a...
heatman101
Mar 08, 2010 | GE Nautilus 24" Built-in Dishwasher
Galaxy D/W Not Cleaning.Also leaving grit on dishes
You should try using a product called 'CLR' were normally you would put soap and also down the water supply pipe to the d/w. it will get rid of any calcium build up in the internal plumbing that could be caused by hard water. Don't have any dishes in when you do this 'clean run'. Next put a couple of dirty plates in and do another run with Cascade in the soap dish. That shoud fix it.
Carefull though CLR is corrosive, wear gloves and safety glasses. When you put the CLR down the water inlet pipe, if you can, turn the water back on before you start the clean run.
Dec 02, 2009 | Cars & Trucks
White Residue
most likely it is your detergent. palmolive eco is notorious for leaving a white chalky residue on dishes. try this out before calling a service tech: put unclean glasses in the dishwasher and in your soap dish and rinse cycle cup put 1/2 cup of distilled white vinegar. if it cleans (or improves) your dishes, then your detergent is the culprit.
Jul 29, 2008 | Frigidaire 24 in. FDB510LC Free-standing...
Dishwasher dishes not clean
i am a retired appliance engineer of 20 years, (and whats a chopper), this problem can be easily improved maybe totally rectified, by making sure the salt is topped up and use rinse aid, make sure all the food catch filters are cleaned out and the waste outlet is also cleaned out, make sure blades are free to rotate and holes are not blocked, these are easy to remove and clean they just unclip. there is no need to dismantle the appliance hope i have helped , if so please rate me,
Sep 18, 2007 | Kenmore 24 in. 16222 Built-in Dishwasher
Kenmore 24 in. 15079 Built-in Dishwasher Logo
96 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
