Question about Razor Pocket Mod-bistro Retro Scooter
Razor pocket mod won't work. When i twist the throttle I hear a clicking noise but nothing else happens battery and charger seem fine and the fuse looks ok
5 Suggested Answers
  • 38 Answers
SOURCE: Bought a razor pocket mod scooter second-hand-it
Use a wedge. Place the thin end between the tire and rim. Then push the tire off using the wedge and your other hand, work your way around the circumference of the tire until it is off. Use the same process to put the new tire on. But this time you will push the tire on the rim.
This is a pic of the ideal tool you should use:
Posted on Aug 13, 2010
SOURCE: razor e300 scooter charger light stays green,
I have this same problem? What do you do? I bought a new charger thinking it was that and the light stays green on it too.
Posted on Sep 09, 2010
  • 25 Answers
SOURCE: Pocket Mod -battery charged. when
none
Posted on Jun 21, 2011
  • 11 Answers
SOURCE: battery charger shows charged. however
Does the Razor charger light go straight to charged? If so the battery has gone & needs replacing, please check the voltage output & load test the battery (weight on scooter while battery connected straight to motor). very common but overlooked issue can just be the On/Off switch, check there is voltage present across the terminals. If you are hearing a clicking noise then the control module may have gone.
Posted on Jul 05, 2011
Hannah Montana razor scooter says charged but wont go whats wrong
I haven't used my razor scooter in years. I just bought a charger and it seem like it is charging but it keep saying it is on low. I twisted the gas thing and it is making a noise like it want to go. But I am not sure I have charge it for 12 hours now. Do I need a battery or is it just taking it time to charge.
Sep 17, 2015 | Electric Razor Pocket Mod Scooter
I think batt is charging power light on but all i hear is a clicking noise and no movement
Replace the battery with a new one and then make sure the new one gets a complete charge before operating the scooter.
May 13, 2015 | Razor USA Razor Pocket Mod Electric...
Motor won't engage. I turn the throttle and get a clicking sound, but nothing happens. We've charged the battery for about 4-6 hours, but the light stays red, never turns green. Help?!!
sounds like the battery is bad and not taking charge.replace battery attemp again if not then check for fuel, spark and compression.then c wat happens or wats not working any motor no matter how small or big has to hv those three things to run. hope this helps.
Jul 08, 2012 | Electric Razor Pocket Rocket Ride-on...
Razor Bella scooter problem
yes sounds like the control module, you can always jump the batteries directly to the motor to make sure that the motor is ok
Jun 25, 2012 | Razor USA Razor Pocket Mod Electric...
How do you operate Bella mod
there is an on/off switch right below the seat next to where you plug in the charger, then you have to twist the right hand grip
Apr 29, 2012 | Razor USA Razor Pocket Mod Electric...
Battery charger shows charged. however when tun throttle, nothing. no indication of loose wire connections. have a pocket mod
Make sure it is not battery or motor, jump the battery + & - to the motor + & -, if it works it will be the control box
30 minute fix for very cheap
ITEMS NEEDED
Get a Potter & Brumfield relay (5 poles)
2-3 feet of wire
4 female wire ends to plug into relay
HOW TO FIX
Take apart razor so you can see the black control box
Unhook throttle plug, this is the one with 4 wires (2 brown & 2 orange on mine)
Wire relay:
85: Ground
30: Red wire from switch to control box, if you wire this straight to battery it will work with switch on or off (killing battery)
87: Red wire to motor
86: Brown wire from throttle plug
Run a wire from 12v (battery) to other brown wire on throttle plug
END RESULT
When the throttle is activated, it closes the loop in the brown wires, triggers the relay, activates the motor
You WILL NOT have the throttle control, it is wide open or off when you activate/de-activate the throttle
This will save you $30 for a new control (brain) box.
Jun 10, 2011 | Razor E100 Electric Scooter
Razor MX 650 wont run
i had the same problem but fixed it this morning, i just sat far back on the seat when turning throtle with all my weight and then slid back on normal when moving, but it makes a grinding noise.
Jul 23, 2009 | Electric Razor Pocket Rocket Ride-on...
Razor Pocket Mod-bistro Retro Scooter Logo
141 people viewed this question
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
David Payne
David Payne
jasiel murphy
Are you a Razor Toy Expert? Answer questions, earn points and help others
