My kenmorre 41742042100 will not drain - Washing Machines
    Genius:
  • 1,417 Answers
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
INSTRUCTION BELOW
  • A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
  • 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  • 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
  • 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  • 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall
  • thanks and good luck.
    Posted on Oct 03, 2010
    I have an older, but in good condition, Kenmorre 80 series top loader washing machine. The spinning won't move or when it starts washing, the arm in the middle doesn't spin the clothes around. Would it...
    The Sears series numbers (70, 80, 90) only mean how many "bells and whistles" a washer has. The most important thing is the full model number. Usually a number starting with 110.########.
    Most models don't use belts anymore but use a Motor coupler.
    This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
    First, see the Sears parts site for your washer:
    http://www.searspartsdirect.com/partsdirect/index.action
    Enter your model number (110.######) and you'll see a list of major sub-components with diagrams and parts.
    Look in the section for the motor, pump gearcase and you'll see the Motor Coupler.
    Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
    It's used as a fail safe device and consists of three parts.
    Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a
    rubber piece with six holes.
    The power from the motor is transmitted through the rubber piece to the transmission.
    The other shaft on the motor directly drives the pump. This is likely why the machine drains.
    If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
    See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
    http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
    If the coupler looks damaged, it's a relatively easy fix.
    Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
    Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
    Put the rubber piece on the transmission plastic piece.
    Replace the motor mounting plate.
    Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be
    damaged.
    Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
    Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
    Nov 21, 2010 | Kenmore Washing Machines
    My kenmorre quiet guard 2 dishwasher is not draining completely and is leaving dishes with a soapy residue.P,ease help.thank you.
    Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
    Dishwasher Problems - Water will not drain out
    heatman101
    Nov 11, 2010 | Kenmore 24 in. 15932 Built-in Dishwasher
    Kenmorre HE3 turns on tumbles a few time then stops and smells like something is burning. Belts not broken. Could they still need to be replaces. Wonts start again for a few minutes
    there is a thermo switch which will shut down a dryer ( its a safety feature) this may be bad. I would pull the front off and investigate to see if the motor, belt , roller etc is causing this problem. Open dryer door take out screws pry gently on each top corner and the front panel is off(some have screws in the bottom corners). Hope this helps tim
    Aug 29, 2010 | Dryers
    My Kenmorre Series 80 washing machine is not agitating or spinning in any cycle. The motor is still running but the agitator is not moving.
    Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
    Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
    If the motor coupler is broken, or worn, the motor may not be able to send power to the transmission for agitating or spinning.
    Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
    Feb 13, 2010 | Kenmore 15864/15862 Top Load Washer
    Our front loading Kenmore MODEL 41742042100.has begun sounding like a jet enjine when it is spinning,someone told me that it is probably bad bearings, is it worth having this 7yr old machine repaired or...
    Hi.
    I
    f you get a very loud noise coming from the machine, and this noise islouder when it spins faster, then it is often because of a problem with the drum bearing.
    The drum bearing is bad, probably drum bearing spider had broken.
    On a front load the drum bearing is located at the back of the drum.
    To replace the part you take apart machine, undo the belt and depending on the model you may need to remove more parts.
    You can find parts and diagrams for most models here.
    Nov 13, 2009 | Kenmore 44042 Front Load Washer
    I have a Kenmorre model 61161 series,that does not freeze or cool
    The cycling sound may be a bad compressor relay or a bad compressor.
    Do you hear a click about every 2 minutes?
    If so, replace the compressor start relay.
    Feb 21, 2009 | Kenmore Refrigerators
    Kenmore 41742042100 front load washer
    IT IN THE SAME PLACE AS THE FRIGIDAIRE YOU HAVE TO TAKE THE FRONT LOWER PANEL OFF
    Jan 02, 2008 | LG WM2688H Front Load Washer
    Kenmore washer 41742042100
    the filter maybe blocked! or something caught in the pump or hose's going to it!
    Dec 09, 2007 | Whirlpool Duet GHW9150P Front Load Washer
    Open Questions:
    Washing Machines Logo
    Top Washing Machines Experts
