Question about Garden
I have an older 90 series Sears Craftsman shop vac and was wondering if I need to remove the filter during water extraction
SOURCE: shop vac
Vacuum is less than a year old and died in the middle of a use. No power... tried to plug it into 3 known, good outlets. Suggestions?
Posted on Jul 06, 2008
wadembly
  • 513 Answers
SOURCE: No model number Sears Craftsman Shredder/Vac
there is no tag on the deck of it it should be a silver color on or around the bottom of the shredder or if its a stand up type it should be on the sides some where but not all models have tags there stamped in the metal
Posted on Jun 05, 2009
SOURCE: craftsman shop vac no power when turn on
I just picked up a similar model someone was throwing away. turns out there is a thermal fuse inside the motor housing that blew. I just need to find the values of the fuse and repalce with appropriate size. motor runs when fuse is bypassed.
Posted on Jun 09, 2009
Richie_asg1
  • 1036 Answers
SOURCE: old shop vac
Yes there should be a filter fitted onto the top section.
For suppliers, it would be cheapest to find your nearest stockist, or buy online and have it shipped. It's still current stock - so spares should be readily available.
Sears stock it -
CRAFTSMAN FILTER
Thank you for using Fixya,
Posted on Sep 22, 2009
  • 56 Answers
SOURCE: Does anyone know the correct spark plug gap
030.
Posted on Jan 23, 2010
Need filter for craftsman6hp. 16 gal shop vac model 113.177060
They're availabe at Sears and Kmart. Lowes and Home Depot also have filters that will work.
Dec 27, 2012 | Craftsman 17765 Canister Wet/Dry Vacuum
I have a 6 gall wet dry shop vac bye rigid . do i need a foam wet filter on the inside or will it work properly without the filter on i need it for water only. people in the store said the paper filter was...
Always use the foam filter when using the Shop Vac, keep your filters clean and it will operate more smoothly. When sucking water I usually take the foam filter off as well as the cylinder filter
Oct 02, 2017 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Parts for a craftsman shop vac
Hello. The best source of craftsman parts is sears.com
If they don't have these parts I will be very surprised. regards, Joe
Feb 12, 2010 | Vacuums
Need brushes for the motor in my Craftsman Vac
Hello. The best source for all craftsman parts is sears.com regards, Joe
PS - kindly rate my answer helpful. thanks.
Jan 27, 2010 | Tools & Hardware - Others
Car interior!!!!!
It will extract the water from the interior, just be sure to remove the paper filter from it before you do.
Jan 25, 2010 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Older model shop.vac parts/owners manuel
Hi, I know on my Craftsman shop vac 2 different sizes of vacs that I use, I try and stick to the craftsman filters, but you can use other brands if they are not available or you want to save some ( $ ) ? As far as a manual for this vac, more then likely you will have to go to the maker and distributor as Sears, O.C.Hardware also sell there products. You may have to go with a manual that is the same peak H.P.and gallons that covers all different makes and models. Filter wise, make sure you have the right ones on or off when using the wet or dry pick-up settings.
Sincerely,
Shastalaker7
Jan 23, 2010 | Craftsman 17765 Canister Wet/Dry Vacuum
Old shop vac
Sears stock it -
CRAFTSMAN FILTER
Sep 22, 2009 | Craftsman 17765 Canister Wet/Dry Vacuum
Using shop vac 52722-90 for wet applications
yes, the foam filter is what you should use, also make sure you remove any bag, or paper filter, the water would make it fall apart.
Sep 16, 2009 | Shop Vac ShopVac 3 HP 2 Stage 10...
Wet/Dry Vac Leaking
are you using a water , foam material filter?
Aug 01, 2009 | Craftsman 17762 Wet/Dry Vacuum
Sears 90 Series Washing Machined throws ground fault during spin.
pvatki, I am a licensed electrician and the NEC (national electrical code) does not require a clothes washer to be on a ground fault circuit interrupter. Replacing your gfci with a standard duplex receptacle will fix the problem you are having.
Dec 29, 2008 | Kenmore 15864/15862 Top Load Washer
Garden Logo
107 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
