Question about Onkyo Audio Players & Recorders
Have an Onkyo TX904, wired speakers to remote but the volume control doesn't adjust. Have sound but faint on the remote speakers, main are fine. Switched the main and remote speakers from the terminal and the main speakers malfunction. Seems to be the remote terminal, volume control not there.
  • 14 Answers
SOURCE: onkyo SR605 Remote not working at all.
Dear Bzambo,
The batteries on the remote are fresh? if so the remote might be bad.
Sidlahora
Posted on Dec 06, 2007
mjap
  • 107 Answers
SOURCE: onkyo tx904
I think it does really happen that way on some things like that , maybe its the controling IC or a busted resistor inside your amp. and check your speakers too. maybe they are shorting inside that makes your amp malfunction. try too open it or its up to you.
Posted on Jan 13, 2008
jeesusfreek
  • 18 Answers
SOURCE: Rear Speaker volume too low
Channel level output can be adjusted in the menu if you have the remote. Set the rear channel level volume higher and the fronts lower if need be, and then turn up the volume. Enjoy!
Posted on Jan 28, 2008
SOURCE: don't know how to adjust volume on remote speakers
Can I ask you something? I have the same but the remote doesn't work, and I have no sound in the B speakers. I wonder if there's something that I have to do with the remote, or there's a problem with the receiver, Thanks.
Posted on Feb 03, 2008
  • 239 Answers
SOURCE: remote code for sony playstation 3
you cannot control a ps3 with that remote because the playstation 3 only works with bluetooth. I'm sorry to have to tell you. you can purchase a remote that works with your system at any that sells your system.
hope this helped
please rate well.
Posted on Mar 06, 2009
Connect Sharp LCD tv to Onkyo TX8011 Receiver
The Onkyo TX8011 is a Stereo Receiver. Two ways to connect:
1) The HD Cable box should have an audio out (typically red and white). Connect this to the Obnkyo CD input (red and white). The volume may be controlled with the Cable box remote or Onkyo remote. The TV volume may be muted or ON.
2) Connect LCD TV's audio out to Onkyo TX8011's CD input.
This is not a great way to set up, as the TV volume, when moved high, will attenuate (over load) the amplifier, leading to a jarring sound on the speakers. To avoid this, the TV volume should be ALWAYS FIXED low.. say about 30%. Only the Onkyo's volume should be adjusted while watching.
Hope this helps.
Nov 20, 2013 | Onkyo Audio Players & Recorders
Where is adjuystment page for audio
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
hope this helps you
Mar 22, 2012 | Logitech Audio Players & Recorders
ONKYO TX-DS484: \r\nI am not getting any sound out of my left speaker on stereo. I cannot find a balance adjustment. I do not have the remote control. Thanks
It sounds like you also need the manual.
http://www.retrevo.com/support/Onkyo-TX-DS484-Receivers-manual/id/365dj182/t/2/
The remote is an RC-4278. You WILL need it.
$25.10 on eBay expiring tonight so jump on it. 3h 35m 40s (Sep 06, 201120:16:46 PDT)
http://www.ebay.com/itm/ONKYO-RECEIVER-REMOTE-CONTROL-RC-385S-RC-373M-RC-371M-/290597112430?pt=LH_DefaultDomain_0&hash=item43a8f00a6e
As far as the left speaker goes, swap it to decide if it's the speaker, wire or the amp channel. There are no control settings that would make one of the front pair go silent.
Sep 06, 2011 | Onkyo TX-DS484 Receiver
Hi, I have a Denon AVR-1709 & recently set up Zone 2 to operate my outdoor speakers via AMP Assign. The system is working but I''m only getting limited volume through the outdoor spears and the...
zone 2 volume can be adjusted by zone2 remote control (small one which came with the unit) or by main remote control if you switch it to zone2 mode. My main rem control has a slide switch i have to put in zone 2 position to operate zone 2 amp.
Sep 03, 2011 | Denon AVR-1905 Receiver
I HAVE A ONKYO TX-910 RECEIVER THAT I PURCHASED IN 1993. IT PRESENTLY HAS NO SOUND. SHOWS POWERED UP & REMOTE CONTROL WORKS. HAVE CHECKED ALL THE SPEAKER WIRE CONNECTIONS & THEY ARE FINE. CAN THIS...
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING.
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead
Apr 09, 2011 | Onkyo TX-910 Receiver
I have an onkyo TX-SV515 PRO receiver and the remote speakers will not turn on. The main speakers work fine but when I depress the button to turn on the remote speakers they do not switch on.
I had the same problem. You must turn on the remote speakers via the reciever and then adjust the remote speaker volume control that is only located on the remote control. The volume buttons are on the top right of the remote. It is briefly discussed in the owners manual which can be downloaded online.<!-- from fixya rte -->
Jun 05, 2010 | Onkyo TX-SV525 Receiver
I wish to reduce the level of sound coming from the sub woofer. I cannot get the main menu up on screen by pressing reciever setup buttons. I have seen it done by a freind so I know it is possible what am...
On your remote control, first press the "RECEIVER" button followed by the "SETUP" button.
Here is a link to the user manual (bottom right corner of page): http://www.eu.onkyo.com/products/TX-SR605.html
From page 70 onwards it is explained how to set up the speaker levels.
Alternatively you could of course adjust the volume on the subwoofer itself. Most (active) subwoofers nowadays offer an output volume adjustment.
Good luck.
Nov 08, 2009 | Onkyo TX-SR605 Receiver
MY REMOTE IS NOT WORKING FOR MY ONKYO TX-SV525,
Hello, I am sorry for your issue. Please go to replacementremotes.com and search txsv525. They do sell a replacement. If you email me at askonkyo@us.onkyo.com and I will send you a copy of the manual. Thank you. Onkyo USA
Mar 14, 2017 | Onkyo TX-SV545 Receiver
Don't know how to adjust volume on remote speakers
Jan 16, 2008 | Onkyo M-282 2-Channel Amplifier
Onkyo tx904
Jan 13, 2008 | Audio Players & Recorders
74 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
