Question about HP Computers & Internet
My DVD drive does not register any discs put into it. This is a new computer, I've had it for a week, and the DVD drive has never worked.
  • Larry Miller May 11, 2010
    what type of computer, and what operating system, and are you familiar with going into BIOS to see what is recognized by your computer?
    write back with more details, it could be something as simple as a cord not attached correctly....
    Problem Solver:
  • 23 Answers
First just ask a question, is your dvdv drive share a data cable into your harddrive/hardisk, if true follow this instruction,
checked your data cable, power cable from your DVD drive, or try to determine if your dvd drive's jumper selection set to slave, after checked your hardrive jumper if it is set to slave change to master, hope you know how to change the jumper setup..
hope it will help.. tnx, if theres a question pm me..
Posted on May 27, 2008
Slim ps2 says "unable to read disc"
You might need a new DVD drive too. Sounds like you need expert help, i had sent my PS3 to videogame911.com after i attempted to work on it my self and they repair everything, even saved my data. Got it back within the week and at a very reasonable price. Hope this helps you.
May 03, 2013 | Sony PlayStation 2 (PS2) Console
Win XP intermittantly fails to see DVD or says it's blank
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem
"you only need to do the following"
if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Nov 21, 2012 | Computers & Internet
Optiarc 7580s dvd does not recognize any disk
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps you
or
or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
hope this helps
Mar 04, 2012 | Sony Optiarc Computers & Internet
My dell insptron 1545 wil not recognise my DVD drive how can I repair this ? I am unable to burn dvd's as even when i insert a brand new dvd I am told that I do not have a writable cd in the drive...
Hi There
DVD drive sometime it is not working simply because maybe the disc you insert is not compatible for the DVD drive you have or the disc you put is really cannot be rad by your DVD drive, best thing to is check and try few discs and observe your dvd drive, sometimes the lens is faulty or sometimes the module of the lens is not moving forward and backward. this is the most case i encountered. you can replace your dvd drive by replacing it by the new one. it is not very costly.
It is better to replace than to repair it, repair might be last only for a weeks while new is sure to work more than that.
thanks
Apr 11, 2011 | Dell Inspiron 1545 Notebook
I put a dvd on the disc tray, but it must not have clicked down because now the tray is open and the dvd is still in the computer
The only thing to do there if you have tried everything to get it out..is to remove the disc drive and take it apart...
but this is a strange 1...i,ve never worked on a computer where,s it,s swallowed up the disc...only if the disc drive is stuck in the closed position.....
Or remove the disc drive,give it a gentle taop on the top...then near the bottom of the opening you should see a small hole to put a pin in it ,to manually open the drive...try that a couple of time rarther than opening the drive up...
Hope this help...if it does then please rate it and if i can be anymore help..
Regards
Apr 02, 2011 | Averatec Computers & Internet
I put a disk into my hard dive the disk sounds as if it working but nothing happens on the screen
I asumme you mean CD/DVD drive?
Is the disc a blank or prog?
Check to see if it is registered.
Click my computer and see if D: drive is showing the disc program?
Nov 08, 2009 | Computers & Internet
Dvd drive not reading a disc
If this happens with every disc, then your drive needs fixing/cleaning or replacement. If it only happens with a specific disc such as your game, then something's wrong with the disc. If it's a homemade DVD you may be dealing with copy protection. Try cleaning the disc and the player. Try the disc in another computer.
Jul 08, 2009 | Dell Dimension XPS 400 PC Desktop
Cd/dvd drive on computer
That means defective lens.
Try first using a dvd lens cleaner. If that does not work, the DVD must be taken apart to access the lens pickup directly and cleaning it with isopropyl alcohol and cotton.
Dec 29, 2008 | Computers & Internet
Cd/DVD drive has stopped working
ur dvd drive lanse has been week u have to change the lanse
Aug 04, 2008 | Computers & Internet
Samsung x15 cd/dvd prob
Click start, run, type regedit
Navigate to this registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\
Delete the "UpperFilters" and "LowerFilters" entries.
If you have more than one key with that number, use the first one.
Oct 12, 2007 | Samsung X15 Notebook
Computers & Internet Logo
65 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
