Question about Brother GX-6750 Typewriter
The correction tape spool came off. When I tried to put it back on the return now goes to the goes all the way to the left and makes a terrible noise
    Brigadier General:
  • 3,513 Answers
I think while installig it you might have done some thing wrong. Please verify the steps with the articles bellow:
http://www.ehow.com/how_6805904_install-correction-tape-typewriter.html
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Oct 03, 2010
How to install correctronic ribbon
Open top cover, small correction tape orange or yellow lift off is kind of tricky, left side goes on small spool holder feeding off the top and going around front of print wheel. by the way relaase the printwheel so it pivots back toward you, eaiser to see, correct tape goes in front of wheel and pivots very similar to left side. Correction tape has good side and bad side good side a matte finish should face away from you, this is the correction. Regular riboon just lifts up reom the front and snaps back in place. two little plastic tabs on back of ribbon case fits in two little holes in carrier. Hop this helps real hard to describe.just works...
Sep 29, 2013 | Brother Gx-8250 Correctronic Electronic...
How to correctly install the correction tape in a smith corona electric typewriter SD770
you have to turn the spool with the knob untill there is tension on the tape or it won't stay in place
Nov 08, 2011 | Smith Corona Wordsmith 100 Typewriter
How do I install a new correction ribbon?
the spool with the new tape goes on the left side of the carrier, with the teeth pointed in. then the tape goes in the guides in the back of the black ribbon plate, and behind the two metal fingers that stick up in front of the card holder. there is a flat spot on the far right and left of the ribbon plate, that the tape fits in., then just put the other spool (take up spool) on the post on the right side of the carrier. put the ribbon back on
Feb 22, 2011 | Brother GX-6750 Typewriter
I installed new correction tape, but there's too much play in it. It keeps unravelling. I have no idea how to tighten it up. When I turn the take-up spool, it just unravels it more without tightening...
Verify that you have installed the proper correction tape. The types of tape that can be used with this system are: Item 1030 - Correctable Film Ribbon, 1230 - Correctable Film Ribbon 2pack, 1031 - Multi Strike Ribbon, 1032 - Nylon Ribbon, 3010 - Lift-off correction tapes (to be used with 1030 and 1230 ribbons), 4010 Cover-up Correction tape (to be used with 1031 and 1032 ribbons).
Make sure that the correction tape is installed properly. Pass the tape through the left guide, behind the ribbon guide and out through the right guide. The rough side of the tape should face the platen. Attach the feeder spool to the pin on the left. Attach the take up spool to the pin on the right. Turn the take up spool counter clockwise until a small amount of tape has wound around it. Replace the cassette ribbon and close the case cover. Press [CODE] + [RESET] to move the carrier to the previous position.
Dec 27, 2010 | Brother ML-100 Typewriter
How do I put lift off tape in my typewriter olivetti ET compact 60? Do you know which of the two yellow rings (the coged or the smooth) with the tape that must be in which side (left and right)?
Can't picture your machine but if you lift the cover and hit correct key a few times, you'll see the side that drives the tape moving. The "empty" spool will go on that side. Make sure the flat, not shiny, side goes towards the roller.
Dec 27, 2010 | Olivetti Office Equipment & Supplies
How to change the correction tape?
Changing the Correction Tape
1) Move the print carrier to the center of the platen using the SPACE or BS key.
2) To replace the correction tape, lift out the typing ribbon cassette (see Changing The Ribbon Cassette) and remove the two spools of the lift off tape by pulling them outwards.
3) Place the empty spool of new tape on the left pin so that the tape winds clockwise. Place the tape around the left guide. Pull the tape around the right
guide and place the loaded spool on the right pin so that the tape unwinds counter-clockwise.
Note: Make sure the sticky side of the tape is facing the platen.
4) Manually turn the left-hand spool in the clockwise direction, tightening the tape until resistance is felt.
5) Replace the typing ribbon cassette.
6) Press the CODE + = (SETTING) key.
Changing the Ribbon Cassette
2) Hold the ribbon cassette on both sides and lift up the front portion (where the ribbon is exposed) to remove the cassette.
3) To insert a new cassette, place the back end of the cassette on the cassette
holder on the carrier and gently press down on the front of the cassette unit it clicks into place.
4) Turn the ribbon feed knob counter-clockwise again to take up any slack in the ribbon.
5) Presss the CODE + = (SETTING) key.
Good Luck!
Oct 13, 2010 | Smith Corona Wordsmith 100 Typewriter
This is soooo lame but I cant remember how to put the correction tape in.... :~)
As you face the machine, the full spool goes on the left side of the printwheel carriage and the takeup (empty) spool goes on the right. Be sure that the shiny side of the lift off tape faces AWAY for the paper. The matte side is what does the lifting.
Hope this helps.
Apr 17, 2009 | Brother Office Equipment & Supplies
I do not know how to load the correction tape...can you help me?
the easiest fix, is to take the machine to a repair shop that sells corr. tapes and ask them to install it. watch how it's done. look in the yellow pages. if you can't find a shop close, - - - first, take the ribbon off, then you put the supply side on the post on the left of the printhead. above the tape and right in front of the cardholder there is a guide for the tape that is black and has 2 fingers pointing to the left. turn the tape so that the part that is facing down as it comes off the spool is facing to the left, put he tape in the guide, between the two metal fingers and the card holder, then into the black guide on the right side and then put the take up spool on the post and turn to take up the slack. put the ribbon back on
Jan 05, 2009 | Brother GX-6750 Typewriter
PUT THE CORRECTION TAPE ON CORRECTLY
First, remove the ribbon. Now look at the left side of the printhead. (thats the unit that moves back and forth) You will notice that, above the spindel that you put the correction tape on, and towards the platen, on the black plastic, there is a recessed flat place about the width of the correction tape with slight serrations in it. This is the guide for the corr. tape. There is one like this on the right side also.
Put the corr. tape on the spindle, keeping slight tension on the tape, give it a 1/2 turn so the underside (dull) side is facing to the left, and put it in the guide. Then you put the tape behind the two metal "fingers" that are sticking up in front of the printwheel, and then into the guide on the right side. Then put the other corr. tape spool on the post on the right side, and turn it until the red "leader" on the tape is past the middle of the printwheel. The dull side of the corr. tape is the side that does the corrections, so make sure that side is facing towards the platen. Make sure the ribbon goes behind the metal fingers also. The tape and the ribbon should both be between the fingers and the metal cardholder.
Oct 17, 2008 | Brother SX-4000 Typewriter
Correction tape
To replace the correction tape:
1) use [SPACE BAR] or <<-¦ to move the carrier to the centre of the platen
2) open the top cover
3) remove the cassette ribbon (if installed)
4) pull off both spools, pressing against the correction tape with your thumbs. Bring it back to a position parallel with the platen and lift it up and out.
5) Pass the new tape through the left guide, behind the ribbon guide, and out thropugh the right guide. The rough (stick) side of the tape should face the platen.
6) Attach the feeder spool to the pin on the left
7) Attach the take-up spool to the pin on the right
8) Turn the take-up spool counter-clockwise until a small amount of white tape has wound around it
9) Replace the cassette ribbon and close the top cover
10) Press 'spider web' key +// to move the carrier to the previous position.
Hope this helps.
Regards TC
Jul 16, 2008 | Brother GX-6750 Typewriter
Brother GX-6750 Typewriter Logo
22 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
