Hi
actually i installed a application from installer of iphone called "customize".
after installing this application my phone is showing the apple icon and not getting on........what to do now???
my iphone is not switching on...................it shows only the apple icon....please helpmy iphone is not switching on...................it shows only the apple icon....please help
iphone is not switching on connecting to the computer it does not show iphone icon on the left side of the itunesiphone is not switching on connecting to the computer it does not show iphone icon on the left side of the itunes
AnonymousJan 06, 2009
my iphone does not switch on, the apple icon stays on, it does not connect to my computer. PLZ help!my iphone does not switch on, the apple icon stays on, it does not connect to my computer. PLZ help!
AnonymousMar 28, 2014
suddenly all my applications are not recognized. i press the icons and write "application is not installed on your phone. not even the icon of play store is not working"suddenly all my applications are not recognized. i press the icons and write "application is not installed on your phone. not even the icon of play store is not working"
You can't post conmments that contain an email address.
Restore frm itunes then unlok if not using at&t sim by software called i liberty,fr the software search on net or contact me on [email protected] then u cn use ur normal iphone
Problem May be #1: Actually the support for Windows XP has been ended from Microsoft, and on the other side you are trying to install Earth, which is updated many times after Windows XP. That's why Windows XP could not install it.
Problem May be #2: Check your hardware properly. All capacitors and insulators. RAMs, Hard-Disk, bad sectors, etc.... These also cause any software lose its action.
Before we get started, you'll want to disable the iTunes helper application that may get in the way of the installation. Make sure iTunes is not running, then open OS X's Activity Monitor in the Utilities folder of the Applications folder. Search for or scroll down to iTunes Helper, select it, and then click on the Quit Process button in the top left of the screen. You'll also need your iPhone, your data cable, and a Wi-Fi connection to the Internet. Apple doesn't support the installation of third-party applications on the iPhone, but enterprising developers have created a program called AppTapp that will let you install including chat clients, games, and other pieces of software - including those that are needed to unlock your iPhone Download and install AppTapp. Once you run the program, the first thing it will do is ask what version of the firmware you're running. If you've just updated your iPhone, you probably have Firmware 1.0.2-select that and click on Continue. Assuming all goes well, you should get a screen that begins with the words: "Congratulations! You have successfully installed AppTapp Installer onto your iPhone." You should then find a new application on the iPhone's home screen called Installer. The next instructions will require downloading some applications from the Internet to your iPhone-so make sure your iPhone is connected to a WiFi network. Launch the Installer program, and you'll see a long list of various applications that you can install. Scroll down, then select and install-in order-Community Sources, BSD Subsystem and OpenSSH. NOW PERFORM THE GSM UNLOCK First, download and install Unlock.app, lockdownd, and Cyberduck. Then go to the iPhone's General settings and set Auto-Lock to Never. Next, you'll need to get your iPhone's IP address on your local network. To do this, go to Settings: Wi-Fi and click on the blue arrow next to the network that you're connected too. Write down the IP address, as you'll need it for later. Now, open Cyberduck and click on the Open Connection button in the top left of the window. In the connection window, type the IP address that you just noted. Make sure that SFTP (SSH Secure File Transfer) is selected, and that you are using Port 22. For the username, type root, with the password of dottie.
Once connected, navigate from /private/var/root to the main directory by choosing the / item. Next, navigate to /usr/libexec and drag the file named lockdownd (the one you downloaded earlier) into it. It will ask if you want to overwrite the existing file-click on Continue to do so.
Now, in Cyberduck, drag the Unlock file from the Mac's desktop into the /Applications folder at the top of the main window. Once that's done, turn off your iPhone and remove the SIM card, then turn your iPhone back on and choose the application on your iPhone called Unlock
Afterwards,there should be a white screen that says "All files found. Ready to go. Press Start." Once you press start, it will take about 20 minutes for all the files to install.
The progress messages will appear at the top of the screen as it progress-once you see "Completed" then you're finished. Insert a new SIM card of your choosing into your iPhone. Congratulations, you've just unlocked your iPhone!
I believe this problem persists after you have jailbreak Your iphone . Now since you have done it the next step Is to install a Ripdev application from the installer module. After You have installed it successfully then you go to your iphone settings. Here you will see Ripdev application installed then touch it to expand it more.Then here you will see Ripdev products, again you touch it to expand and then you will notice a title which says Licenses there you have to touch the Kate application and after that you have to touch "purchase Authorization code" or for trail bases just touch the application which says “Ask for Trial License” after that go to the iphone module that is the key pad and you will see its working fine. In short after jailbreaking and installing Rip Dev you have to purchase That application to get your keypad working. With this 100% your problem will be solved.
its easy if ur iphone is a original one produced by apple then sonnect it wid itunes and restore it after that itll only support at&t sims and uve to unlok it wid iliberty software for using wid other sims u cn contact me fr dat software at [email protected] or search on d net and den use any other sim ans then ull get an icon called installer in ur phone by selecting the option of installing installer on iphone from the iliberty menu and then u can download java and its updates from installer via a wifi connection..................simple
well, as I suppose that you have an unblocked iphone, you should have a blue icon which is installer, otherwise know as the application that allow to install third part software in your iphone.
in the list of application, you will find one called isim.
hi..even i installed this, along with this,i had installed few other packages from installer. i guess it requires an application, thru which we can read thisbook. that application needto be installed. if u come to know how it shouldbe done,better tel me.thanks.
