Question about HP DesignJet 9000 InkJet Printer
Error 1240 hp9000 - HP DesignJet 9000 InkJet Printer
    Genius:
  • 1,089 Answers
Error code 1240. Printhead Number 1 (Black ink supply station has problems)
Posted on Oct 04, 2010
How do I fix? Designjet HP9000 error 1701
System Error 1700: Servo Motor Error
Description:
The Paper-Axis or the Scan-Axis Motor moves the Carriage, but the input from the Linear Encoder Sensor does not change
The easy thing to do is to check the "encoder strip". It's a metal strip about 1/4" high. It runs right to left behind the carriage assembly. Shine a flashlight on it and see if it looks damaged. If its dirty clean it with a slightly damp cloth(water or alcohol will work). Do it with power off. Make sure the carriage moves freely from one end to the other. If the carriage is binding or won't move at all, check the carriage belt for tears or shredding. If you can't SEE anything wrong it probably is the time to call in a trained tech.
The E0800 is a power supply error. You'll need a tech for that too.
Mar 23, 2015 | HP DesignJet 9000 InkJet Printer
Tip
Garmin Nuvi 1240 Favorites Backup and Restoration Procedure Models: Nuvi 1200,...
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Would you like to back up a copy of your Garmin Nuvi 1240 Favorites and Waypoints?
Backup and Restoration Procedure for Favorites:
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
I hope that helps.
______________________________________
Garmin Nuvi 1240 Manual Download
Garmin Nuvi 1240 QuickStart Download
Garmin Nuvi 1240 Webupdate
Garmin Nuvi 1240 Hard Reset
on May 15, 2010 | GPS
Tip
Download Garmin Nuvi 1240 Quickstart Manual
Have you lost your Owner's Quickstart Manual for your Garmin Nuvi 1240 GPS?
Would you like a digital copy of the Garmin Nuvi 1240 Quickstart Users Guide for easy searching of terms and quick reference?
The Nuvi 1240 Quickstart manual is available free in pdf format, just follow the photo link below:
I hope that helps.
________________________________________________
TENGO UN EQUIPO HP9000 Y TENGO EL ERROR 1290, QUE SIGNIFICA ESTE CODIGO SALUDOS,
Trate este enlace.Lo llevara a que baje el diagnostico HP.Luego de bajarlo lo habre y empezara el diagnostico y revelara algun problema si alguno.
Vuelva aca si necesita mas ayuda.no olvide postear algun comentario o un thumbs up,garcias.
Nov 17, 2010 | HP DesignJet 9000 InkJet Printer
HL-1240, the alarm light is on, what would be the reasons?
the first alarm light (at the very top) indicate the toner life ends the second light(middle) indicate the drum life ends and the third is for paper jam or print error
Sep 18, 2009 | Brother HL 1240 Printer
Tip
Download Garmin Nuvi 1240 Manual
Have you lost your Owner's Manual for your Garmin Nuvi 1240 GPS?
Would you like a digital copy of the Garmin Nuvi 1240 Users Guide for easy searching of terms and quick reference?
The Nuvi 1240 manual is available free in pdf format, just follow the photo link below:
I hope that helps.
We have a hp9000 and I am trying to connect into a hp9000 rp5450 how is this done?
This machine is running Unix, specifically some flavor of HP-UX. How to connect to it really depends on how much it is locked down for security. Serial terminal session, telnet, and ssh are all options.
The easiest thing is to hook up a standard vga display, keyboard, and mouse and connect this way. If you don't have a root login and password you will be very limited in what you can do though.
Jun 03, 2009 | HP 9000 K360 (A5166A) Server
Check Cables. Check Scanner Lock. Cycle Power.
the problem is the cable in the scanner's mainboard
Sep 15, 2008 | Office Equipment & Supplies
Color calibration: HP9000 & Photosmart 7460
Had a similar problem --Same Laptop but with epson printer--Found I had to manually go to Printer and reset "Advanced Settings". Don't know if you can do this on your printer. Hope So!
Aug 04, 2008 | HP Pavilion dv9000z Notebook
Error message and won't print
change the USB cable
tray to re install the usb port from device manager
Jun 29, 2008 | Brother HL 1240 Printer
HP DesignJet 9000 InkJet Printer Logo
220 people viewed this question
Seeker5211
Seeker5211
