Question about Refrigerators
Could you please tell me why the ge refrigerator, bottom freezer i have freezes by the fan in between the freezer and refrig? ty is this a easy fix? do I replace the fan or refrig? did GE have a recall or bad design on this? please let me know, ty
  • Refrigerators Master
  • 2,330 Answers
The drain is plugged,when it goes into defrost the ice melts on the evap coil,it should go down the drain line to the bottom where the compressor is and evaporate from the heat but your drain is blocked and the water is sitting there and freezing up.you have to take up the fridge floor and get at the evap coil and first melt out all the ice with a hair dryer,if you have a shop vac you can vac up the water as it's melting,watch out with the heat from the hair dryer,you can damage the blade on the fan and damage the styrofoam,don't keep the heat in one spot to long and try not to open the drain hole till last,if you do and some of the water goes down the drain the pan on the bottom will overflow from to much water,once you melt out all the ice you have to clear out the drain line,i use a steamer,it cuts through whatever is in the line,also on some of the machines if you look at the back of the fridge there's a plastic trap that you can remove and clean out that the melted water runs through,i use a plastic wire tie to snake through it but your machine might not have this,some guys say a turkey baster works to blow through the line but whatever you use when you're done pour hot water into the drain,if it goes down then you know the drain is clear.let me know what you find
Posted on Oct 03, 2010
  • Sal DeAngelo Oct 03, 2010
    also on some models the coil is behind the back wall of the freezer,next time send model number,if the evap coil is frozen and the fridge is warm you have a defrost problem,you have a bad heater,defrost thermostat,sensor or computer board,you'll have to shut down the machine, melt out all the ice and with a meter read out the heater and the t-stat,also another common problem with bottom mounts is that the door gets left open and the air ducts freeze up and you'll have ice,check the top of the door for ice,near the lite cover on the ceiling and you'll see frozen water droplets on the shelves and food,what you wrote described all of the above,without seeing it it's hard to say,if you tell me what you find and send model number i could help you out better
Vegetables in crisper are frozen, as well as liquids in bottom 1/2 of fridge door. The fridge & freezer temp controls won't adjust to our settings. Also, we're getting ice, but no water will dispense.
The freezer cools the refrigerator, so you actually get very cold air passing from the freezer to the refrig. The air from the freezer enters the refrig on the top and falls to the bottom where it is drawn back into the freezer. The temperature of the refrig is regulated by a thermostat and a fan that runs when the thermostat calls for cooling. If the refrig thermostat is faulty and causes the fan to run more than it should, there will be a freezing problem in the refrig at the bottom because cold air falls and warm air rises. If the refrig is thermostat is calling for cooling constantly, this will take more cold air from the freezer than is normal. Your freezer temp might be higher than normal and the refrig will be colder then desired. If the fan from the freezer is running constantly I would suspect a bad refrig thermostat.
May 06, 2015 | Refrigerators
Items in refrig are freezing when they're not supposed to.
thermostat has failed i'd say..its not turning off at the requested temp.
Jul 24, 2010 | GE Profile PGSS5PJXSS Stainless Steel...
The top of the freezer compartment does not freeze ice, but the bottom does. The top of the refrigerator compartment is not cold, but the bottom drawers are freezing.
It sounds like the fan in the freezer is not working , letting the cold air sink , and going into the refrig section from the bottom . Replaceing just the main control board may get the fan going again , however , replaceing both ( possible shorted fan motor will cause the new board to malfunction again ) would be the better suggestion .
Mar 04, 2010 | GE GSS22KGPBB / GSS22KGPWW / GSS22KGPCC...
Frozen water reservoir in GE Eterna refrig model GESL25XGRBS-SS...the water dispenser doesn't work, although the ice dispenser is just fine. We turned off refrig for a few hours and the water dispenser...
According to factory experts, the water line is freezing in the door. There is no easy or cheap solution...they can replace the door for $300 is what I was told. The line is routed in such a way that it is not insulated enough from the cold of the freezer. Take off the bottom fan grill in front, take water line apart and cycle the water. It will pump out but not go through door. Buy a new door or go to the faucet.
Dec 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE fridge is warm and broken; the freezer is cold though.
Air circulation problem. Evaporator fan in freezer moves some air to refrig. Either fan is not working or air passages are blocked with ice. If ice found, then a defrost component failure has occurred. Fix what you find.
Sep 19, 2009 | GE Profile PDS20MFS Bottom Freezer...
Our ge refrig runs constantly,freezer is freezing but the refrig is not cooling. I cleaned the dust and dirt out of the bottom and back of refrig.
See if the fan in side the frig is working It mite be on the freezer side If the fan is not working it will not blow the cold air in to the frig side
Jul 12, 2009 | Refrigerators
Slow condenser and evaporator fans on SDL20KCSABS
Newer GE refrigerators use variable speed DC fan motors to improve energy efficiency. Fan speed is determined by the electronic control board. Your refrig is working as designed.
Please don't rate solution, as anything but a Fix-Ya lowers my overall score. Thanks.
Mar 03, 2009 | GE Energy Star SDL20KCSBS Bottom Freezer...
Amana Refrigerator
Is fan in freezer running? If not it is bad and needs replacing. Please leave feedback.
Nov 27, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Ge Profile refrigerator
Yes your refrig is not defrosting automatically. You can start by removing the shelves in the freezer than removing the rear panel (the panel that is frosted half way). Use hair dryer to defrost ice from coil. This will restore your refrig temporarily. Your refrig has a pretty advance defrost system and is not easy to test. If you have a meter (volt-ohmmeter) i can help with diagnosis.
Oct 10, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
96 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
