Question about Toshiba Satellite P105-S9337 Notebook
Screen went blank. That was my initial problem. Upon restart, it would operate fine for a couple hours, then die again. The duration of operation rapidly became shorter and shorter. The laptop now will not start up at all. I've tried Safe Mode when I could maintain a display for a few minutes, and I've tried to run the Start-up diagnostic. Nothing worked. I purchased & installed a new battery, no luck. I can turn power on & off down using the power button, but I no longer get a display on the monitor.
    Top Expert:
  • Toshiba Master
  • 50,033 Answers
Indicates a dead hard drive
take it to a computer repair shop for a proper diagnosis
Posted on May 15, 2017
sandrew
  • 2961 Answers
SOURCE: can't start laptop
Try booting (f8) again but instead of safe mode try 'Last known good configuration' Your Boot.ini is probably corrupt or your HDD is faulty and has bad sectors. If this is a no go, then you will need your windows cd to either repair your operating system; or a complete re install would be a better solution. As long as you can enter then bios (either DEL or F2 on startup) and enable your cd/dvd drive as the first boot device. Insert your cd and press enter to boot from cd and either press 'R' for repair or 'Enter' for complete install.
Posted on Dec 31, 2006
  • 43 Answers
SOURCE: Toshiba satellite A100 Monitor problem
LCD issue it needs repair..call tosh if your laptop is still in warranty
Posted on Feb 02, 2008
SOURCE: Blank Laptop Screen
sorry about posting for trouble.
similar blank screen problem with Toshiba satlite notebook but I can see the desktop with no light from lcd. so if you just see the screen it's black untill you see very close to the monitor. When it boots i can see the normal screen and it goes away blank. Any suggestion?
Posted on Mar 31, 2008
mnelsonix
  • 58 Answers
SOURCE: toshiba satilite P100...wont turn of
Try these:
1. Can you plug something else besides your laptop into the outlet...verify you have power?
2. Is there a light on your AC adapter...when you plug it in?
3. Try removing your battery and plugging it in, and verify that your AC adapter is working (somehow, if it has no indicator light)
4. Then unplug it, put the battery back in and see if it will start.
Let us know what happens after you try these.
Posted on Apr 12, 2009
leecom72
  • 4806 Answers
SOURCE: cannot start up the laptop
Hi there.
That really quick flash of a blue screen is the blue screen of death and there is a possibility that the error could be memory related.
What you have to do is remove and clean the system memory and the slots the memory goes into.
Take out the battery and the AC power (if attached)
The memory will be located behind a panel underneath the laptop, unscrew the panel unclip the memory, clean the brass contacts and the slots with a clean, dry, soft paintbrush, then reseat the memory making sure it clips into place, replace the memory cover and reboot the laptop, see if it lets you into windows.
Please post back with the results and more help if needed, good luck and thanks for using FixYa!!
Posted on May 20, 2009
Black and White Horizontal Lines
Sounds like the graphics card just died. You will need that repaired.
Apr 15, 2014 | Apple iMac Computers & Internet
Monitor works sometimes and sometimes not
Reboot pc until you have a picture, then try updating the drivers for the monitor and your gpu if applicable, outdated drivers can cause erratic and intermittent behavior. Navigation to drivers access varies slightly based on operating system.
Sep 02, 2017 | Computers & Internet
When powering on dell laptop xps the screen says
It sounds like your operating system file has been corrupt. You might need to reinstall your operating system. If you have a trust worthy technician that can pull your data off of the hard drive before you reinstall the os system. Hope this helps.
Aug 27, 2012 | Dell Computers & Internet
I recently downloaded two optional updates for Startup Windows 7 onto my ASUS EeePC 1005. Following download I was requested to restart my PC to complete the installation. Upon restart, I had no display...
Try starting the PC in safe mode (press F8 as it starts) and then restore your PC to a date before you installed the updates.If that fails you must use your windows 7 disk to repair the system or just install it again.....
Nov 04, 2010 | Computers & Internet
Screen went blank. That was my initial problem. Upon restart, it would operate fine for a couple hours, then die again. The duration of operation rapidly became shorter and shorter. The laptop now will...
you are in luck as you have a video card that is replacable .. this is your video card : PCI-Express™ x16 graphics subsystem, featuring:
o
NVIDIA® GeForce™ Go 7900 GS with 256MB GDDR3
SDRAM VRAM
NVIDIA GeForce Go 7900 GS <<<<< go to web site and buy a new video card because if everything else works it should be your video card has died
May 15, 2017 | Toshiba Satellite P105-S9337 Notebook
My computer restart again and again and hanging problem also and after restarting my monitor screen going on blue .
I know exactly what your problem is. Your computer is not going through the POST because it sounds like the RAM for your computer has went out and died. You need to find out what kind of RAM your computer has and write it down. That is why you get the blue screen of death cause your RAM is faulty and needs to be replaced in order to initialize POST and boot into your operating system so that you can use your PC. If you need further help don't hesitate to ask. Thanks!
Jun 08, 2009 | Intel D865GBF Motherboard
Computer keeps restarting
Escape means that the changes were not saved.
Concerning the hd, it is possible to download a tool to verify its integrity. You can choose the version (bootable would be the best).
http://www.tacktech.com/display.cfm?ttid=287#maxtor
And for the memory stick, you could use the memtest86+ to verify if it is not the problem. I bought 2 memory sticks of 1 Gb each and there was one in problem. I had to test them individually, and found out the one was not good, after 8 hours of test.
http://www.memtest.org/#downiso
Again, a bootable version is better.
Sep 04, 2008 | E-Machines eMachines Desktop PC
Different Problems
This is Phobos92.
It turned into the red ring of death. So no further help needed.
Feb 26, 2008 | Microsoft Xbox 360 Console
Toshiba Satellite P105-S9337 Notebook Logo
41 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
