Question about Hitachi EC89 4 Gallon Twin Stack Air Compressor
Trips thermal overload. power source ok. oil ok
    President:
  • Hitachi Master
  • 1,383 Answers
Several things to check. Amp draw to be within number on plate, if amp draw not correct check capacitor, should be within 5% of rating on cap.. If amp draw about right and cap reads good suspect faulty breaker. If amp draw high and cap. good check for leak at in-tank check valve. With pressure in tank remove hose at check valve spray soapy water. If check valve good, suspect reed valves leaking. If reeds are leaking the compressor will take longer than normal to fill and the discharge tube/air will get very hot. It is recommended to note the amount of time it takes to fill tank when unit is new and compare this as unit wears. Length of time to fill is an indication of how well unit is working. A combination of leaky valves and leaking fittings as well as leaking checkvalve will cause motor to overheat.
Posted on Oct 04, 2010
Testimonial: "best explanation I could have hoped for"
  • Freddie Johnson Apr 22, 2011
    The early Hitachi EC89's came with a 40 microfarad capacitor to start the motor. This is insufficient when its cold, or the compressor hasn't been used in a while, or the compressor is still in its break-in period. Hitachi later changed it to a 60 microfarad capacitor, as it now is with the currently offered EC89's, which provides reliable and consistent starts of the electric motor. FYI: the capacitor is the white tube looking thing just under the black cover on the top side of the compressor. You can just see it without disassembling anything if you peek under the black cover to the best of your ability. To get at it you need to remove the black plastic cover. To do that, it takes about 20 minutes of disassembly time and a few tools: unplug the compressor, disconnect at least one end of the copper pressure tube (the tube that runs from the pump to the tank), remove the four main bolts that hold the black steel compressor base to the main frame, now you can get at the four phillips head screws that hold the plastic cover on, loosen (but don't remove) these four phillips head screws, then pop off the plastic cover (there are anti-vibration side locks that need to be disengaged- by using a long flat head screwdriver from the inside- to pry them and pop them off from the inside). Once the black cover is loose, you will either have to reach in and disconnect the two wires to the breaker, or unthread the breaker's little hex nut and separate it from the black cover. Replacing the 40 microfarad capacitor with a 60 microfarad capacitor (available at your local electric motor rebuilder- yellow pages) will resolve the problem of the weak starting motor that pops the breaker before the motor gets a chance to start rotating. Shame on Hitachi for not publishing this fix themselves.
    Scholar:
  • 127 Answers
Same thing happened to my EC89....Unit would come on fine for 10-15 seconds then the reset button would trip! motor compressed air fine and all else worked great. But I Would have to stop working, walk back over to the compressor and reset the protection overload button on the compressor. It got "VERY ANNOYING" to say the least!! I ended up bypassing the reset button (I took the two wires off the back of the reset button and put them together) Unit worked great after that! so I ordered a new reset button for $8.00 and re installed it once it came in...WORKS GREAT NOW....I did not want to just eliminate the reset button permanently because if there was ever another issue with the compressor ( low oil, bad piston ring,low amp draw, etc.) it would burn up the motor vrs tripping the thermal protection button.....I do not suggest running it full time without the thermal protection button....but only to test for a bad reset button! hopes this helps someone with the same "reset button trip" issue.....
Posted on Nov 24, 2012
Electric dryer won't heat
Thermal overload cutout tripped or is defective and needs replaced. Look for a red reset button near the heater element on the thermal overload. If no reset button, replace the thermal overload cutout. The timer itself could be defective, which will prevent power going to the heater element.
Sep 14, 2015 | Roper Dryers
Hayward RS2000 suddenly stops. Motor housing is extremely hot and has a burnt smell. Thermal overload going bad?
it sounds like there may be a short in the pump. this will cause it to overheat and trip the thermal overload. it may be time for a new pump as this is usually cheaper than fixing it
Sep 13, 2013 | Hayward Sp1580x15 Power Flo Lx 1.5hp...
Tip-over switch location
It will be inline with the power entering, meaning probably by the thermal overload, it may not be equipped with that , but rely on a thermal overload as the oil units surface temps are no way near the point of combustion if it does touch aything as curtains or rugs etc.
Feb 24, 2012 | Honeywell HZ-709 Oil Filled Radiator...
I have a makita MAC2400 2.5 HP that suddenly stoped It's almost brand new but does get plenty use, the oil level was very low or may have just ran out. I added more oil but will not come on, what is the...
Hi and welcome to FixYa, I am Kelly
Remove the rear cover Item 33 this link:
http://www.ereplacementparts.com/makita-mac2400-25hp-1720rpm-air-compressor-parts-c-97_1547_7559.html
Gently start rocking the fan GENTLY back and forth by gripping it in the large center area and see if it will rotate. If you ran it completely out of oil; the piston, piston rings or rod end bearings will seize up. If you can not rotate it by hand and your sure it has locked up... you are going to have to overhaul the pump or replace it. The link above is a good source for parts.
Before considering an overhaul... read out the motor windings after the pressure switch to see if the motor windings are open or read a resitance value under 480 Ohms.
Depending on the motor pump used most of them have thermal overloads that will self reset when the unit cools off. It should self reset in less than 15 minutes if there is one. Ones without a thermal overload end up cooking the motor windings or tripping the house circuit CB if they run out of oil.
Thanks for choosing FixYa,
Kelly
Mar 31, 2011 | Makita MAC5200 Electric Powered Air...
Shower will not heat up. Creda Aqua 9.5e - was working fine but now no red neon indicator and cold water only. I have checked power going into unit and is ok.
May have a tripped thermal overload or blown fuse. Some overloads reset automatically but some will have a red button to reset it with. Some have to be replaced.
May 02, 2010 | Water Heaters
On and off switch does not work
do you mean that the switch is broken or just nothing happens when you turn on the power ... if thats the case then check the line cord for damage .. often the wires break right at the plug or connector .. it will feel more flexible at the point of damage than other areas of the wire... if the cord and connector are ok and power is ok at the outlet .. then you probably have a tripped thermal overload fuse inside the machine where the heating element is located .. this trips perminatly if it ever gets overheated .. that can sometimes be caused by running it without any oil inside .. or sometimes the thermal fuse just goes bad (actually often) ... this is usually easily repaired by a shop that speciallizes in this sort of thing .. the part however is either crimped or soldered in so not a customer repairable part (unless you happen to be a TV repairman or Ham radio person)
Oct 04, 2009 | Bravetti Kitchen Appliances - Others
Is it normal for the pump to turn off and then turn back on?
No, unless you are switching it. This sounds like a thermal overload problem. If the motor is fan cooled, it may be blocked or clogged with grass. If the motor has become wet inside this can also trip overload. That may be a shock hazard, so the source of water must be found and/or the motor must be replaced.
Jun 24, 2009 | Pool & Spa
WIREING IN NEW IEC CONTACTOR AND THERMAL OVERLOAD
I CAN PROBABLY DRAW YOU A DIAGRAM BUT SEE IF YOU CAN UNDERSTAND THIS FIRST. ASSUMING YOUR STARTER COIL REQUIRES THE SAME VOLTAGE OF YOUR COMPRESSOR. 230V MOTOR = 230V COIL ON STARTER. YOU HAVE 2 OR 3 HOT WIRES ATTACHING TO THE TOP OF THE STARTER ( 1 PHASE OR 3 PHASE). TAKE A JUMPER WIRE INSERTED UNDER THE SAME LUG AS 1 HOT LEG AND GO STAIGHT TO 1 SIDE OF THE COIL. THEN TAKE ANOTHER JUMPER WIRE FROM ANOTHER HOT LUG - PASS THRU THE TRIP PACK AT THE BOTTOM OF THE STARTER ( IN AND OUT) THEN GO TO PRESSURE SWITCH. TAKE THE OTHER PRESSURE SWITCH WIRE TO THE LOW OIL SWITCH. TAKE THE OTHER LOW OIL WIRE TO THE OTHER SIDE OF THE STARTER COIL. THEREFORE YOU WILL HAVE ONE SIDE OF THE COIL HOT ALL THE TIME AND WAITING FOR THE OTHER SIDE TO GET HOT. AS LONG THE OTHER LONGER CIRCUIT IS A COMPLETE CIRCUIT IT WILL WORK - IN A SERIES THE TRIP PACK SAYS OK, THEN THE PRESSURE SWITCH SAYS OK, THEN THE LOW OIL SWITCH SAYS OK AND THEN VOLTAGE GOES TO COIL AND PULLS THE STARTER IN. IF THIS IS TOO CONFUSING SEND ME AN EMAIL AND HOPEFULLY A PIC OF YOUR NEW STARTER TO JBRIDGERS@CA-EQUIP.COM AND I'LL TRY TO HELP YOU FURTHER. HOPE THIS HELPS.
Mar 30, 2009 | Champion International Air Tools &...
Motor will not start
I had the same problem and the solution was to manually press the thermal overload button. The button is located under the tool box next the motor head. I do not believe I tripped the thermal overload during use, but I suppose anything is possible. I’ve been using the compressor in sub 40 deg F. temperatures. I found the following in the Owner’s Manual, but had to look at the part manual to locate the switch.
MOTOR THERMAL OVERLOAD
PROTECTOR: The electric motor
has a manual thermal overload
protector. If the motor overheats
for any reason, the thermal
overload protector will shut off
the motor. Turn pressure switch
to the “off” position and wait for
unit to cool before pushing the
reset button and restarting the
compressor.
Good Luck!
Dec 14, 2008 | Makita MAC5200 Electric Powered Air...
Fantom Cyclone XT Vacuum Cleaner
Here is the owners manual which goes over some troubleshooting problems.
http://www.fantom.com/fantom/manuals/Cyclone.pdf
At first I would think it was the thermal overload, which is covered in the manual. But I would guess that you have let it sit for 30 minutes to cool down and tried again and the vacuum still didn't work.
I would think you may have one of four problems.
1. Your thermal overload was tripped and is stuck and will need replaced.
2. You have a clog in your vacuum lines or the brush roller is froze, which keeps causing the thermal overload to trip.
3. Your power cord has a short, which would need replaced.
4. Your power switch is bad, which would need replaced.
Out of these 4 possible problems I would say the only one you could fix on your own would be problem #2. Make sure the vacuum is unplugged and take the brush roller off and clean it, make sure it moves free. Check your vacuum lines to make sure you do not have a clog, other wise the motor does not get air flow to cool it down causing the thermal overload to trip. As for problem 1, 3, and 4 I would suggest taking it to a repair shop.
Hope this helps, post back.
Jul 11, 2008 | Fantom Vacums XT450K Upright Vacuum
Hitachi EC89 4 Gallon Twin Stack Air Compressor Logo
698 people viewed this question
Top Hitachi Air Tools & Compressors Experts
John Trevino
Jim Thurston
Are you a Hitachi Air Tool and Compressor Expert? Answer questions, earn points and help others
