Question about Canon Powershot A2000 IS Digital Camera
Camera indicates low battery even for fully charged battery.
I have connected my PowerShot A2000IS that was doing the same thing for me and I discovered the following:
1) The unit works fine even down to 2.5V providing the supply source (i.e. batteries can deliver 500 mA for a short burst during startup, i.e. when the camera's lens is extended). The camera draws 300mA with screen on after the initial startup current has settled. This means that the camera may not work with batteries like normal alkaline as these don't normally supply large currents, like NI-MH and NI-Cd can.
2) I found that if I lowered the voltage down to (using my bench power supply) that the low power indicator come on at just under 2.5 Vs, BUT once it has indicated low battery, turning the voltage back up to 3V didn't remove the low battery indication.
3) Finally I connected my fully charged (with combined voltage of 2.7V) Ni-Mh rechargeables (old and well used) using wires to allow me to measure their voltage and I found that when I turned on the camera the voltage dipped to 2.3V, but come up after the lens was deployed.
Conclusion and recommendations:
a) Get some new high quality Ni-Mh cells.
b) Don't use Alkaline cells (even Duracell brand might not handle it).
c) Forget Ni-Cd as terminal voltage would be at best 2.6V which doesn
Posted on Jan 23, 2011
Canon PowerShot SX110 IS Digital Camera charge fully battery after one pics show low battery sign
This is probably a battery issue and not a camera issue. Batteries with low output or low power can be due to them sitting and not being used for long periods of time. This can affect their ability to get a full charge as their "memory" is reduced regardless of what the charge light indicator displays. Even taking a battery that has been sitting for a long period and charging it to full charge, might only have limited power. Some of these can be returned to almost full capacity, but it takes multiple, repeated, alternating, charges and power deletions to rebuild the memory. In many cases, however, the battery just needs to be replaced.
Feb 10, 2013 | Canon PowerShot SX110 IS Digital Camera
I have been having this problem with my Olympus mju1040 for quite sometime. Everytime i tried to charge the battery when the battery low signal is blinking or when the screen blackout, it will be fully...
Try charging it for an hour even if it is indicating that it is already full in 10 minutes. If the battery still gets drained after a few shots, then you should change your charger.
May 22, 2011 | Olympus Stylus / mju 1040 Digital Camera
I have a low battery indication with a fully charged battery on a Sony DSC-F717. What do I do?
First, even a fully charged battery may not be working right - VERY common.
Does the camera do this on two batteries, one old and one much newer? (I say this because lithium batteries are good for about 500 charges - if you are over this, the batteries will always read weak...)
A service shop can test the camera and see if the battery is reading correctly. A service shop may allow you to try the SHOP's good battery in your camera and see if it reads right. If OK, you need a new battery.
The service shop can reload the operating data into your camera - I have fixed them this way myself.
If not, the circuit board that handles charging and batteries may run you $275 plus labour. (The board is not repairable)
Mar 22, 2010 | Sony Cyber-Shot DSC-F717 Digital Camera
Low battery indicator with new batteries
Dear friend please go in setting option on your camera and select your battery type there. after that restart your camera. The indicator will stop showing low battery. But also confirm that your new battery are fully charged. Waiting for your feedback.
Jan 30, 2010 | Pentax *ist DL Digital Camera
Camera shows low Battery and goes off even if u insert a new one
are you using NiMh rechargeable batteries?
If yes, check that they are fully charged. If that doesn't do the trick, sounds like it might be a power circuit issue. Samsung is in Secaucus, NJ
or SamsungUSA on the web
Apr 15, 2009 | Samsung Digimax A6 Digital Camera
Canon eos rebel t2 battery indicator
guido462:
new batteries - brand new? fully charged per spec?
Jan 21, 2008 | Canon EOS Rebel T2 with 28-90 lens 35mm...
Low Battery when using screen
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Oct 21, 2006 | Canon PowerShot G2 Digital Camera
Sony Cyber-shot DSC-U10 low battery indication.
possible short circuit that is draining battery at a speed. get your camera tested at some good repair shop,
Jul 02, 2006 | Sony Cyber-Shot DSC-U10 Digital Camera
Low battery indication
You have either a faulty charger, a faulty battery or a fault in your camera. I purchased 2 batteries for my Sony 505v and from new one of them kept flashing an empty battery sign right in the middle of the display. Actually it was fully charged but Sony batteries have a little circuit inside them which tell you how long the batteries will last. In my case I could continue to use the battery but put up with that flashing icon. I returned it to where I purchased it and it was replaced Immediately. Please ,next time give us a little more information as to what battery type it is and which camera it goes in. Some cameras can develop a natural short circuit over time. BMW
Canon Powershot A2000 IS Digital Camera Logo
295 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
