Question about Samsung HP-T5064 50 in. Plasma HDTV
Device code I just got a plasma screen tv and I am trying to program it to work with my cable tv remote. The device codes that they give you aren't working. I was wondering if anyone could tell me what it is? The model code is PN50A450P1DXZA
  • 558 Answers
Some older cable remotes do not have the new lcd /plasm tv codes, you should consult with some one at the cable company and see if they have a box with remote that will support your tv.
Posted on May 27, 2008
My wave cable hd dta remote will not turn offandontv...repair guy said to ask vizio
Use the following instructions and code list to program your VIZIO Universal Remote Control. Press the TV (or device) button and hold for 5 seconds until the LED flashes twice. LED will remain lit. Find the programming code for your TV (or device) in the code list and enter it using the Number Buttons.
try a universal remote and program it, from the manual.
3 Digit Universal Remote Codes For TV Codes For Universal Remotes
4 digit GE universal remote control codes with code entering instructions
http://www.remotecodelist.com/
http://cdn.vizio.com/documents/downloads/vizio-universal-remote-codes.pdf
Feb 03, 2016 | Vizio P50HDTV10A 50 in. Plasma HDTV
Sanyo 50" Plasma DP50710 Remote will not work.
Try to synchronize the remote control with an other code to your TV brand.
Jan 23, 2013 | Sanyo Televison & Video
How to get my Sony HT-CT60 Sound Bar Home Theater programmed to my GCI Cable remote?
This worked for me, but I have a Comcast Motorola DVD-R:
These are the codes for your SONY SA-CT60 Audio Device. Follow the instructions below to program your remote.
silver_with_red_ok_button-lg.gif Most likely code: 30158
Others to try: 31758, 31759
To program your Comcast remote:
  1. Turn on the TV or other device that you would like to program.
  2. Press the TV button on your remote control.
    NOTE: If you would like to program your remote control to work with a DVD Player, VCR or Audio device press the AUX button.
  3. Press and hold Setup until the red light blinks twice, then release Setup.
  4. Enter the first code for your device listed above. If you perform this procedure correctly, the red light will blink twice.
    NOTE: If you enter an invalid code, the red light will display one long blink and exit the programming mode. Repeat steps 2 to 4 with a valid code.
  5. Aim the remote control at your device and press Power once (press the Play key for devices that don't have a POWER button). If the TV turns off, make sure that the VOL+/- and Mute buttons also work. If so, you're all set!
  6. If not, repeat these steps using the next manufacturer's code (you may need to try several codes to find the one that works).
Nov 24, 2012 | Sony Audio Players & Recorders
Hi my samsung remote is damaged.I have a one for all tv universal remote & have lost the instuctions to program the remote to the tv. I need the instructions program my one for all tv remote to my...
Hello
These are the programming proceedings for a one for all universal remote control.
[1] Turn on a desired device (e.g.,VCR or
DVD player) and, if applicable, insert
media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely
before proceeding.Highlight or write down the
codes and device you wish to program before
starting step 2.
[2] On the remote control,press a device key
once (i.e., TV,PVR,DVD, CBL/SAT,AUD,or VCR).
NOTE: To program control of a cable box or
satellite receiver, press CBL/SAT once.
NOTE: To program control of a CD player or
audio receiver, press AUD once.
NOTE: To program control of a TV/VCR Combo,
press VCR once.After programming, you will be
able to control channel selection, volume, and
VCR functions.
NOTE: To program control of a TV/DVD Player
Combo, press DVD once.After programming,
you will be able to control channel selection,
volume, and DVD functions.
[3] Press and hold SET until the LED (red light)
blinks twice, then release SET.
[4] Use the Manufacturer's Codes to locate the type of device and
brand name and then enter the first fourdigit
code for your device. If performed
correctly, the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps
2 through 4 and enter the same code again.
[5] Aim the remote control at the device and
press POWER once.The device should turn
off. If it does not, repeat steps 2 through 5,
trying each code for your brand until you
find one that works.
NOTE: If the device does not have a POWER
key, press the (Play) key.
[6] Repeat steps 1 through 5 for each device you want to control.
OK.
Jul 03, 2011 | Televison & Video
My tv remote quit working. I would like the code for Daewoo TV, model No. DTQ-13P2FC to enter in another remote.
For Time Warner Cable TV Remote Codes for DAEWOO-TV's - Go to Time Warner Cable web site to PROGRAM REMOTE -- Site URL is http://www.timewarnercable.com/en/residential-home/support/pyr.html Then select TW Cable remote model. Under Control a Device -- first select type of device (TV) Then select Brand Name (DAEWOO). TW Cable lists several codes to cover different models. Choose a code and input into remote to see which code works. Try all codes. There were several codes to choose from and to try inputting into my TW Cable remote. Finally, the next to last code worked on my TW Cable remote -The Atlas OCAP 5-Device Remote Control by Universal Electronics. The code for this remote for Daewoo TV Model DTQ-13P2FC is 1661. Hope this helps. Otherwise, try checking the site of your cable or satellite provider & you should be able to get their add device codes for free.
Jun 21, 2011 | Daewoo DTQ-13P2FC 13" TV
Remote control codes
RCA Universal Remote Control Programming Codes
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
  • TV-000
  • VCR-000
  • Cable Box-000
  • AUX is programmed with VCR code 037
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
Find codes for device and brand below.
  1. Press and "HOLD" CODE SEARCH.
  2. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  3. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
RCA Codes for VCR
000,005,007,008,028
035,037,054,069
Nov 04, 2008 | RCA VR557 VHS VCR
My remote dont work
I have a Phillips Magnavox 5 device Universal Remote, model MRU3500 that may help.
JVC brand - including LCD, Plasma & Panal televisions Codes: 0607, 0204, 0321, 0508, 0617, 0326, 0993, 0802, 0108, 0308, 0715
Sep 03, 2008 | Philips 5-Device Universal Learning Remote...
Universal remote
Codes for Samsung (one of them should work on your RCA remote)
006,011,014,015,019,027,036,037,077
Programming Your Universal Remote.
  • TV-000
  • VCR-000
  • Cable Box-000
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Apr 07, 2008 | RCA Universal Remote 3 Device Remote...
Lg remote codes
Programming u-verse remote for LG4270 (LCD 42inch) worked fine with code 1346.
This is a "Plasma" code according to U-Verse technical support, but was suggested with perfect result.
Jan 05, 2008 | Directed 434MHZ Remote Control
Samsung HP-T5064 50 in. Plasma HDTV Logo
152 people viewed this question
Henry  Thomas
Henry Thomas
