Question about Vibe CBR10 Car Subwoofer
I have a vibe cbr 12 1400watt enclosed ive had it for years, since it first came out, its never put a foot wrong! Until when i turned on my ignition 2day. The battery was abit flat, it only just started the car. I reved the car abit turned on my sterio and it sounded like the sub wasnt working. I turned it up to full bass mode and you can only just hear the bass slighty, not even 1/50 of what it shud b. Ive checked the back all wires are connected! The sub light on the back is on! The sub is vibrating but not to the extent it should do, no where near, theres defently power and a beat going to the sub, RCA leads are fine! Ive also checked the volume switchs on the back of the sub and there both nearly on full and ive connected a battery charger to the battery so theres definatley enough power going to the sub, its just not delivering that power. Please can you tell me what is causing this to not work properly? . Is it possible something inside the encloser needs replacing, maybe something to do with the built in amp????
  • middleton_89 Oct 03, 2010
    Its the cbr evo sub not just the cbr!, I got an allen key took off the positive and negative leads and the signal wire, connected them all back up agaiun and it started working fine, i dont no what was causing it, unless there was a loose connection. All fixed now thank god
4 Suggested Answers
SOURCE: vibe cbr1 subwoofer
Might not be eathed properly. Check the earth on the battery as well. Theres more juice goin through there now so it might need a bigger earth or ground.
Posted on Jan 09, 2008
  • 113 Answers
SOURCE: how do i wire a fusion 12'' active encloser up to my car?
OK. (1) The RCA's plug into your audio-In on your amp and the other end of your RCA's plugs into the back of your cd player's audio-out. (2) The small blue wire is the "Remote wire" the one end is wired together with a blue wire in back of cd player other end to amp..To attach wire "remove some of the rubber insulator on wire about a 1/2 inch then twist wires together and put electrical tape to cover or wire nut if you have one." (3) "Ground wire" this is the black wire one side to "amp - neg" and the other end to frame of vehicle. " find a bolt in trunk and put the end of the wire around that and tighten bolt" but before putting bolt on take sand paper to the metal frame where the bolt hole is and sand all the paint off! (4) Last Power wire the "red wire". Cut about 12 inches off power wire plug one end to "amp + pos" the other end to the fuse...Now with the rest of the Power wire plug the one end to the otherside of fuse and run that threw car either driverside door or underneath the dash to the "+ pos red" side of battery.
Then your done! Good luck! and wire in that order and you want blow anything! Give me a thumbs up if you like!
Posted on Sep 24, 2009
plaztiksr4me
  • 154 Answers
SOURCE: 12 volts coming out of phono leads
replace the built in amp
Posted on Apr 09, 2010
I put the wrong key in the ignition, now when I put the right key in, the ignition wont turn at all
Try some WD -40 in the key hole. Spray a good bit in to remove any metal deposits.
Apr 13, 2015 | 1998 Cadillac Catera
2001 Honda CBR 929 RR Fireblade backfires
Hi, Anonymous and the usual suspects are:
1. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead-acid batteries.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Faulty main circuit breaker and or connections.
4. Faulty ignition coil and or connections.
5. Faulty spark plug, oil or gas fouled, wrong heat range or service type, wrong gap, loose in the cylinder head, broken electrode or insulator.
6. Faulty spark plug cables, leaking or broken, internal damage check for spark leakage in the dark.
7. Faulty ignition module, switch, CKP, MAP, CMP, sensor and or any connector in the ignition circuit could have corroded, loose, or broken pins/sockets
8. Burnt exhaust valve or air leak in the exhaust system.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
http://www.fireblades.org/forums/honda-fireblade/59391-backfiring.html
Bike won start just turns over and backfires Any ideas CBR Forum...
2000 2002 Honda CBR929RR CBR 929 RR Service Repair Workshop Manual... $15
https://www.partsfish.com/page/oem-parts-for-honda
Honda CBR 929 RR
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 24, 2012 | 2001 Honda CBR 929 RR Fireblade
I have a 2001 929 CBR and I put a new stator in it because it didn't start before and now it will turn over but it want start. Now I think it's the fuel pump, but if it is, how will it be for a used fuel...
Hi Ediamene, and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of over use of enrichner.
5. Vacuum hose to fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Discharged battery, loose, corroded or broken battery terminal connections especially the "NEGATIVE" cable inside the harness at both ends.
8. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
10. Ignition timing incorrect due to faulty ignition coil, ignition module or sensors (MAP, CMP CKP and/or BAS).
11. Sticky or damaged valve or pushrod wrong length.
12. Primary cam sprocket spline sheared or missing spacer.
13. Security alarm needs a reset.
For more information about your issue, please visit the websites below. Good luck and have a nice day.
2001 Honda Motorcycle Service Repair Workshop Manuals
Feb 17, 2011 | 2000 Honda CBR 929 RR Fireblade
Honda cbr
sorry but that will cheat the next owner. you would not like it done to you
Apr 06, 2010 | 2002 Honda CBR 600 F(4)i
Expert van 2.0 hdi engine runs lovely until you try to put your foot down engine cuts out management light comes on, turn ignition off leave about 10 secs engine starts and runs no misfire or anything a...
Hi You need to get the ecu checked for fault codes if there are none it is possibly low fuel pressure you should allso check this have you changed the fuel filter or opened any fuel lines this could introduce air
which will lower fuel pressure.Good luck Chris.
Feb 24, 2009 | 2006 Peugeot 604
High mileage
Anything over 90000 would equal 15000 + per year.
Nov 10, 2008 | 2003 Honda CBR 600 F(4)i
Vibe CBR10 Car Subwoofer Logo
214 people viewed this question
Top Vibe Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
mossman12
Are you a Vibe Car Audio and Video Expert? Answer questions, earn points and help others
