Question about GPS
Wiring diagram for escort mk5 rs2000 engine loom
SOURCE: Mk2 1991 gti 8v wiring loom
You have blown up the ecu as a result of not having a good earth connection from the earth lead on the gearbox.
This is a very common problem (done it myself!)
Only solution is to get the ecu repaired or replaced.
You must change the oil and filter before trying to start the car again.
Posted on Jul 02, 2008
SOURCE: wiring loom diagram deh1450
http://www.mediafire.com/?qwmnxnjktyz
BAJA EL SERVICE MANUAL ACA
Posted on May 14, 2009
nikey027
  • 30 Answers
SOURCE: Wiring loom diagram - WR125 2000
see yamaha dealer, or probs best bet- clymer manual off ebay (£20ish)
Posted on Aug 08, 2009
alicantecoli
  • 22265 Answers
SOURCE: i want a diagram of the wiring from a ford escort
This is all about a haynes car book is good for ,that or lighting a fire
Posted on Dec 19, 2009
Can a 1995 escort moter b put in a 1998 escort
Do you mean will it fit with no mods? I.e onto your original gearbox, mounts & wiring harness... If you have a cvh engine you can swap with a cvh, if yours is zetec then you can swap with a zetec of the same size, 1.4 & 1.6 cvh engines are the same, zetec motors 1.8 & 2.0 are the same, escort mk5 & mk6 chassis are the same except for the cosworth, hope this answers your question
Feb 14, 2015 | Vehicle Parts & Accessories
Wiring diagram escort mk5
please help my car due mot on moday n wpers wnt work nether do the heater metrix as its burst n out for repair is this why?????
Jan 09, 2012 | Ford Escort Cars & Trucks
I have fitted a 1994 7.3 litre efi engine into a 1990 f150 and was wondering if i have 2 use the complete wiring loom out of the f350 where the engine came from or is there anyway of grafting the engine...
if you contact a ford dealer parts dept, they will give you a printout of the wiring diagrams and color code specs for each vehicle,, the loom on the 350 will have a slight variance of color codes and wires for pretty much the same setups depending on year and model,, Normally I would say yes, But when it comes to harnesses and what all the specified models have as far as accessories comes into play, I would consult the 2 wiring diagrams for subtle changes
May 08, 2011 | Ford F-150 Cars & Trucks
Ford Escort cooling fan not working, Wiring diagram or problem ID Please. 1998 Ford escort 1.6 petrol. Cheers
check the fuses there s also fuses in the engine bay,also check the wiring to the fan,the wires lead back to the main loom so if you are trying to trace the wire back its easier to take this out to check it but make a note of what connects to what.
Jan 31, 2010 | 1998 Ford Escort
Escort rs2000 16v fan belt diagram
My sincere apologies for the delayed response.
I am personally going back to answer your unanswered questions.
I do not know if you still need this information, but I am going ahead and answering it anyway. You may want to Print the Diagrams for future use.
CLICK
on the following LINK. It has the Belt Diagrams you will need.
If you would: Before Clicking: Let me know if this helped you, or if you have any additional information or questions. Feel Free to contact me at FixYa.com!
Again my apologies...
Thanks!
http://www.2carpros.com/car_repair_information/year/1996/make/ford/model/escort/1996_ford_escort_drive_belt_routing_diagram.htm
Jan 30, 2010 | 1996 Ford Escort 4 Door
I have a rs2000 escort and the heating is not working at all, the car keeps over heating, wat is it???
the heater is the first thing that stops working when you lose water, so the problem is
  • water leak from cooling systym
  • if after work on engine, air block in cooling systym
  • thermostat sticking causing overheating
  • electric fan not working when stationary for a while
  • major engine fault, head gasket, checked block
Dec 27, 2009 | 1998 Ford Escort
I want a diagram of the wiring from a ford escort rs2000 1995
Dec 19, 2009 | 1995 Ford Escort
GPS Logo
128 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
