Question about Roper Dryers
I have no heat i checked continunity on the element and replaced both thermostats but still have no heat. i have a roper dryer model number rex6634rq1
  • Roper Master
  • 7,482 Answers
Check your electrical breakers
Be sure to check your voltage coming to the dryer at the plug and the machine back where the wires connect to the terminals you should have 220Volts.
I think this may be your problem with no heat.
This is a free answer, Please rate me
Posted on Oct 03, 2010
Dryer not heating
Hello there and welcome to fixya
Here are the most common things that will need to be checked with a meter to ensure there is continuity on these parts no continuity means that the part is bad and needs replacement ok?
Thermal Fuse
If the dryer doesn't heat, but the drum turns, check the thermal fuse(s). The thermal fuse protects the dryer from overheating and helps to prevent fires. If the thermal fuse is blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric solenoids which open the valve to let the gas flow into the burner assembly. If the dryer doesn't heat one or more of the solenoids may be defective. If the igniter glows for 90 seconds but the burner flame doesn't light, replace these coils as a set.
Dryer Igniter
If the dryer doesn't heat, the igniter might be burned out. Check the igniter for continuity with an ohm meter. Dryer igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can burn out over time. If the dryer doesn't heat, the element should be checked for continuity. The heating element cannot be repaired and must be replaced if defective.
Heating Element Assembly
The heating element assembly on an electric dryer can burn out over time. If the dryer doesn't heat, the element assembly should be checked for continuity. The heating element assembly cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the heat given off by the flame. If the dryer doesn't heat, the flame sensor might be defective. Check the flame sensor for continuity. This is not as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn't heat the high limit thermostat can be defective. It can be checked for continuity. If the thermostat is "open" the dryer doesn't heat.
Cycling Thermostat
The cycling thermostat regulates the temperature of the air in the dryer. If the dryer doesn't heat it may be caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at fault when the dryer doesn't heat. Check all of the other components in this troubleshooting guide before replacing the main control board. The main control board cannot be tested easily and must be replaced if it is defective.
Timer
The timer is normally not at fault if the dryer doesn't heat. In many situations where timers are replaced they end up being returned. Check all of the more common components in this troubleshooting guide before replacing the timer
Oct 14, 2013 | Amana Dryers
Whirlpool electric dryer high thermostat replacement
test all this steps in according with your model, electric or gas. God bless you
Thermal Fuse
Gas Valve Solenoid
Dryer Igniter
Heating Element
Flame Sensor
Cycling Thermostat
Main Control Board
Timer
The timer is normally not at fault if the dryer doesn't heat. In many situations where timers are replaced they end up being returned. Check all of the more common components in this troubleshooting guide before replacing the timer.
Jul 21, 2013 | Dryers
Brand new dryer wont heat
depending on which model roper dryer it can be a thermal fuse,high-limit thermostat,cycling switch,burned off wire in control panel,check each side of the heating element to ground and find 125 v.a.c. then on the side of the element that has low or no voltage on it to ground start at the element and back track the components leading to the dead leg on the element till you find 125 vac to ground and replace or repair component or wire,then you should get 240 to 250vac across heating element terminals
Feb 17, 2012 | Roper Dryers
The heat will not come on
some possibilities are bad heating element or safety thermostats or timer switch. the heater will involve taking the tub out and measuring resistance on the heating element and check continunity of the safety thermostats. with ohm meter. The heating elements are around 250 dollars.
Jan 09, 2012 | GE 5.8 Cu. Ft. Extra-Large Capacity...
Roper electric dryer will not heat after replacing heating element and thermal fuse. what's wrong.
It doesn't necessarily mean the heating element is busted when the dryer stops heating and the thermal fuse is not part of the heating circuit, it is part of the motor circuit. The heating circuit is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The most common part that causes the dryer not to heat is the thermal cut-off and/or the high-limit thermostat. Verify this condition by bypassing the said components. Click on the link below for the detailed instructions. Indicate the exact model number of the dryer should you need further assistance.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
Feb 12, 2011 | Dryers
Roper dryer does not heat . replaced heating element and thermal fuse. what's wrong
No heat at all is usually the thermal fuse, the high limit thermostat, the heating element or you have a bad breaker at the box and are running on 1/2 phase (or 110 only).
With the power OFF and the dryer unplugged. Use and ohms meter (borrow one or pick up a cheap one for around $10-$15) & check the high limit thermostat (right hand side at the base of the housing for the heating element), take the wires off both terminals and check for continuity between the terminal (set the meter of ohms place the black lead on one terminal of the thermostat & the red lead on the other terminal, doesn't matter which, the needle should move, if it doesn't, replace the thermostat).
You can check all the thermostats, fuses, door switch & the heating element this way.
Feb 12, 2011 | Roper Dryers
Model RES7745PQ0 works great but no heat... what is most likely the problem... also I checked my breaker so that's not it...? HELP\r\nBest Regards
The problem is likely in the thermal cut-off (cut-out) and the high-limit thermostat located on the heating element housing. Verify this condition by bypassing the said components. Disconnect power then remove the rear access panel to access the thermal cut-off (cut-out) and the high-limit thermostat. Disconnect the wires of each component then connect them together and insulate it properly. Reconnect power then start the dryer. The problem is indeed in the thermal cut-off (cut-out) and the high-limit thermostat if the dryer heats up. Replace both parts and it should solve the problem. It is an easy and cheap repair to make.
The
thermal cut-off (cut-out) and high-limit thermostat are sold as a kit with part number 279816 and costs about $30.
In case the dryer still doesn't heat up with the
thermal cut-off (cut-out) and high-limit thermostat bypassed, bypass the cycling thermostat then replace it if the dryer heats up. Check the heating element for broken coils if the dryer still doesn't heat up with the three components mentioned above bypassed.
Jan 19, 2011 | Roper Dryers
MY ROPER DRYER QUIT HEATING STILLS WORKS NO HEAT
The thermal cut-off , which is the small t-stat looking piece located at the top of the element housing ( on vertical mount elements ) or the far front of the element housing ( on horizontal mount elements ) , is usually the cause for no heat .
Aug 02, 2010 | Roper REX4634KQ Electric Dryer
Frigidaire gallery series dryer will not heat
Hello spirit817. Unplug the 220v, remove the back panel, locate your heating element, check the wiring connections to the element. DVM or ohm your element for continunity. If open research your local electrical applance store for the replacement. If not the element check your thermostats located in the air drafts with the meter.
Sep 23, 2008 | Dryers
Dryers Logo
55 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
