Question about Honeywell Programmable Thermostat Heater
Problem with Honeywell RTH230B Thermostat
I have purchased Honeywell RTH230B thermostat. When the set point temperature is lower than the actual temperature, the fan will be working if I set it to auto. If the set point temperature is higher than the actual temperature, it will not work, it sounds normal for the cooling. But the temperature would not decrease into my setting point…. What is it wrong with it? Does anyone know how to help me?
  • pstamm May 29, 2008
    Running into similar problem with Honeywell RTH230B, however Heat worked fine, now A/C won't turn on.
    Wire colors from wall: White, Yellow, Red, Green, Black
    Connections on tstat: Rh, Rc, Y, G, W
    What is the correct wire to connection combination?
  • mojokes Apr 25, 2009
    Old thermostat is long gone and I've forgotten the terminals and where things were hooked up.
    Honeywell t-stat terminals: Rh, Rc, W, Y, G.
    My five wires: Red, Black, White, Yellow, Greed
    The heat worked fine all winter. I turned the A/C on today and I get nothing. I imagine my problem is related to my Black, Yellow, and Green wires. Is the black even needed? I can't get a voltage reading across the black and yellow wires, which are connected into Rc and Y, respectively.
    Do I need to ditch the black wire and put a jumper between Rh and Rc?
    Oh....natural gas furnace if that matters (remember, heat works).
  • 46 Answers
Sounds like you have it wired wrong..   Pop the top off and give me to color of the wires and tell me which letter each color wire is on.. that will tell us right away if you have it wired wrong
Posted on May 27, 2008
  • Buck Whyte
    Buck Whyte May 30, 2008
    ok correct wiring with the stat you have is..
    white to W
    red to rh or rc there should be a small jumper that runs between rh and rc
    yellow to Y
    green to G
    NOW the black wire is a question mark... there should be a 6th position on your stat with a B stands for blue.. MOST techs use this diagram.. but may not have had stat wire and used telephone wire.. seen this many times..
    Hope this helps
My wires are as follows.red,white,black,green.where do you put the jumper cable
my model no. is honeywell RTH230B and old model..I don't have the color blue or yellow in this thermostat
Posted on Oct 14, 2011
2 Suggested Answers
  • 5384 Answers
SOURCE: thermostat won't keep furnace fan running
You probably have a loose or broken wire to the fan relay. Check the wires on the thermostat first. Pull up on the bottom of the thermostat to remove it from the wall plate. You should see several screw terminals and the conductor wires that should be connected to them when you look at the wall plate. Check if any of the wires are disconnected or broken. If a wire is broken, strip a portion of the unbroken section of the wire and secure it to the appropriate screw. (The fan relay terminal is G for most setups.) If none of the wires are loose or broken, then you have to check for damage to the wires between your heating system and the thermostat or at the heating system. It could be a bad wire going to the jumper on control board or damage to the board itself.
I hope this helps. If the problem is not at the thermostat, you may need to have a professional diagnose and fix the problem. However, if you post additional comments about your heating system, Fixya experts may be able to help you diagnose the problem.
(we had the broken wires at the thermostat keeping the fan from working in the past. It's an easy fix if you are willing to handle small wires carefully.)
Posted on Jul 06, 2013
New instruction manual for RTH230B
Do you mean the Honeywell RTH230B programmable thermostat? Most of the Honeywell thermostat manuals are available here: http://yourhome.honeywell.com/en/faqs/thermostat . Scroll through the pages to find the RTH230B or use the search feature. The search engine found the installation and user guide in three different languages, see https://yourhome.honeywell.com/en/supportsearch#q=Rth230b . The direct link to the manual in English is https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-1800.pdf .
I hope this helps.
Dec 07, 2017 | Heating & Cooling
I couldn't figure out how to amend my last question, so here is one more piece of information. I just put batteries back in and reset the time/date. The Temp Up and Temp Down buttons WORK FINE
your thermostat may be locked go to honeywell web site punch in thermostat model # and look for set up pushing two button at the same time gets you in but you will need instuctions for set up
Jan 31, 2015 | Honeywell RTH230B 5-2 Day Programmable...
Dip switch settings rthl2310
Check for cold air inside the wall behind the thermostat, a cold wall, and area that is getting hot or cold air blowing on the thermostat. Last, the heater may not be compatible with some digital thermostats. Honeywell Customer Care toll-free at 1-800-468-1502.
Aug 29, 2014 | Honeywell Programmable Thermostat Heater
Incorrect ambient temperature on Honeywell Model RTH221B
Check in your manual for the thermostat. By pushing a combination of buttons you can get into the advanced installer menu. From there you can make an adjustment to correct the temperature.
Nov 11, 2009 | Honeywell Programmable Thermostat Heater
Rth230b thermostat, want to change C* to F*
Turn the thermostat mode to off. Push & hold both temperature up &down at the same time and screen on tstat should change and display Unit this is where you change C to F setting. I dont quite remember how to exit, if you change your setting and leave tstat alone and it should change automatically Good luck
F
Jan 08, 2009 | Honeywell Programmable Thermostat Heater
New honeywell thermostat on new gas furnace not working
sometimes there's a differential setting anywhere from 1-3 degrees, see if you can make sure it's down to 1
Nov 12, 2008 | Honeywell Programmable Thermostat Heater
Honeywell rth230b thermostat doesn't work
On most Honeywell Digital T-stats there is a 5 min delay built in
Oct 23, 2008 | Honeywell Programmable Thermostat Heater
I have my temp on C and I need to change back to F I have the RTH230B programable
May 30, 2008 | Honeywell Programmable Thermostat Heater
Honeywell rth230b won't shut off heat
Sounds like a relay sticking. Possibly in the thermostat or possibly the furnace relay at the furnace. The next time it happens, unplug the thermostat from the wall. If the furnace still runs then it's the furnace relay.
Hope that helps...
Geno
Mar 07, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
2,848 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
