Question about Evesham Axis 2800 (AXIS2800+MKRMAR04) PC Desktop
What CMOS battery replacement would be suitable for my Axis 2800 PC, olease
    Problem Solver:
  • 10 Answers
I would suggest doing a Google search for the CMOS battery for your Axis 2800 PC...Jeff
Posted on Oct 03, 2010
Dell inspirion 1525 master reset
Other than replacing the cmos battery or hard drive that's really it. There is no master reset switch.
May 10, 2015 | Dell Computers & Internet
Were changing the water pump on a 1993 buick lesabre but have run into a problem. Can't get the motor mount out so we can get to the water pump. Have removed 2 bolts and a nut on the engine and all the...
Water Pump REMOVAL & INSTALLATION CAUTION
When draining the coolant, keep in mind that cats and dogs are attracted by ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old. 1987-95 Vehicles EXCEPT 1995 VIN 1 ENGINE
  1. Disconnect the negative battery cable.
  2. Drain cooling system into a suitable container.
  3. Remove the serpentine drive belt, as outlined in Section 1 of this manual. NOTE: On some engines, removing the alternator provides better clearance for removing the water pump. For alternator removal and installation procedures, please refer to Section 2 of this manual. Fig. 1: After removing the alternator, remove the brace 89633p01.jpg
  4. Unfasten the water pump pulley bolts, (long bolt removed through access hole provided in the body side rail), then remove the pulley. Fig. 2: Pull the water pump pulley from the pump 89633p03.jpg
  5. Disconnect the radiator and heater hoses from water pump. Fig. 3: Use a screwdriver to loosen the hose clamp screws, then disconnect the hoses from the water pump 89633p02.jpg
  6. For 1992-95 vehicles, remove the torque axis mount, as follows:
    1. Use a suitable engine support fixture and lifting bracket to raise the engine slightly to take the weight off of the engine mounts.
    2. Remove the through-bolt from the torque axis (front) engine mount.
    3. Lift the engine with the support fixture until the power steering reservoir touches the strut tower cross brace.
    4. Loosen the bottom two bolts on the torque axis (front) engine mount.
    5. Remove the A/C line clip and top two bolts on the torque axis engine mount, then remove the mount.
    6. Remove the 2 bolts and nut attaching the engine torque axis mount bracket assembly to the front of the engine. NOTE: On some engines, when you remove the 13mm bolts, coolant will flow from the bolt holes, so make sure to position a drain pan under the pump before unfastening the bolts.
  7. Remove the water pump attaching bolts, then remove the water pump from the vehicle. Remove and discard the gasket. Thoroughly clean the gasket mating surfaces. Fig. 4: Unfasten the water pump mounting bolts (see arrows for locations of top bolts) . . . 89633p04.jpg
    Fig. 5: . . . then remove the water pump from the engine 89633p05.jpg
    Fig. 6: Use a gasket scraper to carefully clean the water pump's mating surface 89633p06.jpg
    Fig. 7: You can also use Scotchbrite® or equivalent non-abrasive scouring pad to clean the water pump gasket mating surface 89633p07.jpg
    Fig. 8: When using a scraper to clean the gasket mating surfaces, be careful not to gouge the engine and cause leaks 89633p10.jpg
    Fig. 9: Exploded view of the water pump mounting - 1994 vehicle shown, others similar 89633g37.gif
    To install:
  8. Apply a suitable sealant to the bolt threads. Fig. 10: Coat the bolt threads with a suitable sealing compound 89633p09.jpg
  9. Position a new gasket, then install the water pump to the engine and tighten the retaining bolts, as follows: Fig. 11: Place a new gasket on the water pump mounting surface 89633p08.jpg
    1. For 1987-94 vehicles, tighten the long bolts to 29 ft. lbs. (39 Nm) and the short bolts to 97 inch lbs. (11 Nm).
    2. For 1995 vehicles, tighten the water pump-to-block bolts to 22 ft. lbs. (30 Nm) and the water pump-to-front cover bolts to 11 ft. lbs. (15 Nm), plus an additional 80°rotation.
  10. For 1992-95 vehicles, install the torque axis mount, as follows:
    1. Attach the torque axis engine mount bracket assembly to the front of the engine using the 2 bolts and nut. Fig. 12: Install the torque axis engine mount bracket and secure with the 2 bolts and nut 89633g34.gif
    2. Replace the 2 upper bolts previously removed from the torque axis engine mount, and attach the mount and plastic clip for the A/C lines.
    3. Tighten the 2 lower bolts that were previously loosened on the torque axis engine mount. Fig. 13: Exploded view of the torque axis engine mount and tightening specifications 89633g35.gif
    4. Adjust the engine height to align the torque mount with the torque axis mount bracket.
    5. Insert the through-bolt, attach the retaining nut and tighten to the specifications shown in the accompanying figure. Remove the engine support and lifting fixture. Fig. 14: Insert the torque axis mount bracket through-bolt 89633g36.gif
  11. Install the water pump pulley and secure with the retaining bolts.
  12. Connect the radiator and heater hoses to the water pump.
  13. Install the serpentine drive belt.
  14. Connect the negative battery cable.
  15. Fill cooling system and check for leaks. Start the engine and allow to come to normal operating temperature. Check for leaks and top-off the coolant.
Dec 17, 2010 | Buick LeSabre Cars & Trucks
Is there a cmos battery in an hp 2800? If so, where is it?
There is no CMOS battery in this printer. The instruction manual indicates the only way to reset the printer is to power it off, unplug it, and let it rest for 30 seconds before reconnecting power and turning it back on.
http://h20565.www2.hp.com/hpsc/doc/public/display?docId=emr_na-c00453791
Dec 01, 2010 | HP Business InkJet 2800 Printer
Replace cmos battery
A cmos battery is what keeps a device from erasing information being given to it, in other words it provides power to any device that has one in it when that device is off.
simply purchase one from where you bought the printer or from any electronic store but keep in mind that there are different sizes so reffer to the printers manual for more information about it at the hp website below for the manual
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&contentType=SupportManual&docIndexId=64255&prodTypeId=18972&prodSeriesId=3656598&lang=en&cc=us
Jul 04, 2010 | HP Business InkJet 2800 Printer
How do i replace a water pump on a 1992 buick lesabre custom
GM Bonneville/Eighty Eight/LeSabre 1986-1999 Water Pump - REMOVAL & INSTALLATION
CAUTION When draining the coolant, keep in mind that cats and dogs are attracted by ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old.
1987-95 Vehicles
  3. Remove the serpentine drive belt, as outlined in of this repair guide.
On some engines, removing the alternator provides better clearance for removing the water pump. For alternator removal and installation procedures, please refer toin this repair guide.
  1. Unfasten the water pump pulley bolts, (long bolt removed through access hole provided in the body side rail), then remove the pulley.
  1. Disconnect the radiator and heater hoses from water pump.
  1. For 1992-95 vehicles, remove the torque axis mount, as follows:
  1. Remove the water pump attaching bolts, then remove the water pump from the vehicle. Remove and discard the gasket. Thoroughly clean the gasket mating surfaces.
To install:
  1. Apply a suitable sealant to the bolt threads.
  1. Position a new gasket, then install the water pump to the engine and tighten the retaining bolts, as follows:
  1. For 1987-94 vehicles, tighten the long bolts to 29 ft. lbs. (17 Nm) and the short bolts to 97 inch lbs. (11 Nm).
  2. For 1995 vehicles, tighten the water pump-to-block bolts to 22 ft. lbs. (30 Nm) and the water pump-to-front cover bolts to 11 ft. lbs. (15 Nm), plus an additional 80° rotation.
  1. For 1992-95 vehicles, install the torque axis mount, as follows:
  2. Install the water pump pulley and secure with the retaining bolts.
  3. Connect the radiator and heater hoses to the water pump.
  4. Install the serpentine drive belt.
  5. Connect the negative battery cable.
  6. Fill cooling system and check for leaks. Start the engine and allow to come to normal operating temperature. Check for leaks and top-off the coolant.
Hope this help (remember comment and rated this; TY for using Fixya.
Mar 31, 2010 | 1992 Buick LeSabre
WHILE BOOTING MY PC I GET A PROBLEM OR ERROR NAMED AS CMOS CHECKSUM ERROR DEFAULTS LOADED
Usually when I see this problem it is because the cmos battery is bad. Replace the cmos battery and see if that fixes the problem. If it doesn't, then you really do have a problem. :)
Mar 10, 2010 | AMD Sempron 2800, 2.0 GHz 2800+...
Have an evesham pc Axis64-KD and need to know type of battery that backs up clock system. Any info please
The Evesham Axis 64-KD Desktop PC use a CR2032 battery, for the backup battery. (CMOS battery)
It's a watch type battery. Is approximately the size of a US nickle.
This shows what the battery looks like.
http://en.wikipedia.org/wiki/Button_cell
The battery is obtainable in many places that sell batteries for cameras, and watches. I buy mine from my local pharmacy. (Cheaper. About $1.69 US)
Jan 12, 2010 | Evesham Computers & Internet
Forgotten Password
plz remove the cmos battery from the mother board for 20 secs and reboot again
May 18, 2009 | Compaq Presario 2800T Notebook
Just installed new CPU on M848A v2.1 and pc will not POST
becose the processor not support that.replace it by a suitable one.
Jan 16, 2009 | PC Chips M848ALU Motherboard
Location cmos battery fujitsu siemens amilo pro V2000
remove main cover on reverse - there will be a small (2cm) flat battery 'probably under some electrical tape' - good luck
Aug 07, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
Open Questions:
See all Evesham Axis 2800 (AXIS2800+MKRMAR04) PC Desktop Questions
Evesham Axis 2800 (AXIS2800+MKRMAR04) PC Desktop Logo
101 people viewed this question
Top Evesham Computers & Internet Experts
Lakshman P
Anwarul Haque
Anwarul Haque
Are you an Evesham Computer and Internet Expert? Answer questions, earn points and help others
