Question about Beko 24 in. D3731F Free-standing Dishwasher
Hello my beko dishwasher keeps on pumping out even when it is empty of water. i think it happened after the first rinse it pumps constently i havepoured water through it the outlet is not blocked it just keeps going its like the pump thinks there is still water to be extracted
  • clifford starks
    clifford starks Nov 05, 2016
    Nearly bought a new dishwasher till I read this pulled it out tillTed it till it clicked pushed it back works perfectly again.thank you..
SOURCE: BEKO D3422FW Dishwaser stays on the pump out cycle.
I can confirm Solution #2.
This usually happens whe you have a blockage in the waste pipe. For some reason, once you've cleared the blockage, the dishwasher doesn't detect that water has now passed through the system, even if you send through more water via filling the base (I did this about 4 times totalling 24litres of water and it still didn't reset).
Tilt the dishwasher back (I only had to tilt it about 30 degrees), this resets whatever switch it is that turns the pump off and allows it to fill with water.
Posted on May 06, 2009
  • 123 Answers
SOURCE: Beko Freestanding Dishwasher
Hi there ....this condition is ususally caused by a water leak into the sump of the dishwasher which activates a safety switch to run the drain pump..preventing the appliance from being used....Remedy...tip the dishwasher back in the head allowing excess water to exit from the sump...then with the door open check that the air vent lock ring is secure, thet the salt unit retaining ring is secure..and finally that the filter unit to base screws are secure...this done re-start and you should b fine
Posted on Jan 05, 2007
  • 833 Answers
SOURCE: Neff dishwasher will not empty
Could be a kinked hose, diverter solenoid is jammed or burnt out. If the dishes are clean and the pump is working...then look at the above. If the spray isn't happening, the pump could be a problem. They are usually direct drive and you'll note that the motor isn't working.
Posted on Feb 10, 2008
  • 236 Answers
SOURCE: IDL 700 Dishwasher
it sounds like you are going into flood mode. tip the unit 45 degrees to the side and see if you are getting loads of water pouring out. if so you have a leak and need to check components in the base.
Posted on Sep 12, 2008
hektor1961
  • 70 Answers
SOURCE: hotpoint wma13 wont empty, think pump is blocked
Yes,
The water pump most be clugged and/or defective.
Posted on Aug 18, 2009
I have a beko 4311w dish washer that wont empty. i emptyed the water manually and have checked all filters and hoses and all seemed to be clean.then switched back on and machine completed one complete...
The motor runs in one direction to wash and the opposite direction to pump out the water. Look at the motor direction controls to see what is starting to fail.
Jan 03, 2015 | Beko Dishwashers
Hi, I have a Beko DE6340 which just stopped working. No lights or anything and have changed the fuse to no avail. Someone suggested cleaning the drainage pump completely but would that cause it to not
With all dishwashers when you press knob or push button, they first start to empty out any remaining water. If yours isn't doing this it could be that your pump has clogged, or has died altogether. So at the point your at the answer is yes. Check all the lines to and from your pump to discharge. GOOD LUCK FRIEND.
Dec 02, 2014 | Beko Dishwashers
My Dishlex Global 300 dishwasher stops mid cycle and the rinse light keeps flashing ?
I think I had the same problem. I don't know much about dishwashers, but the "Flashing Rinse" has something to do with the drain, or the drain pump (which is why the water doesn't drain).
My dishwasher stopped its cycle, after having filled up with water, even though everything else worked fine, because the drain pump was not even turning on. So I guess, the first question I asked was, is the drain blocked? No. When this happened the first time, the flashing rinse cam up. After that, the dishwasher just wouldn't drain, and there was no longer a flashing rinse.
So then, I figured, the drain pump is probably rooted. The drain pump is found underneith the dishwasher, just behind the front panel on the left hand side.You'll need to remove the metal covers from the front and the left.
When this happened to me, I thought I'd need to buy a new pump, so I pulled the other one out (its a bit fiddly, you have to disconnect the two electrical wires, then remove the drain pipe from it, and then wiggle it off. But when I got it out, I unscrewed it (it has the special hexagonal screws, not phillips or flathead), and it turns out, a fairly large fruit seed had got into the drain pump and blocked it, preventing it from spinning. I put it back together again, and it worked.
It so far has beaten paying $100 for a new pump.
If you want a visual of what the drain pump looks like, look up the dishwasher part number #8905912, you should be able to find it on the internet. Hope this helps.
Jul 29, 2010 | Dishwashers
I have beko dishwasher works fine but no hot water is it just the element which needs replacing or could it another problem MODEL DWD4310S
How far is your water heater from your dishwasher. I knew someone who had to get a circulating pump. His dishwasher was so far form the water heater so when the dishwasher would fill, it used the cold water that is sitting in the pipes and by the time the hot water got there, the dishwasher didn't need any more water. the pump will keep the water circulating back and forth to and from the hto water heater. Or you an get one of those electric small heaters that heat on the spot as well.
Dec 10, 2009 | Beko Dishwashers
What is causing the drain pump to continue running
C1 - Partially Blocked Drain - This error will occur when dishwasher was unable to pump out water in less than 95 seconds. Check drain line for debris and blockage. If clear, check for a restricted drain valve in the pump. Check the pressure sensor for correct operation as it sounds like it may be defective and thinks that the machine is still full of water after it has emptied.
Oct 30, 2009 | Dishwashers
Becod 2731fw dish washer pump running continualy on turning the washer on and nothing else
lower tray flooded have u been using 5 in 1 tabs iff so dont use rinse aid iff not check inlet inside d/washer left hand side tighten up tip machine 2 45 degrees either side this will empty tray
Jul 13, 2009 | Beko 24 in. D3731F Free-standing...
Dishwasher just emptying
I am at the end of my tether. I have bought a new door latch for my Bosch SGS 43E02 GB45, so door now closes properly and have managed to stop the leak under the front left hand side of the machine. Howver it sounds as if it is constantly emptying. It does not go onto the new wash cycle just keeps pumping out the water. It did run a quick rinse yestreday but now is back to the constant emptying problem. Even when I open the door it still keeps running and staying on a emptying cycle despite there being no visible water left inside the machine. Please help!!
Sep 12, 2008 | Dishwashers
Oct 23, 2007 | Beko 24 in. D3421F Free-standing...
Beko 24 in. D3731F Free-standing Dishwasher Logo
2,742 people viewed this question
Top Beko Dishwashers Experts
Shekar Avadhani
Eric Taylor
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
