Question about Maytag MSD2756G Side by Side Refrigerator
Need help My 5.5-year-old Maytag MSD2756GEQ side-by-side refrigirator does not stop working and I am unable to regulate temperature. The feezer still working, however, not so well. the refrigirator part seems to get much warmer . And the floor under the refrigirator is not warm (it use to be warm all these years). Can you please give me any idea what happend and is it worth to fix it. Thanks.
  • bytlmn May 27, 2008
  • bytlmn May 28, 2008
    Thanks a lot for your respond, but unfortunately, it did not help to solve the problem
  • 828 Answers
A removable panel in the rear gives access to the compressor and condenser. Remove the panel and clean out the condenser. Make sure the condenser fan operates when the compressor runs. Restore the panel to its original position for normal operation.
Posted on May 27, 2008
  • James Helmer
    James Helmer May 28, 2008
    Look at the back panel of the freezer compartment. If there is frost on it your problem is related to the defrost system. It could be defrost timing device, defrost heaters or defrost thermostat. When one can not see what the person asking a question see it sometimes takes more than one step to get to the root of the problem. The statement of the floor not being warm threw my mind off track.
How do I get my maytag side by side refrigerator model# msd2756geq to cool down below 50
first turn your refrigerator temp setting to 1 then wait for the compressor to kick off, this will send the unit into defrost mode, and most units take between 1 to 2 hours to acclimate(get tempered) correctly. after a few hours gradually turn your unit towards 9 until the compressor kicks on, when it does , stop turning the knob, it will acclimate again, 1-2 hours (some units can acclimate in 15 minutes) check your unit temp and do not use the unit if it won't cool down to 43 or less degrees, you run the chance of food poisoning. hope this was helpful.
Aug 01, 2014 | Maytag Refrigerators
Maytag MZD2766GE
Apparently, you will need to call a service man.
You may be low on freon.
Sometimes leaks occur and are not serviceable except by a service man.
I recommend that you find a service man in your area. There may be one at this website listed who would be close.
Apr 06, 2008 | Maytag MZD2766GES Side by Side...
Where is defrost timer in maytag MSD2756GEQ SxS
Inside the refrig section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and foreward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrig's , a white box will be seen. Inside this box , is the adaptive defrost control
Jun 13, 2010 | Maytag MSD2758G Side by Side Refrigerator
GE GSS25LGMA refrigirator/freezer refrigirator side is freezing
There is an electrically activated air dampener in the upper left back side of the refrigerator section which most likely has broken (in the open position), allowing cold air from the freezer to continue to enter the fresh foods section. Replace the dampener assembly.
Mar 29, 2010 | Refrigerators
Maytag refrigerator, feezer side coil frozen and frigirator not
Defrost circuit failed, needs to be able to defrost the coils so air can pass through them thus cooling evenly. You can check the heaters located on the coils probably near the bottom back wall of the freezer with a ohm meter if you read through, the heaters are good, if you get no reading the heaters are bad. Or could be defrost timer or on newer models the adaptive defrost control which is a circuit board. If its an older model you can manually turn the timer with a screwdriver if you feel resistance, then you should replace the timer. Also in the circuit is the defrost thermostat located on the coils, this is the least expensive of the 3 components to replace. You should have a schematic located under the fridge, use this to determine which type of timer you have and for further trouble-shooting. Please let me know if this helps
Aug 22, 2009 | Maytag MCD2257HE Side by Side Refrigerator
Refrigerator not cooling: Maytag Plus: Model MSD2756GEQ
Your PTC relay is bad and needs to be replaced. It is on the side of the compressor that connects the wires to it. Cost is about 50 maytag price or you could go with a 3 in 1 cost about 15. If you need any help get back with me and can walk you though it. Ken
Aug 15, 2009 | Maytag MSD2758G Side by Side Refrigerator
The refrigerator temperature is too cold. Everything is freezing.
there is a dial that regulates your temperature, this is inside the refrigirator, look for it and should say cold to coldest, put it in cold or if it has number from 1-5 just put in 3
Jul 09, 2009 | Refrigerators
Maytag plus MSD2756GEQ ice maker not working
I had similar problem in that the fan in the freezer that blows freezing air into freezer and over to fridge was not working. Fridge was running warm (over 40 deg and freezer up near 20) Service call around $160 with new fan.
Feb 06, 2009 | Maytag MSD2756G Side by Side Refrigerator
Freezer won't work in garage in cold weather
Modern fridge/freezers are built to automatically defrost themselves. To do this they require that the room temperature is well above freezing to allow the defrost to take place. If you site the freezer in too cold an environment it is unable to defrost itself and will eventually stop working. It sounds strange but if it is too cold the freezer cannot work. The solution is to buy and fridge/freezer that does not automatically defrost itself if you want it to work in a cold environment.
Dec 06, 2008 | Refrigerators
Maytag MSD2756G Side by Side Refrigerator Logo
189 people viewed this question
Top Maytag Refrigerators Experts
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
