Question about Iomega Computers & Internet
I cannot transfer my data from computer to Iomega hard disk. It can be detected and I can transfer the other way round. Please help me out.
  • 8,404 Answers
Has your Iomega drive ever worked with this particular computer under this particular Operating System??? Have you recently upgraded your computer or operating system??? Have you checked the Microsoft Hardware Compatability list for issues??? Here is the link for Win 7: http://www.microsoft.com/windows/compatibility/windows-7/en-us/?CMXID=ef_sem&semid=ef_GGL_851ac3fe441d9bbe86ee8334a709e4f2&WT.srch=1&ef_id=2437:3:s_261e5c7b1fd43ac28c94d632358a0e63_5518740682:TKiIwQqoEEQAAF-pvOQAACiS:20101003134433 From here you can also access other versions of Windows to match your OS.
If everything checks out in the hardware department, I suggest you go to the Iomega website and assure you have the very latest driver for your device that is compatible with your computer/OS.
Thank you for your interest in FixYa.com
Posted on Oct 03, 2010
How do I erase all data data on my iomega ldhd250-u
click start click on my computer you should see your iomega drive
right click then select format
another way is to control panel administrative tools computer management disk management right click on your iomega drive select format
hope this helps
Jul 08, 2012 | Iomega (33215) 250 GB Hard Drive
My computer recognizes my iomega usb hard drive, but cannot open the files.
here is the best way to get back lost files.
1.) Stop using the hard drive IMMEDIATELY! Do not drag or create any files on it.
2.) Download asoftech data recovery program: http://www.asoftech.com/adr/index.html
3.) Install and run the data recovery program against the hard disk
Good luck.
Sep 01, 2011 | Iomega (34959) 500 GB USB 20 Hard Drive
My iomega hard drive worked fine before, but now won't show on My Computer or Autoplay. Help, please?!
First check whether your computer can see the external drive:
1. Right click My Computer and select Properties
2. Click on Device Manager
3. Expand Disk Drives by clicking the arrow on the left side of it.
Is the IOmega in the list of the disk drives?
If it is, then it is either:
1. The drive is faulty and the ID is from the IOmega controller
2. The drive is ok but severe bad sectors or other failing components prevent the drive to mount.
Testing the External Drive.
Listen closely to the if it sounds like it's spinning or it's doing something.
1. Clicking sound - The hard drive inside the Iomega caddy is faulty, either the pcb or heads, or both
2. Scraping sound - There is a platter damage on the drive. Recovery not possible.
3. No sound at all - Problem with either drive's pcb or the Iomega controller.
If your drive behaves like one above, I suggest you send your hard drive to data recovery companies.
May 06, 2011 | Iomega Professional 500 GB FireWire 400...
My computer refuses to recognize the external hard drive what do i do
Hello there,
What type of OS are you running ( Windows # )
What type of motherboard
Here is what i would do to start off with,
STEP ONE - Check all connections
  1. Unplug the USB data cable from the drive and the computer.
  2. Check the ends of the USB data cable to ensure that they are not damaged.
  3. Reconnect the USB data cable to the drive and the computer. Check the connections to ensure that they are secure.
    Note: If you have a Portable Hard Drive with a 2-line USB/power cable, connect both the data line and the supplemental power line (usually marked with a lightning bolt icon) to USB ports on the computer. If the status light on the drive glows steadily, the drive is receiving power. Go to step E.
  4. If you are connecting an Iomega Desktop Hard Drive, check the power supply connections to the drive and power outlet to ensure that they are secure.
  5. Restart the computer.
  6. Double click the Computer or My Computer to see if the Iomega Hard Drive is detected.
    If the Iomega Hard Drive is detected, you can now use the drive.
    If the Iomega Hard Drive is not detected, please try another USB cable and/or power supply (if available). If the Iomega Hard Drive is still not detected, continue with the next step.
if that doesn't work go to this helpful site and follow the Steps one by one to fix this problem
https://iomega-na-en.custhelp.com/app/answers/detail/a_id/1235/session/L3RpbWUvMTI5NTk4MTQwOC9zaWQvZGMzcHNaa2s%3D
don't forget to Rate
Jan 25, 2011 | Iomega Prestige 500 GB USB 20 Hard Drive
I have an iomega 250 gig external hd. went to plug it in one day and my pc said it couldn't read any of the files. i can still see thumbnails and view photos but can't transfer any data at all. please help...
i have an iomega 320 gig external hd. went to plug it in one day and my pc said it couldn\'t read any of the files. i can still see thumbnails and view photos but can\'t transfer any data at all. please help as i stupidly put all my files on this drive. about 10 years worth of work.
Dec 02, 2010 | Iomega 33089 250 GB Hard Drive
I plug in my hard drive to the USB port, but the computer/USB port wont detect it. This happens on multiple computers
henryhan20, OK, good. Plug both of them in when using the external hard drive. The USB plugs supply power to the device as well as serve as a means to transfer the data. USB ports can carry 5 volts of power (max). If the hard drive is over 4200 RPMs then it will most likely need more than 5 volts to work properly. Try plugging both USB jacks in concurrently.
Hope this helps,
Mark
Oct 05, 2010 | Iomega Computers & Internet
I bought this 1 iomega white external drive to back up my pictures, Now the computer is not detecting it, i have already plug it in another computer and Nothing, I have very valuables pictures inthere and...
Disassemble the casing, and disconnect the USB-to-disk-drive adapter from the disk-drive.
Connect the disk-drive as a "slave" disk-drive in some computer. If you are "lucky", the computer will detect the drive. If you are "unlucky", search online for "Data Recovery Service" -- these are high-cost services that can disasemble your disk-drive, repair it just long enough to copy your files onto another disk-drive (or DVD-writable media).
Jun 15, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
My iomega 500gb external hard disk is corrupted
my pc is not showing my 500gb iomega external at all,in device manager syas all is working correctly
Nov 08, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
External hard drive not detected
http://www.makeuseof.com/tag/external-drive-not-recognized-this-is-how-to-fix-it-in-windows/
May 23, 2017 | Iomega Silver Series 320GB 3.5 External -...
Data retrieval
Find a program in utilities called "migration assistant" it is easy to use, after you have transfered the data find the disk utility, and run repair permissions.
Jul 05, 2008 | Iomega (33222) 80 GB Hard Drive
Computers & Internet Logo
71 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
