Question about Everex eXplora RS2800 PC Desktop
My everex computer has 448 mb of ram i would like
My everex computer has 448 mb of ram i would like to have 512 mb of ram
    President:
  • 1,188 Answers
Actually your computer does have 512 RAM. The 64 MB discrepancy is what the graphics memory uses. 64 + 448 = 512, get it?
If you want it to show full 512 MB, you need to install a separate video card. Refer to your PC's manual and see if it has a separate AGP or PCI-E slot.
If it has then you can choose from the many available in the market.
You can choose between having a low end low cost or a high end one designed for gaming. Just choose what suits you best and remember that a higher power card requires proper cooling and higher wattage PSU (power supply).
Note that no matter how much RAM is installed, some portion of it will be used for graphical operations.
Posted on Oct 03, 2010
I have a K7sem Rev:1.0 Socket 462 motherboard with 448 mb ram, and would like to increase if possible .
Your motherboard will support a maximum of 1GB of memory. It uses PC133 / PC100 memory in two slots (512 Mb in each one)
Dec 19, 2012 | ECS Elitegroup K7sem Rev:1.0 Socket 462...
My system doesnt see the ram i installed,(512x2) its perfectly compatible,still it only sees 448 MB out of 1024.i updated bios and everything.is it coz i am using the on-board graphics adapter?help me out...
It looks like your computer is seeing only one 512Mb RAM module. Your computer uses shared RAM - 448Mb RAM is available for the computer and 64Mb is reserved for video RAM (448 + 64 = 512Mb) of RAM.
One of the RAM modules may be faulty. To determine which RAM module is faulty, remove both RAM modules and insert one RAM module at a time to determine the faulty RAM module.
If both RAM modules are OK then -
Some computers do not like mixed RAM modules from different manufacturers. Try using the RAM modules with the same make and type/speed.
Jun 14, 2011 | Computers & Internet
Is it possible to install windows vista in this computer?
No, it needs at least 1GB of RAM and a much better video card.
Jan 16, 2011 | HP Hewlett Packard Compaq D51S Intel...
Dear Sir/Madam My notebook had 512 MB of RAM and I replaced it with a 2 GB RAM last year.It was ok but now it is so slow and the system properties show 448 MB of RAM.I do not know why? I have just chenged...
If it shows only 448 MB only means the RAM you are currently using is 512 MB only...person who changed your RAM might cheated you instead of putting 2GB RAM...And also check your laptop for any virus...
Jul 05, 2009 | Computers & Internet
Want to upgrade ram pc2700 128mb to 512 mb , so i purchased a 512mb ddr1 400mz ram and put it in parallel port but my computer does not boot so i remove the 512 mb ram but problem was as it is now what...
first you check that your ram version.... i means it is compatible with your motherboard...if still prob remains then remove your all ram insert 128 mb ram then restart the system....... upgrade ram should fallow frequency of 512 mb RAM are same as 128 mb ram freqency........if mismatch is occured then it did nt wrked correctly...
Mar 30, 2009 | Computers & Internet
Loss of Ram in D102G intel Board
hello, you just have a shared memory with the on-board ati graphics, if it's on- board graphic card it shares the system memory-most are adjustable through the system bios-in 64,128,256 settings. and if you put more memory, in most cases it will automatic-raise the memory size of the graphics memory. i hope this helps you, all the best. if you need further assistance reply. don't forget to rate this solution.
Mar 25, 2009 | ASUS P4B533-VM Motherboard
I want to play Fifa 09 on my compaq presario 2100 amd athlon xp 2800+ 2.12 GHz,448 mb ram laptop,but it does not open.I don't have any graphics card but I want to install one.Which would be the most...
Sorry to tell you this but this laptops video card is permanently attached to the mother board. So upgrading to a new one is no possible.
Sorry,
Armymason
Feb 27, 2009 | AMD Mobile Athlon XP-M 2800+, 2.13 GHz...
512 MB memory boards do not work in my Fujitsu Lifebook S2020
frquance is not set and it is not recommand that 2 different friquance ram is not working propaties
Jan 09, 2009 | Fujitsu LifeBook S2020 Notebook
I want to upgrade my HP BA 600 Mother Board`s RAM Capacity
Most likely your MB is too old for this upgrade although there is a chance you could flash your bios (reprogram your computer's brain to accept the new memory providing hp has a flash for it).
here is a link for the latest bios flash for your computer, use at your own risk.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=12454&prodSeriesId=32895&swItem=vc3903en&prodNameId=20305&swEnvOID=54&swLang=13&taskId=135&mode=4&idx=0
good luck.
Thank you,
agadycom
Nov 27, 2008 | HP Computers & Internet
Sdram capacity
its that 512 mb total capacity for your computer memory?? if so read this:
To find the total amount of RAM that can be added , subtract the amount of RAM currently in the computer from the maximum amount of memory the computer can hold. For example, a computer has 256 MB of RAM. If the maximum amount of memory the computer can hold is 512 MB, then 256 MB is the amount of RAM that can be added. this info from the HP website , to find out more , go to http://www.hp.com/support , enter the model number , and look for more information about your computer specs, hope this helps , please rate & thanks AJ
May 24, 2008 | HP Pavilion 8860 (P2941A) PC Desktop
Everex eXplora RS2800 PC Desktop Logo
111 people viewed this question
Top Everex Computers & Internet Experts
k24674
Jerry Umali
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
