I have a Dell Inspiron E1705 Notebook running WindowsXP with a DVD-RW/CD-RW drive. When I insert a DVD to play or to copy it won't work, it tells me I need a DVD decoder. How can I get one to solve this problem.
  • 7 more comments
  • g_wessely Oct 03, 2010
    It tells me I need Media Messenger
  • g_wessely Oct 04, 2010
    Windows Media player gives me the message: unable to open messenger, make sure Window Messenger is installed.
    Another message I get is: compattible DVD decoder is missing.
    How do I get these two? I do not want to install non-window programs nor 30 day trial programs.
    Media Center is asking for "Window Messenger"
  • g_wessely Oct 05, 2010
    I can copy and burn CD's I tried to copy DVD's but I can't. I can't open it sais your disc is blank. So I can't play or copy it. I works on a friend's laptop.
    I am trying to play a DVD and also copy it which requires burning. I have tried it with Windows Media Player 10 and with SONIC Solutions 7
    I installed Power DVD, it opens the disc but the sound is just awful, sort of wavy,useless. You ask if I have a DVD player, isn't there one included in Windows Media Player or Windows Media Center?
  • g_wessely Oct 06, 2010
    I tried to download K-lite mega codex pack. It will not install. I get the message "setup files are corrupted, try a new copy of the program. Have not yet installed the VLC player
    I installed K-lite mega codec pack 6.4 full. I got the Video running with Windows Media Player but the sound is bearly audible, breaking up, jerky, scratchy very low volume. I have not installed the registry cleaner, I am afraid to mess with the registry
    I ran dxdiag
    Sound: your sound card does not support hardware buffering. Sounds will only play back software buffers
    Direct music: all tests successful
    Display: No problems found
    direct dr.. successful
    direct3d 7 successful
    direct3d 8 successful
    Now I could not get in the Internet anymore. This message was written from my second computer
    President:
  • 2,777 Answers
Please confirm here for me before I help you with this problem (I am sure we can get this solved) - this is a DVD Movie you are trying to watch, is that correct? Have you been able to burn cd's / dvd's without issue with this drive?
Pleas let me know, and I will immediately get back to you and help you further,
Tim
Posted on Oct 04, 2010
Testimonial: "I told you I hav media Player and media center, both are supposed to have DVD capapility. Now you ask me if I have DVD player. You lost me"
  • 1 more comment
  • Tim Grayson
    Tim Grayson Oct 05, 2010
    Wait I'm confused, so are you trying to play a DVD and it won't work, or burn a DVD and it won't work... or both? What are you trying to use to burn the DVD if that's the case? What software I mean...
    Thanks
    Tim
  • Tim Grayson
    Ok, so you can't play OR burn a DVD... So for example if you put a retail (non-burned) DVD movie in the drive, you can't play it at all, correct? Do you have any DVD player software on the machine? PowerDVD for example..? If not that is definitely part of the problem.
    Let me know, do you have any dvd software on there?
    Thanks
    Tim
  • Tim Grayson
    Tim Grayson Oct 11, 2010
    Please if possible come back to the question here and rate it 4 thumbs. It looks like the answer helped you, but for some reason it doesn't rate it 4 thumbs unless you come back a second time and specify 4 out of 4 thumbs. I hope you will do this for me.
    Thanks
    Tim
  • Anonymous Oct 05, 2010
    Some blank DVD's will not work in different optical drives. Try a different brand of blank DVD and see if it will copy
    A lot of drives cannot copy DVD R. Try using a DVD-R blank disc instead
  • 13,433 Answers
Just download FFDShow and VLC MEDIA PLAYER.
Its extremely rare with this combination, to find a movie that wouldn't play,
get FFDShow here http://www.free-codecs.com/download_soft.php?d=5550&s=50
with ffdshow all you need to do is to run the setup file and click next repeatedly untill the setup is complete, and then just finish it, close it and its done, works on the background when movies are played.
vlc media player - http://www.videolan.org/vlc/
After you got these two installed, you should be able to play most if not all of the movies out there.
open vlc media player and then click File, dvd movie.
Posted on Oct 03, 2010
  • Ekse Oct 03, 2010
    What is asking for media messenger?
  • Ekse Oct 04, 2010
    please dont use media center, use VLC media player instead.
  • 4,737 Answers
Is there any codec pack installed on your computer? or do you have any fully packed multimedia player installed? like VLC Player or Gom Player....
First download and install the [K-lite mega codec pack], you may be prompted to configure the settings, just ignore and finish the installation, after it's completed, restart your computer and play the DVD again. Hopefully that should work.
If this doesn't fix, download VLC Media Player and install it, play the DVD with the VLC player and try again. (click here to download VLC player).
Let me know if the problem persists. We need to clean the registry entries.
Good luck.
Thanks for using FixYa.
Posted on Oct 05, 2010
  • 2 more comments
  • Lebanon Raingam
    Lebanon Raingam Oct 06, 2010
    I am sorry for the delay. Well there must be other issue with your system like registry or driver conflict or software conflict etc..etc.. I can't make sure right now since I haven't tried..........
    Try another KliteMegaCodecPack (click here), Open the link and download any one from the available lists.
    It's also important to uninstall all other media player like Power DVD, etc..etc.. except the Windows Media Player.
    I would also suggest you to run a system cleaning and a registry cleaning. I don't know whether have any system Utility software like Tuneup or Ccleaner or etc..etc.. You can download Ccleaner from here (click here), this is a freeware, once you open the link, you will see donation page with papay, visa, mastercard...etc..etc.. logos, just below the logos, you'll see two links in Pale Green color, click "Download file from piriform.com" and download the software, install it. Simply click "Next", or "Yes" or "Ok" or "finish", don't configure anything if you are asked/prompted.
    Once it's installed, open the program and click "Run Cleaner" (note: if you've downloaded files saved on internet explorer download folder, please move them to other directory or folder, otherwise you'll loose everything downloaded using your Internet Explorer). During the cleaner running process, if you are asked with a warning, just proceed forward providing positive inputs.
    Again click "Registry" and then "Scan for issues" and after the scanning is done, click "Fix all selected issues" > "No" > "Fix all selected issues", "close".
    Run the Registry cleaner twice or thrice, and do the same with the Cleaner as well.
    Restart your computer and install the Klite Mega Codec Pack or if it wasn't downloaded yet, try again.
    Let me know if you have problem.
    Good luck.
  • Lebanon Raingam
    You don't need to afraid of the Registry entries, it'll not delete important entries, only the junks and unused entries will be deleted. Please try again.
    And let me know the dxdiag result. Type in dxdiag in the run box, a new windows will open up, let me know the following informations..
    • Display
    • Sound
    • Music
    Good luck.
  • Lebanon Raingam
    Well, I hope we are closing, but I don't understand when you say you could no longer access the net from the computer. Please clarify.
    "Your sound card does not support hardware buffering...." means that your sound card doesn't support 22 050Hz Audio Sampling Rate. It'll not hamper or cause anything. If I am right, your system has VIA.... sound card/codec integrated on the motherboard.
    This time, you need to uninstall the sound drivers, graphics drivers and run the registry cleaner so that corrupted or unused entries would be cleaned from the system. Restart your computer and reinstall both the drivers.
    Once again, Good luck.
  • Lebanon Raingam
    I forgot one this, how about that VLC, same sound?
  • 4,281 Answers
It means on your laptop decoder is not installed for that you need to install vlc media player then you can play those dvd files with vlc media player. You can download vlc media player from below link. Click here
  • Click here
    click on above link then install it in laptop then play dvd files with vlc media player.
    Let me know if you need further assistance.
  • You can download dvd decoder for windows from below link.
    Windows media player 11 and download windows messanger from below link.
    Download and install then both will work fine.
Cds not playing but Dvd does?
Your optical drive is not working. you need to replace it.
Dec 06, 2017 | Dell Inspiron 9400 Notebook
Have a dell inspiron cd-rw/dvd drive combo but it does not burn dvd only cd
Your drive is not a DVD burner. The way you can tell is that it is called a CD-RW/DVD drive, not a CD-RW/DVD-RW drive.
Jun 02, 2011 | Dell Inspiron 2200 CD-RW/DVD Drive Combo -...
My burner will not burn cd's anymore. It still plays cd's fine as well as play and burn dvd's fine. I see no errors in hardware setup. It is a nec dvd +- RW ND 6650A that came with my Dell Inspiron E1705.
The CD Burner / Player / DVD Burner are all different heads. If the Dell Inspiron E1705 is an older model it is most likely you have reached the end of it's usable life for the CD burner part. If it is new the CD burner is most likely defective and hopefully warrantied. Otherwise these CD/DVD units can be replaced relatively inexpensively (as compared to buying a new laptop).
Feb 01, 2011 | NEC ND-6650A DVD RW Dual Layer Burner
0F00:136C IDE device failed:blank media or no media is present in optical drive
read failure of the CD\DVD drive. If you were running diagnostics and have no readable media in the drive, that is a NORMAL result.
If you have readable media in the drive, try reseating the drive and try to read again. If the media is not a factory burned CD, try a factory burned one.
See if you can boot to an Windows CD.
If all the above fail, then likely a drive failure, replace the drive
http://cgi.ebay.com/Dell-Inspiron-E1505-6400-6000-E1705-DVD-RW-DVDRW-Drive-/170505381668?pt=PCC_Drives_Storage_Internal&hash=item27b2e9a724#ht_3121wt_1137
Sep 25, 2010 | Dell Inspiron 6000 Notebook
Inspiron E1405 not able to burn dvd
The inspiron e1405 notebooks were shipped with 2 different types of optical drives:
8x dual-layer DVD+/-RW
24x CD-RW / DVD-ROM
the later will not write DVDs
May 27, 2010 | Dell Inspiron E1405 Notebook
Won,t play cds but will play dvd,s
does it read the disc when inserted? If not, then you need to get the drive replaced. That is one of the many services we offer. Please call us at 800-595-3564.
Jan 18, 2010 | Dell Inspiron E1705 Notebook
Dell Inspiron 8600 Cd RW/DVD has stopped working
this problem occurs when the lens of the drive gets weak or broken
you can either buy a new drive or just get the lens of the old drive replaced
yes its possible to replace a cd rw/ dvd drive with a dvd rw drive
Sep 29, 2009 | Dell Inspiron 8600 Notebook
DVD not recognized
do check if dvd-rw drive supports the dvd you want to burn to ( either dvd+ or dvd- !)and do use a freeware burnprobgram like burnatonce instead of the build-in windows one...
burnatonce will tell you all about your drive (see tools - device info) and the disc you've put in!
happy burnin'
Aug 04, 2009 | Dell Inspiron 1501 PC Notebook
Dvd r/rw on Dell E1705 laptop computer quit playing cds and dvds. Makes grinding start up noise but does not play
Your system comes with on-board diagnostics. Run the diagnostics to check if the problem is with the drive or windows.
To run the diagnostics follow the steps below
1. Shutdown the system
2. Press the Fn+Power button together
3. The screen will display color screens
4. Follow the prompts until it takes you to advanced diagnostics
5. Do a custom test on the optical drive.
If you are unable to run the diagnostics
1. Find the dell resource cd that came with the system
2. Insert the cd in and restart the computer
3. At the Dell logo screen press the f12 slowly 5 times
4. Select boot from cd/dvd drive
5. Press any key to boot from cd .... message appears press enter
6. If the system starts from the cd .. this would mean the drive is ok
pOst back what were the diagnosis
Thanks
proton
Apr 11, 2009 | Dell Inspiron E1705 Notebook
When i try to copy dvd it keeps telling me to insert blank disc even though one is in there i can burn cds but not dvd it tells me to put in writeable disk and ive put in dvdr-w and dvd-r and still it...
Go to the device manager to insure your optical drive is in fact a DVD/RW. You should also be able to tell by looking at the front of the drive and see what it says. If it says CD Writable or DVD Rom, you cannot do it. Kind of sounds like you have a CD/RW-DVD Rom combination drive, which does not allow the burning of DVD's.
Let me know, OK.
Mar 15, 2009 | Dell Inspiron 1501 Notebook
Computers & Internet Logo
391 people viewed this question
David Payne
David Payne
