Question about Panasonic PT-61LCZ70 Television
Bulb does not turn on until it has run several cycles and I have restarted it several times. 3 red flashes.
    Problem Solver:
  • 6 Answers
You are having a internal overheat error,sounds like your fan or lamp is going, sorry but this is just the begining with this model.Call panasonic and start complaing now, if enough of us get together maybe panasonic will step up to the plate.
Posted on Oct 18, 2010
Toshiba 62hm84 dlp
Sounds as though the system may have overheated. Do you regularly check the filters and clean them? An airduster can also help to blow dust out of hard to reach places.
Apr 14, 2014 | Office Equipment & Supplies
Tip
How to fix your gas furnice
most gas furneses have a red light on circuit board wich is located on intake. turn heater off then have someone turn it back on while you watch the circuit board. count the # of times the red light flashes before it pauses. it will flash in a cycle. for instance it flashe 3 times then pauses for 5 secounds then flashes 3 times again on and on. look on the back of the panel cover,their will be a diagram, in the diagram their will be dianostic report that will include what that # of flashing red light and what it means. for examle 3 flashing red lights ps stuck open. that means pressure switch stuck open. replace the part and your back up and running.
on Dec 18, 2009 | Heating & Cooling
Just replaced the lamp, worked for about 3-4 days, tv won't turn on, green light flash about 3-4 times then a red light flashes, waited about two days, tv came on and worked for about 1 month now the same...
I have the same TV and had same problem . Try taking the bulb and assembly out and reinstall , there are some sensors on the assemblies that might not be getting good contact . It fixed mine .
Jan 20, 2011 | Sony KDF-50E2000 50" HDTV
Hi, About 3-4 weeks ago I replaced the bulb on my
I am having the same problem as mg2low. I changed the lamp, but my Sony KF60WE610 still will not turn on. It flashes green several times then it begins to flash red. Can you recommend some trouble-shooting for me? Thanks, Richard
Sep 05, 2010 | Sony Grand WEGA KF60WE610 60" Rear...
Panasonic LiFi model number PT-50LCZ70. Have red lamp light flashing on front 2 times. Have tried to turn it on and get no picture and no sound at all. I checked and the fan is running. What now?
After the red 2 flashing starts, press the power button on the front of the TV and hold pressed down for ten seconds.
You will hear a faint click comming from the back of set.
After 10 sec release the button and wait 10 more seconds then press the start button and release right away.
The green light flashes and the bulb attempts to start.
I found my picture will turn on on the third attempt of the bulb restarting.
When you do this and the room is dark you can see the bulb attempt to restart, My bulb has restarted on the third restart every time.
(note: The three start attempt happen after I do the button pressing
1 time and I do not need further button pressing restarts.
I think panasonic needs to let us know what the problem is.
I called Panasonic and they told me to plug it into a wall plug by itself.
I have it plugged into a multi plug adaptor now and have not tried this yet.
Nov 06, 2009 | Panasonic PT-50LCZ70 50" HDTV
Panasonic PT-53TWD63, TV will not turn on, Red power light blinks
It is most deffinately a convergence chip issue. The die for no reason. They can be bought online for around $10 dollars and anyone with experience with soldering can replace them pretty easily. I have done it.
Feb 03, 2009 | Panasonic PT-53TWD63 53" Rear Projection...
Projector will not project light (Mitsubishi LVP-X80U) LCD Proje.
Hello toma_leonard,
First check your lamp to make sure it is seated properly in the socket.
Then check all of your interlocks (see your manual for locations), these are usually located on any hatches or doors that allow access to the lamp and or fan area. Once you check your interlocks make sure the filter and fan area is clear of dust, (some projectors have air flow sensors), and the recheck the interlocks. Once this is done , If the interlocks are not broken, or the lamp fuse blown, the projector should be working. If not it is the lamp that needs changing.
I know this may be expensive, however these lamps do go bad, as much as we wish they would not.
If you still feel it is not the lamp, have a technician check the voltage levels to the lamp and the levels of the control board circuitry.
I hope this helps,
Thank you,
Shuttle83
Nov 20, 2008 | Mitsubishi LVP-X80U Multimedia Projector
LG DLP not turning on
well i know what the problem is... if your getting the white scroll and then the red light flashes but the fans are comming on and you got a new bulb the broblem is the ballast. i know cuz i had the same problem and a good friend of mine has a tv shop and i had him look at it but the good news is that its not that hard to change. if you try to go through LG thay wont be able to sell you the ballast if your just a coust. good news is that you can fined the ballast on ebay from s.gifeasywaylamps its about $130.00 bucks shiped. bad news about is that thay are from china(it is where i got mine) but it works great and hasent gave me a broblem yet. if any one eles has the same problem and it was something eles.... PLEASE POST IT. i hope my info has been helpful to someone.... thanks Brad Ross of East Moline Illinois... you can email me at plopit40@yahoo.com
Nov 11, 2008 | LG 52SX4D 52" HDTV
Sony Wega 55" Replaced Bulb TV still does not work
Hello, please check how many times the red light flashes. If it is 3 times this means that the lamp cover is not fastened securely. If the red light flashes 5 times this means that the lamp driver is defect. If you need more help please advice
Apr 20, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Panasonic PT-61LCZ70 Television Logo
61 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
