Question about Delta 31 - 255X X5 18'' x 36'' Drum Sander
I'd like to download a manual for the Delta 1" Belt/5" Disc Sander I just picked up at a yard sale. I can't seem to find one. Thanks.
  • 2,176 Answers
You might try going to dewaltservicenet.com and typing in your model number in the middle of the page towards the bottom under need a manual. If not let me know and I will try and locate another source for you.
Posted on Oct 03, 2010
Need the size and thread pitch for my Delta disc/belt sander wheel set screw
Probably an 8-32 or 10-32 (possibly a 10-24) or even a 1/4-20. You can get small packs of these size screws at most hardware stores so would be cheap to busy one of each and try and once you know the size you can get a set screw of that size. Another crude way is to see what size drill bit will fit into the threaded hole. If a 3/32" goes but a 7/64" doesn't or fits tight, it is a size 6 (likely 32 threads per inch (TPI). If a 1/8" bit goes but a 9/64 doesn't or is really tight then it is a # 8 size. (8-32 is most common). If the 9/64 goes freely but a 5/32 doesn't it would likely be a 10-24 whereas if the 5/32 does go but an 11/64 doesn't then figure it to be a 10-32. Finally, it could be a 1/4-20 if a 3/16" bit goes but a 13/64 doesn't or is fairly tight. If it is really big and a 1/4" bit fits the hole then it is likely a 5/16-18.
Apr 18, 2015 | Delta 4" Belt 6" Disc Sander 31-460
How to fix motor delta belt disc sander
What is it doing or not doing, when u turn on the switch, either the switch or motor is probably bad or you have too much tension on the belt.
Aug 22, 2014 | Delta 31 695 6" Belt/9" Disc Sander
I need an owners manual for a Craftsman 6" x 9" Belt & Disc bench top electric sander. Where may I go to "download" a copy. The specs for this sander are : 6" x 48" belt at 2700 FPM ...
Go to: Searspartsdirect.com and enter the full code number minus the decimal point. That will take you to a series of drawings with parts lists. Hopefully, they still list the owner's manual. Good luck!
Aug 04, 2010 | Garden
Delta disc and 1" belt worled yesterday, not today. I turn the switch on and the disc "twitches" and the motor hums. I can turn the disc by hand so it's not jammed. Belts are good. Any ideas???
the motor has lost its polarity it uses magnetic electric polarity to turn around. the fault is just as bad as a burned out motor you could have the motor rewound but it would cost more than the entire unit..
sorry
take care.
Aug 03, 2010 | Delta Machinery 1" Belt and 8" Disc Sander
My delta sander stalls while sanding on the belt.
Mine was underpowered from the get go. I have since sold it. Keeping it well lubricated does help though.
Jan 23, 2010 | Delta Machinery 4x6 Belt/Disc Sander
31-735 delta belt/disc sander - dust collection nightmare
The belt cover that does down the front of the belt, below the table, should have an opening inside the baes/vacuum unit. Make sure this isn't clogged with buildup.
Jan 27, 2009 | Delta 31 735B 6" Belt, 12' Disc 3 Ph...
Delta 31 - 255X X5 18'' x 36'' Drum Sander Logo
129 people viewed this question
Top Delta Tools & Hardware - Others Experts
Jim London
Jim London
Andrew Taylor
Andrew Taylor
Are you a Delta Tool and Hardware - Other Expert? Answer questions, earn points and help others
