Question about Samsung ML-3471ND Network Mono Laser Printer
Duplex jam error in samsung ml-3471ND - Samsung ML-3471ND Network Mono Laser Printer
SOURCE: Paper Jam when using duplex function - Samsung ML-2551N
Check underneath printer.
Posted on Nov 10, 2009
SOURCE: Paper jam error
After I looked online for a solution I contacted the manufacturer and was advised to return the unit for repair.
Posted on Feb 12, 2009
  • 19 Answers
SOURCE: My Samsung ML-2151 NT won't duplex anymore, after
ensure you have the correct driver installed. it may have a slight variation in the driver name for duplex printing. ie. the driver name may be ML-2151NT-D.
Posted on Jul 15, 2009
markzbylut
  • 64 Answers
SOURCE: After freeing a paper jam on my Samsung ML 1750 the On line/error
Frequently a very small scrap of paper is caught in the paper path. Take out all the trays and the toner cartridge. Then look very carefully with a flashlight for the smallest scrap left behind.
Posted on May 12, 2010
caroldon
  • 17130 Answers
SOURCE: Sumsung ML-3471ND Paper jam 0 problem
This seems to be fault in the transport of the paper in the rollers. So if you have used any adhesive sticker printing, it is possible that some glue has got clogged into the rollers. If not there can be some jammed paper in the rollers or the mechanism.
So start this work only if you are mechanically able with the right tools.
Remove the covers to get access to the mechanism . Remove the motor drive assembly , the fitting of the motor to the mechanism. Once this is removed the rollers can be turned manually so that you will be able to feed a paper to see the progress of the movement while studying if there is any obstruction or damage to the paper.
There is a in-detect sensor, usually an opto-coupler , make sure this is not clogged or dirty as this IR detection feeds the signal to the processor for starting the motor drive feed.
Reassemble but make sure the rollers are aligned to be in equal gap to feed the paper without a side pull. Now you must print and see if the fault has changed. If not repeat the above work to confirm the area of obstruction.
Posted on Oct 28, 2010
Low Heat Or Open Heat
Dear
low heat error means the temp. of fusser assy. was not achieved during the specified time. some times occur during low voltage supply and reset after s/w OFF-ON.
Open heat error means there is no electrical connection to the heater heater of the fusser assy. It has tob either repaired or replaced with new one. mostly the thermostat is responsible.
Thanks.
Aug 18, 2014 | Samsung ML-3471ND Network Mono Laser...
All door closed but give error door open
CHECK THE ALL DOR SENSER &CLOSSE THE ALL DOOR PUSH STRONGLY
Apr 01, 2014 | Samsung ML3471ND, SASML3471ND - ML-3471ND...
Show the photo of paper pickup assy of samsung ml 3471nd
Hi, what is the problem you face? Always has paper jammed?
Dec 17, 2013 | Samsung ML-3471ND Network Mono Laser...
Appear duplex jam at display samsung ML-2150
Lubricate all gears and shafts inside the machine. There is an idle gear on the top back motor "where the paper comes out" the nylon it is made of shrinks causing the gear to seize on the shaft resulting in jamming. Super glue the fuser output rollers to their shaft. the rubbers on the output roller expand and slip when heated (usually after printing a large document) printing one page then resting/cooling down the problem doesnt occur. the idle roller on the duplex feeder also breaks off.
Jan 06, 2011 | Samsung ML-2150 Laser Printer
Oct 28, 2010 | Samsung ML-3471ND Network Mono Laser...
Samsung ML-3471ND Network Mono Laser Printer Logo
1,246 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
