Question about Zanussi F1245W Front Load Washer
Zanussi F1245W not spinning, it tumbles a bit then starts to pick up speed but suddenly stops, it does this twice on either spin setting and then advances to the end of program. The rest of wash program seems to operate normally, I have checked the motor brushes and they have about 20 mm extension available when removed and there are no obvious problems on the circuit board, pump is running and drum emptying etc.
Hi airflow_grp
sounds like you have the same problem with your machine, if i get a fix ill post you the solution, on this site. .........andy
Posted on Oct 10, 2010
Zanussi aquacycle1200 F1245W When cycle advances-gets hung up on spin.
Hay Jim , sound like you need to replace ccu (main control board )good luck ,APPLIANCES R EN
Feb 26, 2013 | Zanussi F1245W Front Load Washer
Zanussi Aquacycle 1200 Model F1245W wont drain. I cleaned filter. Removed pump and tested if off line and it spins so I am presuming that the pump is not getting power. Is this a PCB/Timer Main Board...
We cannot say if the timer is problem without inspecting the wiring to the pump.
Consider an power supply wire to the pump is broken , then even if the timer is good it wont get power.
Sep 05, 2010 | Zanussi F1245W Front Load Washer
M/c won't spin
Take off top and rear half of machine cover
remove belt and spin drum by hand, (does it spin freely?)
make sure pump and drain hose are ok (clear)
there is a plastic ball (about egg size) in hose from drum to pump.
check motor brushes are at least 3cm long
if you have checked all these but the fault persists email me on andynj42@yahoo.com
Feb 09, 2010 | Zanussi F1245W Front Load Washer
Washing machine not spinning properly
indicates that the suspension rods ( top loader ) or bearing supports ( front loader ) need replacing as the bowl is not level
Jun 24, 2017 | Zanussi F1245W Front Load Washer
When my zanussi aquacycle 1200xc is on the fast spin cycle the spinning drum seems to be getting noisier of late.
Probably the main bearings are going, spin the drum by hand, there should be little or no noise at all, if it feels rough, or noisy, then bearings are failing.
Please rate my solution.
Thanks.
Oct 10, 2009 | Zanussi F1245W Front Load Washer
Noisy and Oil Marks
bearings have failed. replacement is quite a hard job if you haven't done it before but parts quite reasonable. let me know if you want to go ahead and i can give you some instructions
Jul 12, 2008 | Zanussi F1245W Front Load Washer
My Zanussi F1245W Wont Drain or Spin
Check the drainpump. It could be burned og blocked.
Jan 20, 2008 | Zanussi F1245W Front Load Washer
Zanussi 1245w fails to spin
suspect it may not be rotating on wash either. check the moor brushes
Mar 30, 2007 | Zanussi F1245W Front Load Washer
Zanussi F1245W Front Load Washer Logo
232 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
