Question about Sony Grand WEGA KDF55E2000 55" Projection HDTV
Replacing Thermal Fuse in Sony Grand Wega KDF-E55A20
I had the same problem of the power light blinking red six times and saw how you fixed the problem by replacing the thermal fuse.
I have now ordered the new thermal fuse from Sony and in preperation, have removed the bulb through the front and the rear access panel and fan.
It looks to me that to remove the old thermal fuse, I need to remove two screws. But there is only about an inch or so clearance above the two screws, so I do not see how I will be able to remove the old one. Do I need to remove the old one? If so, how were you able to remove the old one?
  • Anonymous Jan 13, 2009
    how to install thermal fuse
Blinking red power light 6 times. Tv picture goes on and off. Then the red lamp light came on? Now nothing.
Posted on Jan 19, 2010
  • 320 Answers
The PROPER way to replace the thermal fuse is to remove the optical block first. There are at least two recessed screws holding the block in place. BE VERY CAREFUL removing the block as it is very easy to tear/rip wires when doing so. I cannot emphasize enough NOT TO JUST THROW THE NEW THERMAL FUSE INSIDE THE CABINET!!!! The thermal fuse is a safety device mounted near the lamp to prevent overheating. Those that choose to just let the fuse "sit out in the open air" are risking greater failures and the possibility of fire.
Posted on Oct 19, 2008
Why is power application erratic?
That is a Thermal Fuse. IT is behind the area where the lamp is. How to change the thermal fuse on sony kdf e60a20
This video is for a different model but its the same idea as yours.
Jun 08, 2015 | Sony KF-60WE610
My Sony Grand Wega KDF-E55A20 will not turn on with the remote or manually. The red light flashes 6 times then off.
6 times is the lamp thermal fuse or lamp. its a thermal that sits on the bottom of the lamp area.
remove the fan and you will see the siler disk with black base cut the wires and slide the new one in on the side secure it on the old thermal and your fixed.
Nov 04, 2010 | Sony KDF-E55A20 55 in. LCD Television
The power red light keeps flashing six times
The blink code means that something on the board is over current/over voltage. It could be an overload of the +5 line (A/B boards) or the +5 line is shorted.
The TV needs to be opened up and the boards checked. You may be lucky and only need a thermal fuse. Also check your bulb.
I hope this helps.
Apr 26, 2010 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony Wega Tv powers on w/ green power light and
need to know how many time the red light is blinking there should be a pause. 4 blinks is a fan, 3 blinks is the lamp door is not closed 6 blinks is thermal sensor.
Apr 22, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
I have Sony TV model KDF-42WE655 which stopped working. No display and when powered on, the green light comes on and blinks approx 50 times and turn red (blinking red). How and what do I need to buy to fix...
Its not the green light that you should be count but the red. How many times is it blinking? Here is a quick update of the errors that are most common.
3x - Lamp switch not engaged
4x - Fans issue
5x - Lamp
6x - Thermal fuse
Dec 15, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Does not turn on.
The Six blinks mean that the thermal fuse needs to be changed.
Jul 07, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Picture will not come on
Most likely the thermal fuse has gone bad. Sony part # 191002393 Prett cheap part and east you replace.
May 18, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Sony grand vega 55" will blink green for three times than red blinking under the power light. nothing comes on no sound, no picture and no fan's are running. Tried to change the bulb, power board...
Your problem is your thermal fuse.It is located around the bottom of the compartment that houses the lamp. You will have to remove the lamp and take the bottom back panel off. Then you will have to remove the fan. I ordered the thermal fuse so I would know what I was looking for when I started to replace it. If you take your time and are patient enough you can fix it yourself. I fixed mine and it's working great.GOOD LUCK!!!
May 15, 2009 | Sony KDF-E55A20 55 in. LCD Television
Sony Grand WEGA KDF55E2000 55" Projection HDTV Logo
5,899 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
