Question about HP Deskjet F4180 All-in-One InkJet Printer
The printer is showing E and it is nort printing any thing although the ink cartiges are full so can u plz tell me what is the problem n what to do with it? thanks alot.
  • HP Master
  • 7,733 Answers
Uninstall / Install / Restart Use the CD and set the printer again.
Post back!
Posted on Oct 03, 2010
My "ink not sufficient" button is blinking but the
Hello
I believe the ink cartridge should have ink but not sufficient for printing, if the cartridge is expensive why dont you re-fill it, re-filling is very low cost option.
Also clean the contacts of cartridge from both ends.
Hope this helps, if so do rate the solution Good Luck
Jan 11, 2011 | HP DeskJet 990cxi InkJet Printer
Epson Stylus C84 prints every other line.. Cleaned print heads and ran nozzle check...still same problem.
Your printer head may be booked. Follow the instruction given bellow:
1. Open printer cover and put off cartige from cartige chamber.
2. Take a plastic seringe with full of ink and fit it on head's stick. Then push ink carefully.
use this procedure one after another . I thing you may relive from your problem. thank you.
Aug 17, 2010 | Epson Stylus C84 InkJet Printer
Why does my printer notrecognize the ink?
follow the mentioned procedure:
1. click start manu
2.open fax and printer
3.double click the effected printer icon
4.there will be show some print order, delet all the print order, then restart your printer.
solution-2
if you use continuous inking system, push out all the ink cartiges from the chamber. then clean the conected area and set the cartige again perfectly.
Feb 05, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I got my ink cartridge refilled but it's still saying its empty, how do i get it to print anyway?
So as MUKHTAR states, do not refill cartiges when they are TOO EMPTY as most of the new printers have a sensor in the cartige that tells when it is empty. and when that sensor fills that the cartige is empty, it stays that way, no matter how much you refill it.
on the laser printers, when you refill your toner cartige there also is a chip that is changed (the sensor) because once that sensor feels that the cartige is empty you will not be able to use that cartige anymore.
Nov 26, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Black ink is not working but cartridge is full.
You may need to remove the protective sticker, if you've done that already, try cleaning the print heads, they sometimes get clogged... Best of luck!
Sep 16, 2009 | HP Officejet 5610 All-In-One InkJet...
U051 .. u162
Those are cartridge errors, the chip on the front tells the printer how much ink is left, when you refill, you also need to reset or replace the chip on the cartridge, or you will keep getting errors.
Aug 24, 2009 | Canon PIXMA MX310 All-In-One Printer
Can you tell my printer cartiges was finish i refil new cartige and put in the printer but printer does not work only for printing from computer but fax is working photocopy is work and sccaner is also...
Please follow these tips
1. turn off your printer for one menu t and then turn it one.
2. You should charge your ink the option may be in your Pinter software or there should a button in your
Pinter to charge your ink.Press
OK to begin charging the ink.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}you need to disable the ink level monitors afterre-filling the cartridges. go to properties, maintenance, view printer status,option and click enable status monitor once
Nov 22, 2008 | Lexmark Office Equipment & Supplies
Ink cartridge problems
The printer is working again - I exchanged the ink cartridges yet again, and finally the printer accepted them. Still don't know why the problem developed.
Apr 28, 2008 | HP DeskJet 5150 InkJet Printer
OK-has anyone solved the 924 ink reset issue.
I have the same, problem. the printer is a piece of junk
Mar 01, 2008 | Dell 924 All-in-One InkJet Printer
Dell color cartridges
this sounds wierd to tell you
take out the cartige and if you can take out the cartige holders ( try to reach for the place where the ink flows out) spray it with a glass cleaning solution and let it pass inside where the ink pases and believe it or not it will clean properly the ink passages. try to clean the bottom of the cartige too.
some 1 trid it infront of me and it worked.
ps: an unproper positioning of the cartige will cause the printer not to work.
Nov 09, 2007 | Dell 924 All-in-One InkJet Printer
HP Deskjet F4180 All-in-One InkJet Printer Logo
Seeker5211
Seeker5211
