Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore HE3 front load washer. No power, no lights on panels. Cord socket and house circuit panel ok. Fairly new, not much wear, working fine till today.
SOURCE: kenmore front load he3 washer: door wont unlock
happened to me once - I just unplugged the machine - waited a minute and plugged it back - it - then used cancel button
Posted on Mar 02, 2009
fanny
  • 146 Answers
SOURCE: my Kenmore washing machine he3
The water inlet valve/solenoid on the machine may be faulty and letting water pass through even when it is supposed to be shut. Try turning the water off to the machine every time after you use it and if water stops going in while its off, replace the inlet valve/solenoid.
Posted on Nov 03, 2007
SOURCE: Kenmore Elite HE3 washer
I found when mine doesn't drain there is a sock blocking the drain holes. Open the door and pull out the rubber gasket at the bottoma nd there should be around a half a dozen holes. Good luck!
Posted on Feb 21, 2008
SOURCE: front load washer door won't open
There is an override switch directly below the latch under the machine on most front loaders.
Posted on Jan 24, 2009
DrakeTech
  • 61 Answers
SOURCE: how do i open the front panel of my Kenmore Elite
To access the front panel, or to take it off persey, you would have to remove the top of the unit, this isnt hard as it is fasted by a few screws in the back and you slide the panel back and then you will have access to the front panel mounting screws and remove those to remove the front panel.
DrakeTech
Posted on Feb 24, 2010
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
LG Washer wont start, no power
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
Jun 21, 2009 | LG WM-2277HW Front Load Washer
Check Pump on front loader kenmore HE3 elite
Remove the lower front panel 3 screws across the bottom. Pump will be behind this panel.
May 26, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3 front load washer the control lock is on and I don't
Look close at the panel.... it will tell you what button to hold in for 3-5 seconds
Good Luck!
Feb 24, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 front load dryer no power
Yes. Remove the kickplate and check the continuity of the thermal fuse located on the blower housing.
Feb 23, 2009 | Kenmore Dryers
Front load washer door won't open
Jan 24, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore he3 not heating
REMOVE 2 SCREWS ON BOTTOM OF PANEL,, REMOVE LINT SCREEN , NOW REMOVE BLACK METAL HOUING ,,,DISCONNCT POWER BEHIND METAL HOUSING THERMAL FUSE IS RIGHT THERE REPL ,NOW SHOULD HEAT UP ,,,2 RED WIRES CONNECT TO IT
Nov 23, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore HE3 WasherManual?
Click on your model number (below FIXYA) on this website, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, u hv your manual on line. If available that is..
Apr 13, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
HE3 Front loader Controls Locked
Try 'end of cycle' pushed down till the light goes off. Or locate the button with diagram of 'lock', & push down till the light goes off.
Dec 24, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
566 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
