Question about RCA D52W19 52" Rear Projection Television
RCA 52" Screen
I was cleaning my TV and lifted it and did something to the inner screen. It appears to be pushed in at the top and there is a dip in it. It kind of caved in a little. Now the screen is blurry. It looks as though I could even it out by popping the back off and just pushing the screen back towards the front of the TV. Any advise on whether I would make things worse?
Thank you I will give it a try:)
Posted on Jun 03, 2008
  • 927 Answers
It may not the easiest job but take the off the front cabinet assembly, lay it on a flat surface(like the floor) with blanket. Please be careful those screens are about $150.00 each.
Posted on Jun 01, 2008
Rca tv is blurry
2 types. If wooden top rail of screen surround: remove end screws of top rail by removing caps over screws on upper front sides. Remove the two screws. Remove top wooden screen bezel piece. Now pull up and out screens. If sceen surround is plastic one-piece all-around: remove speaker grill board. Remove screws along lower front of screen bezel. Pull bottom of screen bezel out a 1/2 inch. Lift up on screen bezel to remove entire screen assembly.
May 06, 2010 | RCA P52926 52" Rear Projection Television
How to remove screen on projection screen tv 56"rca model#p56926
Remove the speaker cover on the front, it just pulls off. Pry each side a little at a time. There are 4 screws that hold the screen on. Remove them and the screen just lifts off. There are wires attached to the controls so, keep that in mind when lifting the screen.
Aug 10, 2009 | RCA P52926 52" Rear Projection Television
How do i take the screen off for cleaning
Pull off the speaker grill. Remove the 4 or so screws along the bottom edge of the screen. The screen will do one of two things: Either it will lift about two inches and then it will pull straight off, or it will hinge out from the bottom about 8 - 10 inches and then it will lift off the hinge at the top.
Aug 02, 2009 | RCA P52926 52" Rear Projection Television
Sansui Projection TV - RCA D52W23 52 in., Problem is tv gets turn off automatically after few minutes. It doesnot off but a blue screen with lines appears immd.., it takes long time get the picture on...
CK for Bad capacitors cp114,120,150 if any of them is puffed up on top it is bad so replace all 3 cp150 is 2200uf 16v other two are 220uf 35v also resolder all pinns on FBT flyback transfomer.
Jan 23, 2009 | RCA D52W23 52" HDTV CRT TV
52"RCA HDTV projection TV
take the back off and you will have access to the top mirror and the screen mounts. with those removed you can then clean everything...unplugged .
Dec 08, 2008 | RCA D52W23 52" HDTV CRT TV
Cracked Screen Protector
what is the model number for you set. is it a hd52w56 or something like that. on that model it is called the super sheild. is the inner screens damaged.. if just the outer screen that runs 200 or more. i have seen people just replace the plexiglass on it. the inner screens run about 250
Nov 09, 2008 | Televison & Video
RCA 52inch Big Screen.
On your remote push "Info" then push right or left to get OFF zoom mode, Cinema view looks pretty good.
Jul 20, 2008 | RCA HD52W56 52" Rear Projection HDTV
Screen removal
Screen Removal
There are two types of screens used on this chassis.
Model 1 - with one piece frame around screen.
1. Remove the front grill cloth assembly and remove four
(4) screws along the bottom of the screen frame.
2. Pull out slightly on the bottom of the screen frame and lift
up and out on the top of the screen frame (and screen) to
Model 2 - with wood piece securing top of screen.
1. Remove the screw access cover plug from each side (near
top) of the TV and remove one screw from each side.
2. Pull up on the wooden strip and remove.
3. The screen can now be lifted out of the tracks and
Jan 21, 2008 | Televison & Video
RCA D52W19 52" Rear Projection Television Logo
50 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
