Question about Dishwashers
When dishwasher is off and I cleaned the filter, I noticed water in bottom of filtering system. Is this normal?
  • 3,361 Answers
Yes. some water is always retained there.
Posted on Oct 03, 2010
Salt holder full of water
Hi Elizabeth
have had a dishwasher for many years and have found this to be a normal practice .... Hope this puts your mind at rest ????
Mar 20, 2016 | Dishwashers
When i clean the filter i notice that there is water left in the filter hole .is that okey
How much water should I expect to be left in a dishwasher ...
diy.stackexchange.com/.../how-much-water-should-i-expect-to-be-left-in...
May 15, 2011 - After every load there is always some water left in the bottom of the drain basket/filter. It's not up into the dishwasher itself, but when I reach into the filterto clean it, there's always water in it. ... I did notice some string and guck wrapped around my food chopper blade .... Making holes in 3D objects (Unity).
Cleaning a DE Filter - Troubleshooters.Com
www.troubleshooters.com/pool/de_filter_cleaning.htm
Make sure the hose has no large holes, and that it's tightly secured to the waste ...Water is pumped into the filter housing at high pressure, it passes through the DE ... He has cleaned the center, but the left and right sides have not yet been .... Is there a pool store open that will help you reassemble, assuming you drive all ...
Dec 29, 2015 | Dishwashers
Should there be a little water left in the dishwasher
yeah there should be a bit but the bottom should also have dishwasher salt in there. this is the bottom. the salt helps kill smells also helps cleaning. when you bought the dishwasher it should of come with a funnel thats for filling the salt into the system.
Jun 08, 2017 | Frigidaire FGHD2433K 24 in Builtin...
Dishes are not getting clean
Hi there.
In the bottom of the dishwashers is normally a filter with a handle on it for easy removal. pull it up, gently, you might have to turn it slightly from side to side to loosen it if it is very dirty. When this filter is out you will see another filter that is just lifted straight up and on that one you might find a lot of dirt.Put both filters in a 10 liter bucket with on cup of chlorine(diluted to 5%) to 5 liters of water. Pour some chlorine( 2 cups) into the bottom of the machine, and close the door and let the machine run on its hottest cycle until finished. When the machine is finished, rinse out the filters in the bucket with warm water. Brush the rest of the dirt off and replace them where they were. Run the machine once again, now on a normal cycle with the dishes in it and I believe they will be clean.
Iceman.
Nov 04, 2009 | Maytag MDB7100AWB Dishwasher
Clogged dishwasher drain?
clean the filter, check the water inlet and outlets for blockages
Jun 29, 2009 | Bosch SHU9915UC Dishwasher
Water is left in the cavity beneath the base filter
water under the filter is normal. Most diswashers do not drain completley- this acts as an air lock to prvent odours coming thru the drain hose
Jun 29, 2009 | GE Nautilus 24" Built-in Dishwasher
No pressure during wash cycle
Motor pump has gone out. pump needs replacing. the unit needs to be pulled out inorder to access the pump. the sides of the d/w must come off.
Jun 09, 2008 | Dishwashers
F8 is flashing. The drainage well in the bottom of the machine is full of water, so much be blocked somewhere.
It could either be the filter (most likely), the drain pump (likely) or the drain hose/tube (least likely).
Normally, there would a filter somewhere at the bottom of your dishwasher with the primary function of keeping large particles of food and foreign objects away from the impeller/pump. Most current dishwashers have self-cleaning filters and therefore regular cleaning is no longer a concern. However, some other dishwashers need to have the filter manually removed and cleaned regularly or as even in your case. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher and may cause the problem as you have described.
To check the filter and/or the drain pump, the bottom has to be exposed, the filter/pump located and cleaned.
There are pages online with illustrative description and detailed procedures on how to go about this. Perhaps you can try referencing here and/or here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 24, 2008 | Whirlpool Dishwashers
Water is not draining out of the dishwasher
Apr 25, 2008 | Dishwashers
Dishwashers Logo
Top Dishwashers Experts
