Question about Kenmore Heating & Cooling
Dehumidifier model#580.54501 50 pint,kept turning on and off avery few minutes,filter is clean and i do not see ice foeming on coil,can you give and help, bob kap
Sent my just $9.95 and i will tell you how i fixed the problem
Posted on May 27, 2008
My Kul Dehumidifier filter keeps freezing up? is there anything I can do to keep this from happening?
Turn the knob to a lower setting so that the unit cycles on & off. This will give it time to warm back up and melt the ice in between dehumidifying runs.
Aug 30, 2015 | KUL 50 Pint Dehumidifier"
There is ice on the filter and the filter will not come out. Tried turning off so it would melt, but filter still stuck. It is summer so why is ice forming?
I have had a AD75UST0 WHIRLPOOL Dehumidifier for several years. I had mine ice up once or twice particularly on very high humidity days > 90%. Once it thawed out. I was able to remove the filter. Most likely it is due to dust getting on coils & condenser Or actually has a Freon leak. to resolve the dirty coils you can easily dissemble (that is remove front & rear cover) it to give coils and condenser a good thorough cleaning. It the coils and condenser are not at all dirty, then is not the cause of the icing. The units are typically not serviceable - i.e. a disposable small appliance.
Jun 02, 2014 | Whirlpool 75-Pint Dehumidifier
Where is the filter on this dehumidifier. Mod# ad75ust
To locate the filter: Shut unit off. Remove "bucket". You should find a "tab" at top of where bucket goes in middle front of unit. Pull down to remove tab of Filter. Clean thoroughly and dry Filter before re installation. Visually inspect the coils and condenser while filter is out ( a flashlight helps). If it looks slightly dusty or like covered in felt, then it would be wise to remove front and rear covers and give the coils and condenser a thorough cleaning.
Sep 26, 2013 | Whirlpool 75-Pint Dehumidifier
My dehumidifer runs but no water is being pulled out
Might be a dirty coil and condenser.
I have had a AD75UST0 WHIRLPOOL Dehumidifier for several years. If it actually still runs, I would suggest you take off covers and give the coils a good thorough cleaning. Otherwise the units are not designed to be serviceable aka - "disposable small appliance". if you do dispose of it take it to a qualified recycle organization for Freon products. Shut unit off. Remove "bucket". You should find a "tab" at top of where bucket goes in middle front of unit. Pull down to remove tab of Filter. Clean thoroughly and dry Filter before re installation. Visually inspect the coils and condenser while filter is out ( a flashlight helps). If it looks slightly dusty or like covered in felt, then it would be wise to remove front and rear covers and give the coils and condenser a thorough cleaning.
WHIRLPOOL DEHUMIDIFIER Parts Model ad75ust0 Sears PartsDirect
Apr 18, 2013 | Whirlpool 75-Pint Dehumidifier
Icing up on a dehumidifier
The gas can pass through the pipework slowly by osmosis especially after several years use. However, check fans, heat exchangers etc first before condemning unit.
May 15, 2012 | Whirlpool Dehumidifier 40-Pint
Why is my unit have ice on the front grill?
Its not supposed to. if it has a filter clean it if not try to clean the coil, if these do not fix the problem it could have a ref. leak.
Jul 04, 2011 | Whirlpool 25-Pint Dehumidifier
Dehumidifier problem
First, make sure the rectangular filter on the back side is clean so air can flow over the coils freely. Try to place the dehumidifier on a table or something to get it off the floor. (floor level is cooler than head level) If you still have icing issues, replace sensor. (part # WK23X10011 )
Sep 01, 2008 | Dehumidifiers
Heating & Cooling Logo
106 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
