Question about Cameras
When I turn the camera on, it says "lens error" - but the lens is not on. It tells me to remove the lens cap and turn the camera on. Can I fix this problem myself?
  • Obertelli
    Obertelli Oct 03, 2010
    Please state the make and model.
  • lhudson825 Oct 04, 2010
    Coolpix P100
    Brigadier General:
  • 3,006 Answers
The Coolpix P100 is a bridge camera: an advanced digital compact model styled like an SLR and with many similar user features, but with a single non-interchangeable lens fitted to the camera. I was therefore a bit puzzled by your comment that "the lens is not on". I now realise that you meant that the lens was not switched on.
Although the lens cannot physically be removed from the camera, when not in use (camera off or only turned on in playback mode) it retracts as far as it can into the camera body. But even in playback mode the camera will run diagnostics on the lens when the camera is turned on. Your camera has detected a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty (should definitely apply to the P100 as it's a very recent model) and has definitely not been subject to misuse then contact the Nikon service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault. The article mentions Canon a few times but the advice applies equally to all cameras with lens errors. Note that the article clearly tells you which remedies are warranty-friendly and which ones you must not attempt if you wish to preserve your rights to a warranty repair.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome!
Posted on Oct 04, 2010
Sony HDR-XR200 lens cover problem
You have two options, replace the motor that opens and closes the lens cover or remove the lens cover shutters all together, and use a 30mm lens cap.
May 25, 2010 | Sony HDR-XR200V High Definition AVCHD...
When turn on tells me to remove lens cap , no pic
CCD (imaging IC ) went bad and require replacement.
Nov 15, 2009 | JVC GR-D22U Camcorder
Tells me to remove lens cap , no pic when removed
This could be two things:
1. CCD has failed or
2. Lens unit connection to main pcb has failed
We can fix this for you, email vintech@optusnet.com.au
Oct 26, 2009 | JVC GR-D22U Camcorder
Lens Error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 29, 2009 | Nikon COOLPIX P90 Digital Camera
Hi my camera is telling me to...
Is the camera turned on? Removed the Cap on the Zoom lens? Try turning it off and on, while the cap cover on the lens is removed, then press the heart button and take some photos. What specifically is the warning?
May 07, 2009 | Panasonic Lumix DMC-FZ4 Digital Camera
Zoom error
Turn Camera off remove batteries for a few moments. Re insert batteries. Turn on will reset itself. Ensure you use correct focus settings as per instructions. If you dont use correct settings this problem will reoccur.
Oct 27, 2008 | Fuji FinePix S1000FD Digital Camera
ERROR REMOVE CAP LENS
I had the same problem with mine after I dropped my camera when it was opening up after turning on. It feel directly on the lens and ever sense has told be to remove the lens cap.
I’ve disassembled the camera and discovered that the zoom motor drive assembly has a small set of plastic gears inside that are quite fragile and like mine are easily broken. You’ll find the zoom motor after taking the back assembly of the camera off. It’s located on the bottom left side of the lens assembly if you're looking at the camera as if you were taking a shot.
Here’s the part no. from the Panasonic support web site.....
L6DAAAHB0001
ZOOM MOTOR
46.07
May 28, 2008 | Panasonic Lumix DMC-FZ8 Digital Camera
Lens error nikon coolpix 4300
This error occurs if camera is turned on before lens cap is removed. If you are removing the lens cap before turning the camera on and still getting this message, camera should be serviced by a qualified technician.
May 17, 2008 | Nikon Coolpix 4300 Digital Camera
Cameras Logo
237 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
