I need to do a low level format for my hard disk. Bad sector problem. Do you guys have any application for that particular kind of formatting?
    President:
  • 1,216 Answers
Bad sector on hardisk there two kinds of that is software and physical. physical badsector caused from plate of hardisk damage is caused by dirt, fallen down, collided, to be incised, etc. While software badsector can be caused when hardisk busy sudden die, cause of usually broken electrics current.
For the bad sector damage of physical of hardisk, we require a really of expert to repair the hardisk. While damage of software we can repair xself use software or tool. One of the software which can be used to repair bad sector on hardisk that is HDD Low Level Format Tool.
Using this software hardisk can be low level format. Require to be paid attention that using low level format on a hardisk, causing all data in hardisk will lose and cannot be recovery again. But this way will be more effective eliminate sector bad.
HDD Low Level Format Tool Support Hardisk SATA, ATA or SCSI, can is also used on removable media like flashcard, flasdisk and etc. To run this software is very easy, that is :
  • Download HDD Low Level Format Tool from the link above and install it till finish.
  • Run HDD Low Level Format tools
  • Select a hardisk which will repair then click continue.
Select LOW-LEVEL-FORMAT tab", if you sure To format the hardisk click "format this device" button and await till finish. ad for hardisk repaired hence required time will longer.
HDD LOW format level can be download from following link,
http://hddguru.com
note : If on hardisk have detected badsector, before doing above steps, first step to backup all existing important datases
Premium experts are not paid for free questions so require your appreciation in form of a 4 thumbs rating
THANKS
Posted on Oct 03, 2010
I have dell inspiron 1525, with windows 7, and this message appear whenever trying to login to my pc.. "Windows failed to start, a recent hardware or software change might be the cause. File:...
The hard drive may had a BAD SECTOR ( corrupt section )
try to format with normal mode,NOT quick format.
try using LLFTOOL ( hard disk low level format ) http://hddguru.com
quite bit longer to fix the bad section,but works.
akee.4shared.com
Aug 15, 2011 | Dell Inspiron 1525 Laptop
Looking to initialize (low level format) a wd600ue with bad sectors. Init fails with win 7 data management
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart or
just place a tick in the bad sector box
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive
then you might try the low level format
hope this helps
Jul 29, 2011 | Western Digital Scorpio WD600UE...
How to remove bad sectore of hard disc? s/n=0415j1ftc02540
Let's try to explain the question that grinds us all when in cams about the hard disk. Can we actually repair a bad block? Before of the answer you must find some information about what is a hard disk, how does it work, what are bad blocks. After that you must identify them because you will need the exact location of the affected sectors. After you have done that you must run a few steps:
- before you try to resolve the problem with the bad sector you must extract the data that was written to that block. To do this you must run a Recovery program that you can find freeware on the net.
- bad sectors are unreadable parts on your hard disk but the nature of them must not be always physically and that part of the platens to be destroyed. The bad sectors can be simulated by some programs. This means that some programs installed on your computer can interrupt the reading process on to another segment of the platens. That is in the most happier cases but the chances that the bad sectors are cause by this is less then 10 percent. In this case is difficult to resolve the problem because even the Scandisk or other identification programs used to discover bad blocks will give a rapport that nothing is wrong with your hard disk. The best way is to uninstall the latest programs applied to the computer.
- lets supposed that you have a 20 gigabits partition on your hard disk that has bad blocks. After the identification program it will indicate you where are the blocks situated on the partition. So this way you can isolate them in to another partition that you must never use again. Another scenario can be created and the bad sectors can be at the beginning of the partition in the middle of it and at the end of the partition. Know it's a little bit tricky because you can't just go on and create three new partitions to eliminate the bad sectors from use. In this case most of the new hard disk has a spare space available just for this type of scenarios. You must access the CASH memory of the hard disk and indicates to the hard disk that instead of writing down on the effected blocks it must write to the spare blocks.
- another to restore the hard disk is to use the low level format option. Many of you think that low level format is a program. Wrong, the low level format option is set for any BIOS and can be easily use if you know some command line programming. The low level format can take to be complete a very long period of time but in the most cases we can obtain marvelous results. Actually the low level option takes every cluster of the hard disk and identifies them again (throw a thermal process) and writes down on the memory of the hard disk what sectors can be written and witch blocks are un-writable. This procedure is the best that can be because it will need no effort from your side to try and avoid the bad blocks that already exists and the hard disk itself know where the bad blocks are.
In conclusion the bad blocks can't be fixed. The problem is a permanent one and we can only try to use the hard disk until it is broken down for good. But if you are having financial problem this is a best way to keep going with your old hard disk.
Thank you for choosing FixYa! Your rating will help me succeed and continuously help a lot people.
Feb 03, 2011 | Maxtor Hard Drive
Hello Sir,Infact when i want to download something in my memory card there is written MSDC write error.So please guide me how can i get rid of this problem.
This may be related with a corrupted or bad sector in the msdc more than anything in the iPhone or music player. If you have used this memory a lot, erased and copy many files over time, it may be a good idea to back up and reformat the memory using a low level format so it will take some time to really erase and format the memory. But if the damage sector is hardware or physical and not an error on the format you may need to live with it or replace it. Anyway check with another msdc device and verify if this is related to the particular msdc you are using.
Use this tool to format your memory card http://www.softpedia.com/get/System/Hard-Disk-Utils/HP-USB-Disk-Storage-Format-Tool.shtml
Oct 13, 2010 | Computers & Internet
Very slow at start up and shuts down at will.
hi, ( O.S - win XP / windows 7)
u need check the system virus/spy virus/Had disk bad sector. 1. After system ON press F8 key 3. Select the safe mode with command prompt 3. Type : chkdsk and enter it will check the bad sector,lost clusters,cross -linked files and lost clusters, directory errors. 4.If u found any Bad sector - u need format with Low level format Hard Disk / if not any bad sector (a) Run with Anti Virus with latest updates.
Rgd, Manju
Feb 10, 2010 | E-Machines eMachines Desktop PC
Barracuda 7200 6Y160M0 FW YAR51HW0
do a low level format with a software from hddgurudot com its free software. run it and choose this drive for low level format.it runs through windows it will make a new list of bad sectors and add it to the p list of the hard drive company settings
datarecoveryfactory
Jun 09, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Bad sactor
a low level format could revive the disk - download the disk utility from the disk website (e.g if it is a quantum load the disk manager from quantum site & run on the disk - follow screen instructions)
hope this helps
Mar 16, 2008 | Computers & Internet
Hard disk is read only
format your hard disk with disk manager software. (low level for formating). this software can remove bad sector of your hard disk
Oct 10, 2007 | Computers & Internet
Computers & Internet Logo
837 people viewed this question
David Payne
David Payne
