Question about Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White
Purchased a used gas oven yesterday. The top burners are working fine, but the oven is sooting up. We live in the country and use propane, but did not receive any additional orfice or instructions. In the past, I have had to change orfices to seitch from natural gas to propane, but this one seems to not give an option. Any suggestions?
  • Whirlpool Master
  • 3,361 Answers
We need a model number to be specific.
Check the gas regulator and make sure the pressure cap has been set for propane.Most of them are turned over to put more pressure inside the valve.
If so. Check the air shutter on the bake gas tube and adjust for the best color flame.
Also tighten the bake burner orifice with a 1/2 inch wrench.
Posted on Oct 03, 2010
  • rickey_ingra Oct 03, 2010
    The model# is W12000905A. Where is the pressure cap?
  • steve
    steve Oct 03, 2010
    The pressure cap is on the gas regulator.
    That is where you hooked your gas line to the range.
THE PROPANE FRYER SOOTS UP AND BLOWING SOOT ALL OVER THE PLACE HOW DO I FIX THIS
You are getting too much gas or not enough air to the burners... check the air shutters and make sure they are all the way open and if so then cut back the gas pressure at the gas valve...
heatman101
Jan 05, 2011 | Ovens
Fridgatare modle #FGG3054KFB I have a frigidaire range that has been converted to propane. When the oven is turned of it has a strong propane smell and there is alot of moistier inside. The flame is about...
It shouldn't be burning yellow and emitting soot at all;sounds like on of these possible causes-
(a)blocked burner airways(this can lead to yellow tipping and sooting on LPG powered appliances because insufficient air is getting through to the burner causing it;you can also get this effect on LPG barbecues say if dead insects or spiderwebs are in the burner pipes and airways after a period of storage),
(b)incorrect aeration being set when the burner was converted using LPG jets(too much gas and not enough air causing yellow flames/smells and sooting),
or (c) if you use propane cylinder gas a dicky or faulty regulator. I would get it looked at investigating all the possibilities I mention and taking action to correct this where necessary ie clearing the burner airways(if this is causing your problem), adjusting the aeration in the burners until you get a clear noiseless blue flame without any excessive yellow and sooting(but even after good adjustment you may find still get a very slight yellow tip without sooting at the top of the flame;this does happen with propane gas and there is a slight tendancy for this to happen more often with butane-butane tends to display very slight yellow tips on ignition increasing slightly as the burner warms up to full temperature) or if you use propane cylinder gas replacing the regulator if that is necessary.
Nov 22, 2010 | Frigidaire FGB24S5A Gas Single Oven
Propane stove burns yellow & creates soot
clean the orfices and tubes and then if possible adjust your air mixture setting also
Sep 21, 2009 | Frigidaire FGB24S5A Gas Single Oven
I have a gas oven. The flame burns yellow and leaves too much soot on the wall near the flame. Is there a way to clean the element thing? Dave
I am not sure. However, people in our area of sc, have had burner problems because a local utility added propane to their natural gas because they got it a bargain. guy
Jun 10, 2009 | Frigidaire FGB24S5A Gas Single Oven
Propane not getting to oven... stove top works fine..
The pilot light must be lit and stay lit before you will have any propane coming into the oven. This is a safety feature.
May 17, 2009 | Magic Chef 9122 Gas Single Oven
Propane kitchen-oven ''whoofs''
Propane burns very dirty,I bet the burner and pilot are clogged with soot.In techinical terms the sound your hearing is blowback.If you check the burner/pilot you will likley see black soot,remove them and clean with soap and water.
Mar 16, 2009 | Ovens
Oven burner flame is low
0000000.jpgOn top of that safety valve is a nut. Get a good fitting wrench. Turn on the oven and use that good fitting wrench on that nut. Turn it counterclockwise till the flame comes up about midways of the flame spreader. Don't get the flames too high. Midways of the spreader now. LOL
Jan 02, 2009 | Ovens
Gas oven that cooks unevenly
clean your orifaces.
Also make sure that it's the correct stove for your gas type. If you're using a NG stove on Propane, you're wrong. It's making a lot of soot, and could potentially blow up your house. Stop using it until you're sure.
Dec 05, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Gas stove burner/oven noises
too much air on top burner ,delayed ignition on oven ,ignitor not lined up properly or check gas presure may need regulator adjustment or replaced. gas 784
May 12, 2008 | Ovens
Oven won't work
You cannot afford to take chances with gas of any kind, I must first suggest that you get a registered expert to sort out your problem. because you need to know and be sure that there is gas in your bottle, that you have the correct regulator and pressure, that the oven is set up for bottled gas as the jets are different sizes to normal town gas but all these measures can have disasterous effects if you get it wrong
Jan 28, 2008 | Ovens
Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
175 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
