Question about Samsung HCM5525W 55" Rear Projection Television
2003 Samsung HCM5525W started having green&red lines at top and bottom of screen....Is there a module I need to replace, if so what and where can I get those? Thanks John
  • 1 more comment
  • jcoppeta Oct 03, 2010
    Thanks I located the two chips, there are about 20 or so pins on each part that needs to be soldered off can I do that with a soldering gun ???? Or is it easier to just but that entire board??
    Thanks for the info, just have to decide on which path to choose....do you think I can use a conventional solder iron or do the techs use a special solder iron and solder ?? Thanks
    Thanks you were a help
  • 10,594 Answers
There are two black big chips mounted with aluminum heat sink on deflection board that need to be replaced, chip part number is STK392-040 and available in Part Store.com
Click on above link to see image of chip and price info.
Soldering work is involve to replace these two chips and you can attempt if you have prior experience of electronics stuff repair.
Thanks.
Posted on Oct 03, 2010
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Oct 03, 2010
    Yes, that correct, each chip has 18 pins that need to be unsolder, take out old chip, put new chi and solder its pins with soldering gun etc.
    Complete deflection board is also available but problem-fix cost will be increase.
    Click HERE to view deflection board image and price info.
    Thanks.
    Well you are better judge to evaluate your expertise/ skills.
    If you feel comfortable in soldering work then can attempt to replace chips by yourself OR local tv repairman is always a good option to do that.
    Thanks.
  • clemej68 Nov 15, 2010
    Welcomjee, hoping that you can still help. I ordered and replaced the two STK392-040 semiconductors. Fairly easy swap. They repair helped the convergence a bit but It still looks like it is "out-of-alignment". Is there some type of alignment that needs to occur now that the semiconductors have been replaced? Or, is the potential some other part that may be bad?
Wavy lines
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 18, 2009 | Samsung HCM5525W 55" Rear Projection...
Color alignment
Please replace both convergence IC's.
May 27, 2009 | Samsung HCM5525W 55" Rear Projection...
Samsung HCM5525W 55inch
This is a convergence problem. It happens to all big screen rear projectors. The convergence output ic's need to be replaced. I would let a repair man do this.
Nov 11, 2008 | Samsung HCM5525W 55" Rear Projection...
Samsung 55" model hcm5525w
its the convergence problem in your power supply board
please check out this links
for convergence board ics reparing it your self
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
and for convergence settings
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
thanks.
Oct 05, 2008 | Samsung HCM5525W 55" Rear Projection...
Samsung hcm5525w rear projection tv
Extensive analysis revealed this unit to be for 120V 60Hz regions. If you use it in a region where the mains supply is 220/240V 50Hz then it won't work. In addition, the PSU will overheat, with possible damage to other modules.
One possible solution is a 120V 60Hz inverter, else Samsung may be able to provide the correct PSU for 220/240V.
Jul 14, 2008 | Samsung HCM5525W 55" Rear Projection...
Samsung HDTV top of screen is turning inwards
Mine is Same, Just got it back from repair shop. Two Convergence Chips Replaced. $220.00 Got it home and picture was perfect, after about 1/2 hour I now have the Line back and top curving. I suspect bad soldering
Nov 14, 2007 | Samsung HCM5525W 55" Rear Projection...
Red tint on the entire picture
Always try your extended warranty!.....Probable cause = bad
red tube. One adjustment may help---turn down red screen
control, located behind technician access panel in front of set.
Nov 04, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Samsung HCM5525W TV red blue outlines on images
The Samsung has bad convergence IC's most likly. This should be repair ONLY by a trained technician as a TV set is not a place to experiment or tinker with because of the extremly high voltage inside. This repair should cost you in the range of 250 to 400 bucks . Good Luck
Jul 31, 2006 | Samsung HCM5525W 55" Rear Projection...
Samsung HCM5525W 55" Rear Projection Television Logo
442 people viewed this question
Henry  Thomas
Henry Thomas
