I ran the Maxtor shared external hard drive set up when it came to entering a password i did not know which password it meant and anyone i used i keep getting "incorrect password" what password does it want. I uninstalled it, if i reinstall it will i be able to start a new account with a new password
  • 558 Answers
Contact Maxtor on this, there may be a password to use until you install it then you are usually supposed to make a new one calling Maxtor or looking in their faq on their web site may help, it may be as simple as password is the password
Posted on May 27, 2008
How do I make use of a Maxtor Hard Drive. Should it have a disc to instal?
Dear shirley403
Yes, you need an operating system disk if you use the Maxtor hard disk as the main patision to your computer.
but, if you only use it to backup drive, set the jumper to slave.
If you are using external cassing, jumper settings depending on the situation, try to enter the master jumper setting,
if it fails in effect, put to slave or cable select
hopefully this can help...
TQ
Oct 31, 2010 | Maxtor Hard Drive
Hello I'm looking for the drivers for a Maxtor Shared Storave ii network drive
Welcome to Fixyah,
I suggest to you go ahead and visit maxtor website and from there look for the download button, If ever you can also contact tech support.
Aug 11, 2010 | Maxtor Shared Storage II 2TB Network...
When I connect my Maxtor external hard drive to my MacBook Pro, the light comes on, however the computer does not recognize the drive. I've gone into disk utility and it doesn't show there either. Not...
I think I got it. I have a Maxtor and when I connected it to my macbook same thing - light comes on but the computer does not know its there. So I tried to plug it into my PC (i've got it formatted for both - a actually it has 3 partitions one mac, and two pc) well when I plugged it into my PC the Maxtor Manager popped up and said that the drive was locked and I needed to unluck with my password. Once I unlocked it, it worked. I disconnected it from the pc and I plugged it into the mac and it's working fine now. I guess there is no manager for mac. I'm going to the website to see if I can download the manager for mac. Hope this helps.
Jul 22, 2009 | Computers & Internet
Maxtor 750GB External Drive Blinking White Light
If you hear a click-click sound it means that your drive's mechanics ia failing. BAD NEWS !!
Jul 06, 2009 | Maxtor Shared Storage II N01R010 1 TB USB...
Maxtor 3200
Seagate troubleshooting Error Code 10, states that drive has failed. (Seagate bought out Maxtor)
Before you resign yourself to everything is lost on this harddrive, how about trying one more thing?
How about putting the harddrive inside in a new external enclosure, and see if it works? I suggest that perhaps the external enclosure it's in, is bad.
The harddrive inside is a 3.5 inch harddrive. Same width as used by a desktop computer. It is a Sata harddrive.
Here's an example of a 3.5 inch Sata, external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3901268&CatId=2780
Just pop the external enclosure open that holds it now, take it out, and install it into an external enclosure like the example above. Plug in the USB cable.
Don't know if this applies to your particular Maxtor Personal Storage 3200, but when I went to search for the type of harddrive it uses just now, I ran into thsi, and thought I would pass it along. http://www.seagate.com/www/en-us/support/downloads/personal_storage/ps3200-sw)
May 10, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Stored static ip address in nas server and cant
I have a similar problem. There is a reset pinhole switch just beneath where the Ethernet port is that if you push it is supposed to reset the drives name and switch it to DHCP. You can see this in the manual. Unfortunately, this hasn't worked for me and I'm working through another solution to see if I can find the IP it is attached to.
Apr 21, 2009 | Maxtor Shared Storage II 2TB Network...
Unable to see Shared Storage Drive II on EasyManage via Wireless
Just got a Maxtor Share II drive and absolutely love it. Setting it up was a pain especially when the drive didn't remember the Administrators password.
Here's what I think the problem may be
1-Your router is not assigning an IP address to the drive
2-Make sure your router is configured to DHCP IP configuration not Static.
3-Before trying to use the drive make sure to install the Software/Drivers first.
Other suggestions
This may or may not apply to you. I got my Maxtor drive on 4-07-08 and from previous experiences with other computer products, ie, windows software, printer drivers, etc. The manufacturer in order to rush things out the cd software that comes with the product is not the final version and most likely the software already has an update on the manufacturer’s web site so it’s always good to check before committing to what you get on the CD. So sure enough the BIOS for my Maxtor Share II 500Gig hard drive was already old. I downloaded the new version upgraded the BIOS and my drive is working great. I hope this suggestions help. Enjoy your drive. Alfredo.
Apr 09, 2008 | Maxtor Shared Storage II (S01R320) Hard...
Unlocking external drive
You may have the encryption set on the drive - meaning it needs a password to access the Maxtor. Is this problem on the original computer you installed the Maxtor or on a different machine? Either way try reinstalling the Maxtor software. If you do not have it you can get it online at:
http://support.seagate.com/rightnow/mini_software/otiii_mini.exe
Jan 03, 2008 | Maxtor OneTouch III Mini Edition 120GB...
Not recognizing password
hi, im sure i can help, what software did you to put the password on, like was it just normal windows xp or was it a unique software that came with the external drive.
Let me know
Happy New Year
John
Dec 24, 2007 | Maxtor OneTouch II external hard drive...
Reg: User creation and folder creation problem,
Possible solutions.
1- Reset your harddrive using a pin through a little hole behind the drive.
2- Update the hard drive bios
3- download the lattest drivers.
Aug 17, 2007 | Maxtor Shared Storage II (S01R320) Hard...
Computers & Internet Logo
David Payne
David Payne
