Question about Sanyo Televison & Video
How can I tune my Sanyo CE32LD81-B/UK television. I live in Ireland and when I input my country into the TV it searches and finds no Analogue Stations. Yet when it searches for digital Stationd there is no problem???? Thanks
  • 11 Answers
SOURCE: Digital tuning
You'll need to go into service mode and do a factory reset.
To enter service mode you'll need to press these buttons on your remote in the following order:-
Standby-info-menu-mute-standby.You'll need to do it fairly quickly and be patient it doesn't always go into it first time,don't press and hold the buttons.
The service menu should appear on the screen.Use the up /down cursor to scan down to option number 12 (factory reset)and then press the right cursor wait will appear on the screen and the set will go to standby(don't worry this is normal)
Reboot the set and retune and all should be well
Posted on Nov 04, 2007
  • 300 Answers
SOURCE: Connecting Digital Decoder to Analogue TV.
This whole things is about converting the output of your digital decoder box to RF since your TV set only has an RF input
Lets look at the two main standards Composit and S-Video
1. if the output of your digital decoder is Composit you will need to convert it to RF using a Composit to RF converter.
RCA makes very small cheep ones that use about 9volts of power and can convert Composit into RF
2. if the output of your digital decoder is S-Video you will need an S-Video to RF converter
S-Video output is the newer standard but is essentialy the same as Composit and low cost.
Shalom ..
Posted on Sep 14, 2008
welcomejee
  • 10594 Answers
SOURCE: Telefunken analogue color TV model
As you said, its an analog model tv so it doesn't have Audio-Video connectors to hook up set top box.
Sorry.
SOURCE: I have a 37" LG
you need a cable hdtv box to get hdtv.
Posted on Jan 06, 2009
  • 9 Answers
SOURCE: Trying to tune a UMC
The tuner is probably faulty. Got the same tv, no probs.
Posted on Mar 10, 2009
How do I go back to Digital add on search when my boyfriend scanned for the analog channels. Sanyo TV model # dp42545
Usually you have to go to chanel setup and scroll down to DTV setup up or DTV auto tuning and click on the remotes enter button and choose to scan for the Digital channels (DTV) Then tell your boyfriend that they don't broadcast in analogue anymore.
May 09, 2015 | Sanyo Televison & Video
How do I retune my Samsung smart TV 40"with 3D
Country (Area)
Broadcasting > Channel Settings > Country (Area)
Select your country so that the TV can correctly auto-tune the broadcasting channels. This depends
on the country or region.
When the PIN input screen appears,enter your 4 digit PIN number.
Digital Channel
Change the country for digital channels.
Analogue Channel
Change the country for analogue channels.
Manual Tuning
Broadcasting > Channel Settings > Manual Tuning
Scans for a channel manually and stores in the TV.
If a channel is locked using the Channel Lock function, the PIN input window appears.
This function depends on the country and region
Page 147 of this User Manual located on this page will give you more information. (Sorry it wouldn't let me link the PDF manual directly)
UE40H6240AK UE40H6240AKXXU Support SAMSUNG UK
Sep 09, 2014 | Samsung 40" 1080p 3D Slim LED Smart TV...
Auto retune has wiped everything. Help
There is the digital tuner (DTV) and the analogue tuner (TV). Make sure you are tuning the digital side as there are no longer any analogue TV broadcasts in the UK.
Sep 04, 2014 | LG 26LH2000 26 in. HDTV LED TV
Sanyo tv troubleshooting CE32LD81-B/UK
If the set should not come out of standby, the fault should be with its main digital control board itself. Troubleshooting procedure to these boards are very skilled work, and need all measuring instruments, and expertise. To get more details, http://electronicshelponline.blogspot.com/
Nov 14, 2013 | Televison & Video
Tv keeps switching itself onto standby by itself. When left off for a while, it lets me switch back on but after a while, it switches itself back off
Unfortunately there are several reason why this may be happening.
The two most likely ones are a bad main board and a bad power board.
What I'd do if I were you is open the TV, inspect the power board for bulging capacitors, have them replaced if I spot some and if the problem persists I'd assume it's a bad main board.
Oddly enough all such main boards I could find on eBay were in UK...are you by chance in UK too?
You'd need 17MB22-2 021106 .
Hope this helps.
www.coppelltvrepair.com
Feb 22, 2013 | Sanyo Televison & Video
The screen says that the signal is weak and shows snow.
Is this a replacement set? Plugged in the same antenna?
Is this the analogue tuner you're using or it's DTV (Digital TV tuner)?
If you're in the USA and Canada there are no analogue transmissions.
You'll find the tuner selection in Menu and a sub menu headed Inputs.
If in the UK some regions have closed down analogue signals already and some are coming up to doing so, concluding with my region, London in June, 2012.
If you're not in these countries you'll get your area's info. by entering 'Digital TV changeover' into Search on your web browser.
Sep 26, 2011 | Televison & Video
Hi, I am trying to tune in my bush tv without success - I bought it in Ireland but the tuning does not give ireland as an option.... what can i do?
When selecting a country, chose Australia not the UK as Australia broadcast in VHF, whereas the UK do not. Then hit the search button and it should pick up the 4 Irish channels, no problem.
Oct 18, 2010 | Bush DVD142RC 14 in. TV/DVD Combo
I am unable to pick up sky and set it to a position on analogue tv settings. The Tv is sanyo ce26ld90b.
If first we could ensure some connections are tight before moving into TV settings.
You have told me that you are using sky over an analogue connection. Make sure that these are plugged in at both ends (sky box and TV) and that your sky box is on.
Now using your TV remote, enter the TV settings (there should be a button for this specifically on your remote), and opt for Tuning and manual tuning. The layout for most TV settings are similar.
By manual tuning, you are able to select the number on which you want to view a channel (in the analogue case, Sky as a whole is considered one channel on your television)
Now you should be able to use the left and right keys on your remote to tune up and down a range of frequencies, one of which Sky will be on. Once you have found this frequency, you should store it to the channel you have selected.
To my mind, the only thing that would then cause this to reset is if you turn off your TV from the mains each time you finish using it.
Aug 23, 2009 | Sanyo Televison & Video
Sanyo tv no manual needs tunning ?
Hi I don't know what country you're in but there are websites that will supply direct replacement remotes. You could try here if you're in the uk:
http://www.remotesrus.co.uk/remote/make/SANYO.htm
If you can identify the exact model number of the appliance or remote you can also google for information, there may even be a picture of it somewhere or a source where you can obtain a manual.
Good luck...
Hope this helps
Feb 11, 2008 | Televison & Video
Televison & Video Logo
73 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
