Question about Whirlpool LER8648L Electric Dryer
Drum stopped spinning. Is it the belt. Is heating.
  • Whirlpool Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley or a faulty motor.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Posted on Oct 03, 2010
Hi, My dryer has stopped dying the my cloths is this a common problem?
No, is the dryer drum spinning? If not, replace the drum belt. If the drum is spinning but not drying the colths. The dryer heating elements is burnt out and needs to be replaced. GB..stewbison
Aug 31, 2011 | Fisher and Paykel SMARTLOAD DE62TG1...
Recently, my dryer stopped spinning. The heat still works but the drum will not spin at all. Help me please :(
If you are brave enough to try undoing some nuts to open the dryer up you will probably find that the belt that wraps around the drum is broken or has slipped off of the drum. I bought a new one and did the repair myself.
Oct 16, 2010 | Kenmore 62622 Electric Dryer
My kenmore dryer heat very good but the drum stop working it dose not spin at all
Hello
The drum not spinning is either a broken belt or a faulty drum motor.
Mar 21, 2010 | Kenmore 73952 Gas Dryer
The drum for our Zanussi TC7103 has stopped spinning
sounds like a new drive belt is required. pull the machine out remove the mains supply!!!!
remove the top and look into the back of the machineif you cant see the belt them remove the back of the machine, it's like a small fan felt from a car it's either come off or disintegrated in which case you'll need a new one.
Nov 09, 2009 | Dryers
Dryer heats but drum does not turn when the start button is pushe
You need to check the drum belt. With dryer empty, reach in and give it a spin. If the belt is good, it will stop in 1/2 turn or less when released. If the belt broke, it will spin almost a full turn.
Oct 25, 2009 | Kenmore 62602 Electric Dryer
My druer is heating but the drum wont spin
either the motor is defective or the drum belt is broken or off the pulleys, if you can't hear the motor start and run w/o belt attached and it just buzzes the motor start cap could be bad
Sep 30, 2009 | Dryers
The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
May 19, 2009 | Whirlpool LEQ9858L Electric Dryer
Whirlpool LER8648L Electric Dryer Logo
63 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
