Question about Canon Video Cameras
A red blinking light is on the screen, and the tape does not run while record button is pushed. can not identify what the red flashing picture is, but there is a red line running threw it
    Genius:
  • 1,812 Answers
The Red flashing icon with the line through it says there is no tape in the camera. This could possibly be a problem in the cameras tape detection circuitry and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Oct 03, 2010
Sony bravia kdl55hx729 3d led tv turns on 3 seconds shows picture than four red flashes
the error light sequence that you are seeing is indicating a "backlight error". Most likely you have a bad inverter board -the board that powers up the back-lights behind the display panel. They might be available via ebay if you are a DIYer, or you need to call for sony service.
Good Luck!
Rich Lilja
Dec 07, 2013 | Sony Bravia KDL-55HX729 LED Internet TV...
Blinking red light will not power up
What make and model camera?
Jun 30, 2013 | Cameras
PROTECTION flashing on lcd screen
there should be a little tab on the tape that can be moved (the one on my tape is red) if it is closed it stops the tape from being able to record anything and if it is open you should not see the protection on the screen
Apr 08, 2009 | Samsung SC-L810 Camcorder
Red light keeps blinking when I try and take a picture
actually the flash ckt is having problem that is the reason the red indicater blinks. you can take photographs with flash off mode,to solve this problem you will have to contact service centre
Dec 08, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
NEED HELP
G'day,
I also have the same problem and after almost buying a replacement I thought I would try one time to get it to go.
What I did was start the cam without a tape in it, let it bring up the little red icon indicating no tape inserted, (it hadn't started flashing "PLEASE RE-OPERATE AFTER PUSHING RESET BUTTON" at this stage) then I inserted my tape. Hey presto, it works although for how long I don't know. I'll immediately start burn my tapes to disc while the going is good.
Hope this helps someone
Aug 22, 2008 | Panasonic NV-DS38 Mini DV Digital...
Red power light flashes twice and unit will not record. I will not play a tape, none of the tape keys work (rewind, fordward, or pause, etc). I do get a picture in both the vcr and camera mode but the tape...
1. Take out the tape - AND TURN THE CAMERA POWER ON
2. press the menu button (near the viewfinder)
3. Use he wheel on top next to the viewfinderto scroll through the choices
4. Choose "display setup" by pushing the wheel in
5. Choose "C. Rest" by pushing the wheel in
6. Turn camera off
7. Next time you turn camera on y ou should be able to view tapes and record.
IT DID NOT WORK THE FISRT TIME SO I PUT MY FINGER IN TO TRY TO GENTLY PUSH BUTTON WHEN I TOOK THE TAPE OFF AND THEN TRIED SOLUTION ABOVE AGAIN, AND THIS TIME, IT WORKED. BUT PLEASE DONT INSERT YOUR FINGERS IN AS I DID TRY THE SOLUTION 2 OR THREE TIME IT SHOULD BE OK, HOPE THIS WORKS FOR YOU,
THANKS AND CREDIT TO LABBER
Dec 20, 2007 | Panasonic Palmcorder PV-DV53 Mini DV...
Pv-dv53d
6. Turn camera off
Oct 11, 2007 | Panasonic Palmcorder PV-DV53 Mini DV...
Panasonic NS-DV 65 video camera, Tape not detected?
TRY THIS, (CREDIT TO LABBER) IT WORKED FOR ME
I did have a similar problem as above, and has not been able to use the camera for a long time as power turns itself off in less than 2 mins. I tried the solution #3 (by labber) above. which i have copied and pasted below .
1. Take out the tape - mine stayed on longer (without blinking) when the tape was not in.
6. Turn camera off
7. Next time you turn camera on you should be able to view tapes and record.
THANKS HOPE THIS HELPS.
EBEN
Dec 06, 2006 | Panasonic NV-DS29B Mini DV Digital...
Panasonic PV-DV53D
I was having the same problem. here's the solution that worked for me - should do it for you as long as your camera stays on long enough. 1. Take out the tape - mine stayed on longer (without blinking) when the tape was not in. 2. press the menu button (near the viewfinder) 3. Use he wheel on top next to the viewfinderto scroll through the choices 4. Choose "display setup" by pushing the wheel in 5. Choose "C. Rest" by pushing the wheel in 6. Turn camera off 7. Next time you turn camera on you should be able to view tapes and record. hope that helps!
Oct 16, 2006 | Panasonic Palmcorder PV-DV53 Mini DV...
Video Cameras Logo
230 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
