Question about Rheem Water Heaters
Pilot light went out. Try to light, would not stay lit
  • 520 Answers
Sounds like the thermocouple.
Posted on Oct 03, 2010
Sw6p suburban won't stay lit. My 6 gallon hot water heat on my 2007 camper won't stay lit, I go and light the pilot light and it lights but I turn the gas up and it blows out please help
the thermal couple is likely bad .
when you release does pilot stay lit or only as long as you hold the button .
if it stays lit then the thermal couple is good
if it only blows out as you turn on the heat then its draft issue.
May 09, 2015 | Water Water Heaters
Rheem 22V50F1 pilot won't stay lit. Changed thermo couple & it lit, ran then went out. Let it sit overnight & it lit, ran then went out. What next? p.s. The unit is 5 years old. Thanks
If pilot lights and flame is robust and clear blue, and pilot goes out later, then some suspects can be excluded: air in gas line, low gas pressure, thermocouple is overtightened (finger-tight + 1/4 turn), thermocouple not positioned correctly in the flame, dirty pilot tube.
If flame is yellowish and small: then clean pilot tube and combustion parts.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Remaining suspects can include: air in gas line, low gas pressure, bad gas control valve, tight house so household vent fans pull air down water heater vent that blows out pilot, hot attic with inadequate ventilation, water dripping down vent.
Open following links to read troubleshoot resources.
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Aug 16, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Pilot light will not stay lit.
More than likely the thermal couple is defective. The thermal couple is a safety device that shuts the gas off if the pilot goes out. If it is defective the pilot light will not stay lit. The thermal couple is the device that the small copper line goes to. It is mounted beside the pilot flame and the flame much touch the TC for it to work. If the flame is not touching the TC bend it until it is in the flame. If it is touching the TC then replace it.
Jul 28, 2011 | Whirlpool Water Heaters
The pilot went off and will not lite
There is a special procedure for lighting pilots. It should be clearly labeled on the unit. If you are following this and it will not stay lit, then you need to call a certified repair tech.
Feb 14, 2011 | Rheem Water Heaters
The Pilot light will not stay lit
You will need to replace thermocouple or you might get by for awile by cleaning old one by lightly sanding tip and making sure it is positioned in center of pilot flame. When you light pilot hold down on pilot button until you can see the tip of thermocouple glo red. If after cleaning the pilot won't stay lit after you release button then you need to replace it. Remove thermocouplefrom gas valve and pull back on it to remove it from pilot assembly. You can buy universal replacements at most hardware stores. Try to get one at least as long as the old one. Good luck.Ihope this helps you. Thanks.
Dec 04, 2010 | Rheem 75 Gallon NGAS 70K Water Heater 6YR...
Pilot will stay lit but burner goes out about 1 minute after it lights
Sound like the flame sensor you could scratch around on it and try again.Possibe venting issue
May 14, 2010 | Water Heaters
Pilot light on water heater wont stay lit
The thermocouple has failed. It is the temp probe that goes from the pilot lite burner area to the control valve. Go to your local plumbng repair shop and buy one. Most appliance parts stores have them also. Take the old one with you and they will hook you up with an exact replacement. They are not that hard to change. Usually a nut or 2 screws in the temp bulb area at the burner end and a nut that threads into the control valve.
Make sure before you install the new one that the area where it mates to the gas valve is clean. Should be about a 20 min job including clean up with replacement parts in hand.
Jan 23, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
I don't know how to restart my old bosch water wizard 10p, pilot light has gone out.
get a long stick match, a flashlight remove lower inspection cover, find thermocouple and pilot light will be next to it,turn gas valve to pilot light and hold down,stick the match in by thermocouple till the pilot lights and hold valve down till pilot stays lit,this may take a minute or more,then release gas valve and see if pilot stays lit, if not retry,if it wont stay lit,the thermocouple is defective and needs replacement
Jul 12, 2009 | Bosch & Tankless LP Hot Water Heater
Water Heaters Logo
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
