Question about Haier Dehumidifiers
My haier dehumidifier continually runs even with the selecter switch turned off . any advice ?
  • Haier Master
  • 1,711 Answers
Even thought this a problem with just one relay included on the control panel which is stuck to the on position, the solution is to replace the whole control panel.
Posted on Oct 03, 2010
Dehumidifier runs continuously and displays higher than normal humidity levels.
Probably some glitch with the sensors. I recommend taking it to a service center.
Dec 06, 2013 | Haier DE65EK 65 Pints eco-Friendly...
Haier dehumidifier will not power on
Turn the ON/OFF Switch to OFF and unplug the unit for 15 minutes.
Once the time has elapsed, plug the unit in and turn the unit ON.
Hopefully, during that 15 minute timeout, the electronics reset and reverted back to the original factory settings. And the unit will turn ON when you press the ON/OFF Switch.
It's also a good idea to check the outlet it's plugged into. It very well could be an issue with the outlet (no power) or the circuit breaker for that outlet has tripped.
If you continue to have a problem getting it started, contact LG Customer Support 1-800-243-0000.
May 27, 2013 | Haier 65-Pint Dehumidifier
Icing coil ices up ,but will not defrost no matter how long it runs. It just continues to build up ice.
If your dehumidifier is freezing up then that probably means the unit itself is actually working well, and you probably just have the unit turned up too high for the conditions.
Try turning down the setting on the unit so that it cycles on and off every few hours and does not run continuously.
Also try using some warm soapy water to clean off any dust or oily residue from the cooling coils in the rear of the unit. Remember to also clean the air intake filter while you are at it.
The ambient temperature in the room may also be a bit too low, so you can try adding some heat to the room if necessary. A dehumidifier will not work properly if the ambient air temperature is too low. Basically, the warmer and more humid the room is, the better they work. Since warm air rises, you can even try lifting the unit higher up off the cold floor onto a bench or table where the air is warmer.
Sometimes the drain tube leading to the bucket is clogged. You can often clean this out by inserting the pointy end of a long heavy duty plastic zip tie and jiggling it around a bit. Do not insert anything metal or sharp into the tube or you may damage it.
You can click on the following link for a general operating and troubleshooting guide with additional tips on effective dehumidifier operation:
http://www.allergyconsumerreview.com/dehumidifier-advice-troubleshooting.html
And here is a link to a tip from another Expert (Heatman101) which includes his very detailed troubleshooting guide for dehumidifiers:
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
I hope that was helpful to you, good luck and take care.
If you choose to rate this solution, or Heatman 101's tip using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
Jun 21, 2011 | Haier AHD25 Dehumidifier
It continues to shut down after start saying it is full, but it has no water in it. No matter if I take out the bucket and push back in it still says full. Not even a year old!!!
Here's a solution that often works. Turn the Master ON/OFF Switch to OFF. Unplug the unit from the wall outlet and wait 12-15 minutes before plugging it back in. Then turn the Master ON/OFF Switch to ON and set your control as you normally do. Hopefully, that 12-15 minute timeout allowed the unit to reset itself. If it continues to do this contact Haier Customer Support 877-337-3639 and have your Model Number and Proof of Purchase handy. If it's less than a year old, it's still under warranty.
Good lick. I hope this helps solve your problem.
Apr 18, 2011 | Haier DE65EJ Dehumidifier
My dehumidifier leaks and not shut off. The bucket is full, but the unit still runs and I notice water puddling under the unit and my rug is wet around the dehumidifier.
I don't have a Haier but I have a dehumidifier which has a float and when the float get to a certain point,it activates a switch for auto shutdown.If yours has the same setup,the switch is probably bad.
Good luck! Greg If not,let me know.
Aug 16, 2010 | Haier HDN655E Dehumidifier
Unit wont run but lights up. It reads low humidity even though its high
First, make sure the reservoir is empty. If you plug the unit in and see a green power light, but the unit won't run, make sure the reservoir is properly inserted. Many dehumidifiers have switches or sensors to make sure that the reservoir is placed so that it won't leak. Look for these sensors and make sure the reservoir is engaging them. If your dehumidifier has a float or switch to indicate a full reservoir, make sure this switch isn't being tripped accidentally.
Good luck.
Aug 13, 2010 | Haier HD656E Dehumidifier
Tyies to Start
It could be a bad compressor, circuit board, or maybe even a sensor or dehumidistat...
Here is a tip about dehumidifiers2_bing.gif that run but do not extract water from the air..
Dehumidifier is running but no water is in bucket
heatman101
May 02, 2010 | Haier 65-Pint Dehumidifier
Dehumidifier
Dear rmclpc
huuum at your service.
Here is a site offered by fixya.com for owners manuals.
http://www.pronto.com/user/search.do?displayQuery=
kenmore%20elite%20oasis%20owners%20manual&SEM=true&query=kenmore
%20elite%20oasis%20owners%20manual&adid=1210312579-6519660d_10_gc&ref=
owners%20manual&creativeid=1167763135&site=
www.fixya.com&loadingComplete=true
Bless You,
huuum
Please give me a good rating before you sign off here at fixya.com
Sep 17, 2008 | Maytag M7DH45B2A Dehumidifier
Haier 30 pint dehumidifier continuous drain problem.
Many just attach the hose at the reservoir; from your description, Haier apparently has a separate location. Check that the point that the hose attaches has an opening (many don't, they expect you to drill it). It should then drain through gravity. Check to make sure that no part of the drain hose is higher than the bottom of the reservoir, otherwise it can't drain. It won't siphon because each time the the tank empties, the suction is broken and the siphoning can't continue.
Aug 24, 2008 | Haier Dehumidifiers
Dehumidifiers Logo
43 people viewed this question
Top Haier Dehumidifiers Experts
Steve
Bill Long
Jim Thurston
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
