Question about Kenmore Refrigerators
Can't get ice bucket back into place to make ice...what are we doing wrong.
  • 547 Answers
First, turn the icemaker off by raising the wire "bar" that is attached to the icemaker until it clicks into the raised position.
Second, if your freezer has an ice dispenser system, make note of the position of the drive gear at the back of the freezer. It will have two prongs that will need to mate with the icemaker bucket. If they aren't lined up with the icemaker bucket auger, then turn the auger by hand until it will line up with the prongs.
Finally, check for a stray ice cube resting inside the freezer, either on the back wall or on the side rails where the bucket rests.
Posted on Oct 03, 2010
  • Rob C Oct 03, 2010
    Oh, and then of course lower the wire "Bar" to turn the icemaker back on when you're all done
How do I Prevent ice dispenser from freezing up? Ice is in the ice bucket but will not disperse.
The ice stays in the cubemaker tray for a set time and then empties into the bucket. If the freezer was too warm the ice wasn't frozen enough when the cube maker emptied it and it all stuck together. Now the fridge is cold again empty the bucket, make sure there is no ice stuck in the dispenser and try again. If it is a Samsung fridge do the above and turn it off for 30 seconds and back on again. Sometimes the controller and display freezes and reads the wrong temperature.
Nov 18, 2014 | Refrigerators
Removed ice bucket to clean & now unable to return it into freezer how is this done?
Lift the ice level bar to the up position, the bucket should easily slide back in place. Make sure to drop the ice level bar back into down position to allow for ice to be made.
Sep 18, 2014 | Samsung RS2630SH Side by Side Refrigerator
Cannot get ice maker back into freezer. how should I do this
you have to turn the cog on back of the ice bucket, so it will fit back into the gear socket. I have the same problem with my fridge
Sep 18, 2014 | Samsung RS2534 Side by Side Refrigerator
Is the paddle supposed to spin
Your paddle won't turn. Your silver bucket is the one moving (turning) and not the paddle. It's working like it should. I thought the same before I found the lid (cover).
Jan 11, 2013 | Back to Basics -- Plastic Bucket Ice Cream...
I can't seem to get the ice bucket back into place on my RS265TD. What's the secret to putting it back once you've removed it to clean?
I hope you figured it out by now, but in case you did not: move the ice level bar up which will allow you to push the ice bucket back. Then move the ice level bar down to get the ice in the backet.
Aug 07, 2011 | Samsung RS265TD
We emptied ice bucket to fill cooler. Now all we get is crushed ice and not cubes. I can switch buttons from crushed to cubes but still get crushed. Did we do something wrong when I pulled out ice bucket...
There is a metal rod under the ice bucket. This rod sticks out from the back of the bucket. Where it inserts into the ice shelf, you will see a small square hole. This is what changes it from crushed to cubed. It is an actuator that moves the rod to allow cubes to come out. Stick a screwdriver into the square hole and move the actuator up and down. Then reinsert the ice-bucket and that should fix the problem. Hope this helps.
Mar 24, 2011 | Frigidaire FRS23H5AS Side by Side...
Ice maker stopped working
if there is ice in the mold then the problem is the ice maker unit , replace the ice maker for the fix.
Phil
Jun 10, 2009 | KitchenAid KSRG25FKSS Side by Side...
Refrigerators Logo
115 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
