Question about Samsung SyncMaster 913V 19" Flat Panel LCD Monitor
Samsung syncmaster 913v gives message ' not optimum mode"
    President:
  • 547 Answers
The 913V has a native resolution of 1280x1024. If you use a higher resolution than that, you'll get slightly blurry text. If you use a lower resolution, then images will be slightly choppy around the edges.
To get rid of the message, set your resolution to 1280x1024.
In Windows XP, you do this by right-clicking on the background (desktop) and selecting "Properties" to bring up the display properties.
Select the tab marked "Settings" and look for a "Screen Resolution" slider. Move that slider to the right until it displays "1280x1024" and hit "OK"
Posted on Oct 03, 2010
Syncmaster 913v not optimum mode
I just resolved this problem for my SyncMaster 913N.
It seems to be a known issue, however it can take quite some time for the problem to occur. In my case about 3,5 years, so well out of warranty.
Short term solution: unplug your monitor from power. The switch on the front is not good enough. Pull the plug and leave it for an hour or so (all night if you can). Good chance the monitor will work next time you power it up.
The problem will is likely to come back..
Permant fix requires some basic soldering as per this video:
I just managed it and it has been ages since I soldered a resistor so you may very well be able to do it. I spent $25 on tool and part and saved me from buying a new monitor.
Mar 20, 2010 | Samsung SyncMaster 913N 19" LCD Monitor
I have the same problem. I get a box with "not optimum mode. But what I need is a picture of the mainboard with the 50 ohm resistor between pin5 and pin6.
hello
I am a technician-informatic. I have repaired about 80 Lcd Samsung monitors with theese problems. I offer the repair manual.
Manual has been done with the experience of the repairing Samsung Lcd monitors. Manual was made by me and shows how to open monitor, how
to solve dark screen problem, how to check and replace capacitors, how to solve the problem non-optimal mode (without reprogramming MCU or
changing the main board) photo are included. 100% functional. The repair process is very simple 30-40min. (does not need a lot of
experience in electronics and expensive instruments) and is not expensive. With this manual you can solve problems by yourself and save
money.
"Not Optimum Mode 1280x1024 60Hz"
- The monitor turns on but turns off by itself, the LED blinks green.
- If you detach from the PC points to "control cable" the picture runs continuously in the vertical direction or presents while line , and
as soon as it is reconnected, the monitor goes off.
- The monitor does not turns on and dont dispaly anything, the LED blinks green-lit, if you detach from pc points to "control cable".
- The monitor turns on, works well some time, but after a window apiers "Not optimum mode. Mode recommended 1280X1024 60Hz"
- The monitor turns on, works well only with low resolution 800x600, when try to change a window that reads "Not optimum mode. Mode
the manual you can find on ebay (my ebay name is asnerejas123):
Samsung monitor repair manual guide 710n,913v,510n more
220498646211
Riparazione - repair Lcd Samsung monitor 710n,913v,510n
220498645860
Reparaturhandbuch für Samsung 710n,913v,510n und
Sep 14, 2009 | Samsung SyncMaster 710N 17 in. Flat Panel...
Samsung lcd television the screen goes blank after 20 mins of watching there is still sound though
right click on your desktop.go to properties.then go to the screen saver tab.click on screen saver tab.then you will see call monitor power.click on the power icon.go to the settings forr home/office desk power scheme.there you will see a setting called (turn off monitor)change that.let me know if it did work hay.
Sep 07, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Cannot set my SAMSUNG SYNCMASTER 710V MONITOR RESOLUTION
When you can't change the screen resolution then most likely only the default VGA driver has been installed. You need to install the graphics driver of the video card that is installed in your computer.
To check which graphics driver is installed, click on Control Panel - Display - Settings - Advance - Adapter tab. If the graphics adapter is set for Standard VGA then the graphics driver was not installed.
Aug 22, 2009 | AOpen Black 17" CRT Monitor
Samsung 913V LCD Monitor--No display when vga plug plugged in
1. please check by pressing num lock or caps lock key to verify that your machine is booting up, if yes then check the cable and if after changing the display cable it doesnt show up anything, it means you have a faulty unit
2. if numlock/caps lock key doesnt work, then your machine is not booting up, please check for loose ram etc.
Apr 04, 2009 | Samsung SyncMaster 913V 19" LCD Monitor
Syncmaster 913v
hi
I am a technician-informatic. I have repaired about 60 Lcd Samsung monitors with thees problems - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very easy and simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
if you are interested check it.
or just enter number in search field: 220409788372
thank you
Oct 26, 2008 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Samsung 710V Comes on for a second then shuts down
the fault is the backlight, Samsung has designed it as when one of the baklights are faulty the unit shuts down.
Sep 02, 2008 | Samsung SyncMaster 214T 21.3" LCD Monitor
Samsung Syncmaster 710n monitor - screen goes black for no reason. All cords connected properly. Computer works with other monitors. Switch on front of computer is on - green light on. Get floating...
in safe mode adjust the resolution lower than 1280x1024
then restart and then install the driver again the driver is crrupted than install the right driver problem could be solved
May 16, 2008 | Computers & Internet
Resolution Issue "Not Optimum"
Hi Guys.
I have had this problem and after a bit of searching found that it is a known problem.
Give Samsung a ring and if it's in warranty they will replace it
Jan 03, 2008 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Samsung SyncMaster 913V 19" Flat Panel LCD Monitor Logo
594 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
