Question about Acer AL2216W LCD Monitor
Monitor works during boot-up but not in Windows
I recently had to reformat my primary harddrive and re-install everything. Now I can't seem to use my AL2216W in Windows. The system has been set up to use a two monitor display system and the secondary monitor is functioning properly but as of yet, I have been unable to get it to use the primary (the Acer). It comes up during the initial boot sequence but turns off as soon as windows loads. I've installed the latest drivers for my Radeon x1650 card and for the monitor and the hardware setup is unchanged from before the re-install.
  • reddryder Apr 30, 2009
    I recently had to reformat my primary harddrive and re-install everything. Now I can't seem to use my AL2216W in Windows. The system has been set up to use a two monitor display system and the secondary monitor is functioning properly but as of yet, I have been unable to get it to use the primary (the Acer). It comes up during the initial boot sequence but turns off as soon as windows loads. I've installed the latest drivers for my Radeon x1950 card and for the monitor and the hardware setup is unchanged from before the re-install
  • 40 Answers
Did you install the ATI catalyst software?  You will have to check a box that says active monitor on your graphics console for the appropriate monitors.
srich
Posted on May 27, 2008
  • Frank Sheffield Jun 02, 2011
    i have aspire 5315 using windows ultimate 7 64bit. Almost same prob. The monitor works during boot-up then goes black. however. if i connect an external monitor then the notebook screen comes back on and it often stays on even after i disconnect the external. it continues working until i reboot. I have no driver for it and believe this is the prob. but it seems to me that if it will work when i connect the external (thus causing it to load the ext. monitor driver, i guess) then there should be some way to make these setting permanent until a driver does come out. this frustrating because i really like this os,
How can i reset my windows 7 password?
Lost Windows password:
  • Login as Administrator. Try with no password (load safe mode if you don't see Administrator). Press F8 during boot to access Safe Mode.
  • Login as other user (if other user is available) and manage users. Must be an administrator.
  • Reformat computer.
  • Use 3rd party software to remove password. Like http://www.top-password.com/reset-windows-password.html
If you can handle Hirons, this one's a breeze. Licence key purchase is required though. Nor does it specify EFI / GUID. Maybe contact them before purchase.
Oct 03, 2012 | Computers & Internet
How can I transfer data between two primary hard drive after replacing one
Windows needs to be installed on the new primary hard drive and also thecomputer or laptop's device drivers plus your programs etc. to get afunctioning computer/laptop again.
Jul 09, 2012 | Toshiba Computers & Internet
Blank Primary Monitor Problems
Try pressing F8 key while turning your system on, keep pressing till the recover mode appears with all list with safe mode etc. look for START WINDOWS TO LAST KNOWN GOOD CONFIGURATION. and select to run your program on this mode. Once your system is running, go to control panel ..select remove a program, from the given list of drivers try to remove the newly installed Nvidia drivers from it.
restart your system again, if the problem continues, try to restore the whole system, using restore and backup from your drive. best of luck.
Jun 24, 2012 | Computers & Internet
Trying to install windows 7 retail 64 bit on Scorpio (was installed once already started getting wonky so decided to format reinstall) boot with usb dvd rom drive get to unpacking of windows files and...
According to Microsoft, Windows 7 must be installed on a primary partition. This error code means the installer hasn't found a primary partition on the target drive. The primary partition must be on the first hard drive in the boot order, and if you have more than one user partition (not counting the small drive table partition), you must install to the first user partition. Unfortunately MS doesn't seem to have a clear, comprehensive answer to the issue. I've gleaned the following from various forum responses.
For some reason the installer is date sensitive, so make sure the time and date are correct in the BIOS. Time your next install attempt so it will NOT go past midnight during the installation.
Check your BIOS settings to make sure the drive is listed as a "primary" drive (drive 0, not drive 1) rather than a secondary.
Some people have had problems with the Windows 7 installer on drives that have the Master Boot Record from previous installations. Try a FORMAT /MBR using the Windows 7 install CD. If this doesn't work,
  1. Use the partition command to remove the target partition from the drive to wipe this out
  2. Partition the now unused space and reformat (again!), and
  3. If the partition command or installer has an option to set a partition as primary (or something else), choose primary (disk 0) for the partition you want to use for Windows 7.
If all else fails, use your HP Software Recovery CD to do a complete repartition and reformat. You could use the Windows 7 partition command to do the same thing, but then you would lose the HP System Recovery partition. However, if HP is marking the System Recovery partition as partition 0, it could be causing the problem. In that case, see if HP has an updated version of the CD that includes a fix for this, or do without it and turn it all over to Windows 7.
Dec 26, 2010 | Western Digital WD Scorpio Black...
Issues with some programs and not able to backup. So I tried to do a restore(not a full recovery). Now it goes to a DOS screen and displays:"NTLDR is compressed, press CTRL + ALT + DEL to restart and it...
Boot from your Windows installation disk and try to repair the Windows installation. NTLDR means NT Loader,it's the primary boot file for your OS.
You can repair if it can,or re-install.Just don't reformat during the process or it will wipe everything off your HDD partition.
Bob
Aug 10, 2010 | Compaq Presario 6350US (808736414036) PC...
I tried to re-install windows xp to clean my computer (running slow). It aske if I wanted to include web updates and I answer yes. Computer went to a blank screen and no won't load from recovery disc or...
Hi, you will need to reformat your hard drive before installing XP, First boot into BIOS by pressing the F1 key during bootup, change the primary boot drvice to CD rom, save changes. Insert XP cd into drive and reboot PC; select boot from CD when this appears during the initial boot fase. Allow files to be installed. When this finishes, delete partion and then repartion hard drive. Select format hard drive, when this completes your PC will reboot, do not select boot from CD and XP will start to install normally.
Hope this helps, if not come back to me.
Aug 04, 2010 | Computers & Internet
Had a power failure in my area, my dell desktop was on at time. When I turned it back on I got blue screen which I know is not good. Decided to install new/bigger harddrive since I need to install windows...
Hi, you need to change your primary boot device, try pressing the F1 key during bootup, this will take you to the BIOS screen, from here you can change your primary boot device from HD to CD, save your changes, reboot, selecting boot from CD when it appears during bootup.
Hope this helps
Jul 21, 2010 | Dell (E210882) Motherboard
How to reformat a computer?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To install new version of XP. Insert XP CD into drive, reboot pc pressing F1 button.. This takes you into BIOS, change your primary boot device to CDrom, save changes and reboot. Select boot from CD once this appears and wait for files to be installed. Select the part of the hard drive you wish to use for your operating system (usually the largest) and select partition this drive. Delete any previous os, and reformat hard drive. (Be aware this removes everything saved on your hard drive, so always back up first) Re boot afterwards and reinstall operating system.
Hope this helps
Jul 19, 2010 | Microsoft Windows XP Professional
Computer- reformat
In order for the computer to work, and for you to reformat the harddrive, you will need a bootable disk, either one which has a drive utility on it in order to reformat and partition the harddrive or an operating installation disk which includes a drive utility (any windows installation disk has it) - without one you will neither be able to properly reformat the harddrive nor install an operating system on it in order to use the computer.
As you have stated, this is obvious, and your problem is that you do not have an installation disk. A restore disk would not help if you reformatted the harddrive.
You can either purchase a Windows operating system disk, find one (no, not anything illegal - I have spare copies of windows and all of my geek friends have spare copies, because frankly of issues like this),
or download a copy of Linux and burn it to a cd - Ubuntu is a decent choice for a starting Linux user, and is very easy to use (works alot like windows, has tutorials, etc) and is completely free - you can do a search for Ubuntu Linux on google and you will be able to download a copy which can be burnt to disk or request a disk be sent to you, though I cannot remember if they still send free Ubuntu disks out.
Linux typically runs very well on limited resource computers such as the one you are in possession of. Did I mention it was free? If nothing else, you can use it to reformat the harddrive using their Live Boot disk - it allows you to use the Ubuntu operating system without installing it. You boot from the cd and can use their harddrive utility, or install Linux to the harddrive, or just check it out to see how it works.
Dec 14, 2008 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
Bootmgr error
theres several stages involving formating a disk.
this error however, appears to be discribing a boot-manager program.
Try booting with Windows in the actually DVD Drive.
If this does,nt work, re-format the hard-drive. or obtain a setup disk from your computers manufacturer.
i.e Compaq.
Mike @ Compurepair.
Feb 24, 2008 | Compaq Presario 2700 Series (222123-001)...
Acer AL2216W LCD Monitor Logo
186 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
