Question about Magellan Triton 400 Handheld GPS Receiver
When i start my unit then it freeze and i have to take the batteris out to shut down
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 154 Answers
Sorry but you have somehow corrupted the software in the internal system. Solution: Seek a repair center like the Jungle Ghost at http://www.jungleghost.com/repair_service.shtml
If the unit is in warranty .. return to Magellan
Posted on Dec 01, 2010
My tablet started shutting down and restarting while I was using it. It eventually would do nothing but shut down and restart but only partial start up. It freezes at the Samsung screen and then re
got same problem on my alcatel android phone. it has somethiing to do with heat sensor. I install toogle notification and put battery temperature as notification bar icon. whenever I used the phone for heavy app or charge it with hi-amp charger until it get above 38 degree, it will keep restarting. if it happend, no choice except remove battery until it cool back down.
Nov 05, 2014 | Samsung Galaxy Tab 2
Sony vaio PCG-7142L keeps freezing
Can check if the battery is low ... or is not (or cannot) holding a good charge ... when you unplug it (from the charger) ... when this happens ?
If that is the case, it may "freeze" while it is busy trying to store the contents of your memory before it shuts down (or hibernates). Does it shut down (or goes into hibernate if you let it continue to "freeze") for a while ? If so, then it's your battery.
If the battery doesn't hold a good charge, the laptop will run only a short time (while unplugged) before it has to shut down due to low battery. And if this is the case, consider getting a replacement (new) battery. And follow the initial charging instructions (for a new battery) to lengthen the life of the battery.
Apr 03, 2014 | Sony VAIO Computers & Internet
D620 bad battery causing freeze
Original or replacement battery? Replace battery, or, Contact Dell Support, if it's a fault or recall on the specific battery, it would be noted at Dell. There has been battery recalls, in the past, that were fire hazzards. I don't know if your battery applies? This issue COULD be dangerous, if left unattended.
Dec 31, 2012 | Dell Latitude D620 Notebook
Model Number: UACC-036JAS The unit works fine. The problem is it doesn't shut down after the specified temperature has been reached. The furnace blower shuts down, but the ac unit keeps on running....
Hello, usually a stuck contactor coil will cause this on the outside unit. When the outdoor unit runs continously and the indoor blower does not run no heat is being absoebed by the evaporator coil and thus the line freezes. Replaceing the contactor will fix the problem.
Aug 30, 2011 | Ruud Heating & Cooling
My hp dv 6000 will not boot up. What can I do.
shut down unit...pull power cord...pull the battery out of the unit ...reconnect power cord see if unit will start up... if it does, go to e-bay price a new battery... you have the information on battery...
shut down unit re-install battery see if it starts up...if it does unit was dropped but ok for now.
if unit does not start repeat first part,,,, order battery or bid on one or wait a while till you have the money.. or do battery pwr test...if not replace battery with a known good battery see if computor will boot if it does boot.... bad battery.
Nov 25, 2010 | HP Pavilion dv6000z Notebook
Showing a LP on display. What are the possible problems?
Here is the reason for that problem per the manufaturers web-site
http://www.haywardnet.com/products/Manuals/pdfs/Manual122.pdf
The low-pressure switch senses the refrigerant pressure in the sealed refrigeration system to
protect against certain conditions that could be detrimental to compressor life. The switch shuts
the unit down in the event of loss of refrigerant, fan motor failure, evaporator freeze-up and
airflow blockage. The switch automatically resets when the pressure rises to normal operating
pressures. The display will show "LP" if this switch is tripped.
Evaporator Freezing
The low-pressure switch will shut the heat pump down when the evaporator starts to freeze.
When the unit starts to freeze the low-pressure switch will be tripped, causing the display to read
"LP" This will prevent the evaporator from becoming damaged or deformed.
If the air outside the heat pump is not warm enough to produce heat, the system will shut down.
The actual point at which your unit will shut down due to low temperature varies depending on
which model you purchased, current weather conditions, and the amount of sunlight reaching the
heat pump. The shutdown can occur anywhere within a wide range of temperatures, usually 45°F-
55°F. This is not a "fixed" range. We stress that climate conditions, sunlight, and various models
respond quite differently to low ambient temperature. A shutdown occurs because low
temperatures will activate the systems low-pressure safeguard switch (digital thermostats will
display a code "LP".) The unit will start up again when the temperature has raised enough to reset
this switch. Note: Low ambient temperature does not necessarily affect the Chiller models
or the cooling cycle of the heat/cool units.
If this post has helped you, please take the time to vote positively for me on this site. If you need additional help, I can be reached @: adamh@newconceptchem.com
thanks,
adam
Oct 23, 2010 | Hayward Heatpro 81k Btu Swimming Pool Heat...
Ihave Garmin nuvi 885. Suddenly screen is frozen. I start again and tochscreen work a few clic and screen is freezing again. I thought battery poblem and I purchase extra battery and arge fully and I tried...
You can update it with garmin webupdater or If its still under warranty send to garmin to be refurbished.I have the same unit and it does freeze up momentarily while the proccessor catches up.Only for a second though.Its a refubished unit as well.
Dec 23, 2009 | Garmin Nuvi 660 GPS Receiver
The outside unit runs but the inside doesn't blow
COUL BE A FAULTY BLOWER RELAY BOARD OR THE MOTOR COULD BE GETTING HOT AND SHUTTING OFF ON OVERLOAD. CALL A CONTRACTOR
Jun 16, 2009 | Goodman CLJ36AR42 Air Conditioner
Coils freezing up on a/c unit
hi thanks for the question i would check the air filter this is a must it has to be kept clean the only other reason is if your trying to keep the room too cold the unit.has to shut down to let that ice melt so if your trying to keep the room too cold it will never shut down don't try to get 68 degrees
Sep 27, 2008 | Heating & Cooling
R31 freezes up
Your computer shut down due a bad battery, Need to replaced.
Replace the battery first and see if your computer still freezing.
The reason(s) you may experience computer freezes, could be software related or hardware related; perhaps it's a combination of both.
Below is a broad list of some of common causes of computer freezes.
  • Memory
  • Video
  • Device Drivers
  • Bad Motherboard
  • Bad Devices
  • System Resources
  • Software
Sep 25, 2008 | IBM ThinkPad R31 2657 Notebook
Magellan Triton 400 Handheld GPS Receiver Logo
35 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
