Question about John Deere Garden
John Deere 318 riding lawnmower break pedal stuck in down position, cant move. Found that was havng to push down very hard to get started and then last time pushed all the way down and started but cant move because pedal(s) stuck. How can I release them?
SOURCE: illustrated parts list for john deere 102 riding lawnmower
Go online to www.johndeere.com click on residenial tractors,then click on services and support. You should be able to get an answer there. Otherwise contact them through email.
Posted on Apr 08, 2009
  • 246 Answers
SOURCE: manual John Deere lawnmower
Hello lcurfman:
>>You can obtain Technical Information (operator's manuals, parts catalogs & service / technical manuals);
Call 1-800-522-7448
>>You can View a Breakdown/IPL of the Engine and Mower at this Site Addy, http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt and Enter the Model Numbers and Click Find. Then Select your Model from the Search Results Area. Then Select the Sectional File. Then Select the Section of the Mower you Wish to View Online. *You can Drag the View Windows for Better Viewing.*
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
  • 61 Answers
SOURCE: I have an Older John Deere riding lawnmower with a
ck anti backfire selanoid on carb see if its moving and if it is then ck for 12 volts
Posted on Sep 06, 2009
  • 69 Answers
SOURCE: I have an A680L John deere riding lawnmower. The
Burning belts sounds like something is locked up. Make sure there's nothing wrapped around any of the blades and that they turn freely.
Posted on Sep 09, 2009
SOURCE: need owner's and service manuals for John Deere Model 317/
First off, Mowerman's response was incorrect about the age of a JD 317.  They were made from 1979 to 1982.
You can only get manuals either through here:  http://techpubs.deere.com/deere/Default.aspx  or from a dealer.  They're expensive.  You can find them on ebay and also here: http://www.ssbtractor.com/tractor_manual_display.cgi?m=John%20Deere&o=317%20Hydrostatic but I haven't used that site.
Posted on Oct 27, 2009
John Deere 318. Why won't shifter move from neutral?
the dash is notched were the neutral posisition is , this notch (shift lever needs moved out of notch) is there for two reasons , the one you need to be concerned about is the clutch disconnect , this makes it impossible to shift into any direction without clutch pedal down , sometimes this lever will become bent and not press far enough for release arm of shift lever to allow its movement
love these little tractors , they got all the features of a bigger machine but with the size ease of a compact machine , for a small farm or big home garden there's nothing this machine cant do with the right attachments on it I sure wish JD still made em !
Sep 15, 2015 | John Deere Garden
Where is the fusible link in a John Deere LX 255 lawnmower?
First thing to check is make sure you blade switch is in off position, brake/clutch is down and locked. There is a 20amp fuse in a fuse holder by the battery in engine compartment. Is it not turning over or not starting?
May 08, 2015 | John Deere Garden
I have a John deere L108 ride Mower with a problem with the break pedal The brake pedal is pushed or the linkage is stuck in the "brake" position.I have disconnect from the diff but unable to...
if the linkage is free it is probably the caliper. you may have to take it off and work with it to get it free. they get stuck from rust sometimes. there is videos on you tube that show how to do this.
Feb 21, 2018 | Garden
Brake pedals are stuck down and cant be moved....
Will need the model number for best results, but insure that your parking brake lever is not still engaged. Typically a lever on or below the "dash". You would need to depress the foot brake and at the same time, release the parking brake handle.
Oct 02, 2010 | John Deere Garden
Fuse problem on John Deere 318 lawnmower
Does the mower have an electric clutch the clutch could be going bad if it has one unplug the clutch and see what happens
Oct 19, 2017 | John Deere Garden
Mowing right along and suddenly the tractor won't go move
it's 1 of 5 likely things
The drive belt from the engine to the transaxle is totally slipping or broken
The linkage from the control pedal to the transaxle is faulty.
The transaxle is broken (not user fixable)
The by-pass rod is pulled out
Jul 11, 2010 | John Deere 22HP Hydrostatic 42" Riding...
The parking brake on my John Deere L118 is stuck in the activated position. Therefore the tractor won't roll. How can I disengage the parking brake?
Usually there is a red handle under the steering colunm that locks the pedal down. You will need to depress the brake as you push down on the red handle which should release it.
Oct 11, 2009 | Garden
Parking Brake Lever (Orange Plastic Lever on left side) is stuck
The parking break is associated with your foot break. Depress the foot break ALL THE WAY down, then you will find that your parking break can be pulled all the way up.
May 14, 2009 | John Deere Garden
Garden Logo
275 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
